Old 05-19-2014, 12:01 PM   #1
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Legless awning angle adjustment
My Fiamma legless awning extends almost horizontally, and with my arm straight up (about 7.5 feet) I'm nowhere near touching the end.
I'd really like to set it lower to provide more shade and a cozier feel under it.
Has anyone tried adjusting it so the angle of inclination is greater? Wondered how easy it is to do, and whether there were any disadvantages.
Peter
Old 05-19-2014, 01:55 PM   #2
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
I think you would have to adjust the mounting angle on the roof to make this happen. Have you thought about getting a shade that attaches to the awning and hangs down.
Ron_CA is offline   Reply With Quote
Old 05-19-2014, 03:09 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I don't have the legless Fiamma F65 Eagle awning. My awning is just a regular F65 with legs. But I have an 8×12 black mesh shade that attaches to the front of the awning, for when the Fiamma Privacy Room is too much trouble to set up. It really makes a difference. But I can't recommend it for the F65 Eagle awnings.
With the F65 Eagle legless awning, you'd have two problems using that kind of shade. First you'd need a ladder to attach it when you set up and remove it when you break camp. Second, you'd need to disable the auto-retract feature of the awning, because if it auto-retracts while you've got that shade staked down, you'll break something.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-19-2014, 03:28 PM   #4
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
You would have to adjust the mounting of the awning but that will likely require you to fabricate new cast aluminum mounting brackets. The instructions for installing the mooting brackets and the awning are found here.
Hanging curtains will not work because the extra weight and wind drag will almost certainly cause the awning to retract even in the slightest breeze or even someone just brushing by it. You can disable the auto-retract switch, but then you risk bending or breaking the awning support arms if wind gust comes by.
Your least cost alternative might be to sell your legless awning to someone else and replace it with a legged awning that will fit your existing mounting brackets. That would open the opportunity for mounting an exterior privacy room.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 05-19-2014, 03:47 PM   #5
Ron_CA's Avatar
Looking at that drawing you MAY be able to:
Remove screws H, bolts E and fabricate new brackets F to just give a little tiny bit of additional rise or twist to the awning as a whole. A tiny bit 1/4 inch or so will equate to a lot more at the end of the extended awning.
Now remember I said may be able to. You would have to look at it yourself and see if this is workable or not.
Old 05-19-2014, 05:24 PM   #6
UKDUDE's Avatar
Sedona , Arizona
Thanks guys.
I downloaded the F65S manual and it seems the inclination angle is preset to 10 degrees, but there's some plate in there which can be positioned to provide four angle options - 0, 5, 10 and 17 degrees. 17 degrees would be better than 10 degrees, although not by that much.
I wondered if anyone had tried changing any this and whether lowering it would still provide enough clearance with the sliding door.
Old 07-12-2014, 07:49 AM   #7
Ellisu2015's Avatar
Baton Rouge , Louisiana
I am taking my 2015 AI Ext into the RV dealer today for some minor work and will inquire. I find the automatic retraction feature engages too easily. Would like to adjust the wind tolerance and would certainly like to adjust the angle of the awning. I will see if the dealer can help.
2015 AI Ext
Ellisu2015 is offline   Reply With Quote
Old 07-12-2014, 08:07 AM   #8
UKDUDE's Avatar
Sedona , Arizona
Thank you Ellisu2105, I have documented in another thread that I'm not really fond of the legless awning, and this is another reason; lowering the angle of inclination may help to reduce the chances of an automatic retraction due to the wind. Please let us know the outcome.
Peter
Old 08-17-2014, 07:44 AM   #9
Ellisu2015's Avatar
As an update, the dealer in Baton Rouge was not able to change the angle due to the sliding door interference. They were able to adjust the wind sensitivity so the awning wouldn't prematurely retract with little movement from the wind. I guess we will have to live with the parallel angle of the legless awning.
2015 AI Ext
Old 08-17-2014, 03:21 PM   #10
UKDUDE's Avatar
Sedona , Arizona
Thanks Ellisu2105, agree we'll have to live with it.
Awning lock latch alignment adjustment help exallen Awnings 18 02-21-2014 12:18 PM
Which is worse when towing, trailer angle UP or trailer angle DOWN? Streamer1 Towing, Tow Vehicles & Hitches 33 09-19-2006 08:43 AM
Zip Dee Awning Adjustment handn Awnings 3 04-28-2006 06:42 PM
Hitch angle? Krazykraut General Motorhome Topics 2 07-01-2004 02:53 PM
Legless... canny_banjo_man Off Topic Forum 5 05-15-2004 06:54 AM
