Old 08-26-2014, 06:09 PM   #1
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Leave Shore Power Connected 24/7
Since taking delivery in late May I have kept my Interstate in my driveway when not on a road trip.
I will be starting to store it in my garage on another property I own. I have a 30 amp RV outlet and am wondering if I can leave it plugged in all day, every day?
The solar panel does great keeping things charged but since I won't be in the sun anymore?
RV dealer said yes at walk thru and my airstream manual says no, but I realize a lot of info in the manuals is not updated every year and some may be wrong.
Can I call Magnum and see what they say, or will the answer be depending on the entire system install.
What is the consensus here?
Ron_CA is offline   Reply With Quote
Old 08-26-2014, 06:28 PM   #2
Teamaron's Avatar
2014 Interstate Ext. Coach
Boca Raton , Florida
I have mine plugged in 24/7 in my warehouse and called airstream to confirm and they said yes it's fine as it has an auto shutoff when charge and will trickle charge when low.
Teamaron is offline   Reply With Quote
Old 08-26-2014, 06:57 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have several things that I keep plugged in even when not in use, a couple of them being RV's. I do have a battery disconnect on mine. But if the converter/charger is working properly it shouldn't matter.
Aaron
WBCCI #XXXX AIR #2495
Old 08-26-2014, 07:06 PM   #4
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Can you identify your charge converter by brand/model?
What about getting separate panels mounted on your garage roof that your quick connect when you park/store?
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 08-26-2014, 07:12 PM   #5
1987 25' Sovereign
Oregon , Ohio
I keep mine plugged in all the time when home, but I do leave something small on like the radio or a night light so that there is a small drain on the batteries all the time.
msmcv51 is offline   Reply With Quote
Old 08-26-2014, 07:28 PM   #6
Ralph & Shin
Rsknutson's Avatar
Frederick , Maryland
Soon after we bought our 2014 AI I had a 30 amp circuit installed and have kept it connected 24/7 when parked in the driveway. Given today's advances in electronics I would have been very surprised but even more disappointed, had it not have the auto shut off feature. By The Way Ron_CA, nice garage!
_____________
Ralph & Shin
WBCCI #6954
Rsknutson is offline   Reply With Quote
Old 08-26-2014, 07:45 PM   #7
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
The key to whether you can leave it plugged into shore power full time is whether you have a 3 stage charger or not. If you have a single stage converter/charger such as the Parallax that AS puts in their trailers then you should alternately charge the batteries fully and then disconnect them every few days to a week. This is because it charges at a constant 13.6-13.8 volts and will "cook" your batteries over time. A 3 stage charger will maintain the batteries on a "float" charge of about 13.2 volts.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 08-26-2014, 07:52 PM   #8
Ron_CA's Avatar
Thanks Aron. I may call them tomorrow just to see if we get the same answer
Not sure what Converter / Charger I have. The controller is a Magnum ME-MR.
Thanks everbody for your thoughts.
Old 08-26-2014, 08:10 PM   #9
UKDUDE's Avatar
Sedona , Arizona
There have been numerous threads on how to efficiently manage batteries in the Interstate, and whether or not to leave it plugged into shore power indefinitely.
In my opinion the confusion is down to Airstream not updating the manual when they upgraded the charger/inverter to a Magnum.
The Magnum is a smart (multi stage) charger that efficiently maintains the batteries indefinitely. The only problem for Interstates is that Airstream never installed a temperature sensor since the Magnum needs to know the prevailing temperature to optimize charging.
Old 08-27-2014, 07:30 PM   #10
Ron_CA's Avatar
I talked to Jim @ Airstream and he said yes, it is ok to leave plugged in. He even acknowledged that the manual states otherwise.
Old 08-27-2014, 07:41 PM   #11
2010 22' Interstate
Vincennes , Indiana
What, then, makes the Magnum different from the Tripp Lite if neither have a working temperature sensor as installed in the Airstream?
aa9zz is offline   Reply With Quote
Old 08-27-2014, 08:26 PM   #12
UKDUDE's Avatar
Sedona , Arizona
This question is best answered by our resident electrical expert - Lewster - but I'll give it a go:
The Magnum has an automatic 4-stage charger process (Bulk, Absorb, Float,
and Full Charge). It continually monitors the battery without overcharging, and when the voltage drops below a certain level, will automatically go into float mode to provide a trickle charge.
The voltage levels at which it moves between one stage and another are dependent on temperature to ensure no under and over charging. Without the temperature sensor it uses a default setting.
I cannot answer for the Tripp Lite but believe it has a lower number of stages for charging and may not even have temperature sensor capabilities.
Old 08-28-2014, 08:08 AM   #13
ben322's Avatar
2009 Interstate
Bethesda , Maryland
Those with the Tripplite should be very careful. Even with the dip switches in the correct positions, it boiled a set of batteries when left plugged in which is another reason I upgraded to the Magnum.
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 08-28-2014, 08:30 AM   #14
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
You could always plug into a cheap timer and set it to charge one hour a day. If it's only about batteries current should be real low.
kscherzi is offline   Reply With Quote
Fresh water tank filling when connected to shore water redzebra Fresh Water Systems 7 12-20-2013 02:52 PM
Battery charging when connected to shore power. Wingeezer Batteries, Univolts, Converters & Inverters 3 07-15-2011 10:12 AM
No 110 power connected to shore bonginator Electrical - Systems, Generators, Batteries & Solar 3 06-25-2010 07:53 PM
Battery at 45% even though connected to shore power SilverGate Batteries, Univolts, Converters & Inverters 27 04-17-2009 04:35 PM
TV connected & on shore power? Kistler Audio, Video & TV 4 04-03-2004 05:12 AM
