Old 08-28-2014, 01:44 PM   #15
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Originally Posted by kscherzi View Post
You could always plug into a cheap timer and set it to charge one hour a day. If it's only about batteries current should be real low.
I am actually leaning in this direction.
Ron_CA is offline   Reply With Quote
Old 08-28-2014, 02:03 PM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by UKDUDE View Post
I cannot answer for the Tripp Lite but believe it has a lower number of stages for charging and may not even have temperature sensor capabilities.
I believe the TrippLite is three-stage without temperature compensation.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-28-2014, 03:56 PM   #17
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Another relatively cheap and quick alternative is to get a smart battery charger that has the same features as a Magnum. I bought a CTEK Multi US 7002 in error before realizing the Magnum could be left plugged into shore power. And it has a temperature sensor.
Old 08-28-2014, 03:59 PM   #18
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Confidence in the grid should be part of the equation, here in FL the lightning capitol of the US it is better to pull the plug. Power surges are not unusual either, someone suggested a timer but if it is long term parking, a battery minder on the timer would be a better option, plugged in it will keep the batteries charged and maintained.
Old 08-28-2014, 05:39 PM   #19
2011 Interstate Coach
Muskogee , Oklahoma
The 2015 models have the Magnum Inverter/charger.
The temperature sensor monitors the temperature to better tune the amount of voltage based on the temperature. But the main difference between the two is the Magnum won't overcharge the batteries-the Tripplite definitely will.
The Magnum is a "smart" charger. It shuts off all current when the batteries and fully charged, and then turns on when they are less than fully charged.
Leave it plugged in if you have a Magnum. If you have a Triplitte, don't. Rather, turn it on until a full charge is reached, and then unplug it.
You can add a battery temperature sensor for about 30 bucks. You can also upgrade to a better monitor and battery monitor kit. It's fun to click on the LPG valve for instance, and immediately see that you just upped the load by .6 of an amp. Or see just how ineffective the stock solar panel really is.
Finally, if you have the Tripplite, consider upgrading to the Magnum. It's worth every cent.
Originally Posted by aa9zz View Post
What, then, makes the Magnum different from the Tripp Lite if neither have a working temperature sensor as installed in the Airstream?
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 08-28-2014, 06:11 PM   #20
2005 16' International CCD
2015 Interstate Coach
Bandon , Oregon
We have some wild winter weather here in the Northwest including power outages and electrical spikes.
We kept our Airstream trailer connected 24/7/365 and plan to do the same with our new AI.
We leave a small table-top dehumidifier and heater (on low) to draw on the battery just a bit. In 9 years, we've never had a battery problem with the trailer. Don't expect one with the AI.
Rapa Nui is offline   Reply With Quote
Old 08-28-2014, 07:28 PM   #21
Sebastopol , California
I don't have 30amp service where I park my AI but I do have power. I purchased a C-tek multi stage charger and keep plugged in to a wet cell 24/7 when not traveling. This is a reasonable solution as I have total and continual use of my DC system at home . I've recently been experimenting with a 100w solar suitcase which appears to do an adequate job and stores reasonably well beneath the couch.
Sebtown is offline   Reply With Quote
Old 08-29-2014, 10:46 AM   #22
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
If you are just charging batteries a 15/20 Amp adapter for your power cord will allow you to plug into a standard 15/20 Amp receptacle. I can run everything except AC with this adapter.
- - Mike
2013 AS Interstate on 2012 MB Sprinter
- - Mike
Old 08-29-2014, 05:42 PM   #23
I considered using my adapter and factory shore cord but I prefer the c-tek charging profiles including the programmable reconditioning mode to desulfate the wet cell on occasion.
Old 08-29-2014, 09:59 PM   #24
David M's Avatar
Orange County , California
- - Mike
Hey Mike,
I don't understand. I can run my AC using a 20 amp adapter. I also have a 2013 AI on a 2012 chassis. Am I missing something?
David
David M is offline   Reply With Quote
Old 08-29-2014, 10:09 PM   #25
Originally Posted by David M View Post
Hey Mike,
David
I think I understand. You can run your AC. Or you can run everything else. But you can't run your AC with everything else.
WBCCI #1105
TAC LA-4
Old 08-29-2014, 10:39 PM   #26
David M's Avatar
Thanks Protagonist, that makes sense.
David
Old 08-30-2014, 07:35 AM   #27
BikerBill
Poconos of Pa , Pennsylvania
Using a home 20 amp outlet will work for your AC but not the m-wave at the same time. Think of it like this. A normal window AC in your home plugs into a wall outlet but you wouldn't plug in your m-wave to the same outlet in your house and use them at the same time. If you did, pop the circuit breaker. Same thing applies to your 20 amp outlet for your AI. Now plug it into a 30 amp outlet, that's a different story but most people don't have a 30 amp outlet at their home.
Your 3 biggest amperage draws are the AC, the m-wave, the water heater on electric and your Magnum inverter/charge may draw 7 amps on charge mode. So plan accordingly how to use your 20 amps when plugged into your home outlet.
Bikerbill is offline   Reply With Quote
Old 08-30-2014, 09:43 AM   #28
UKDUDE's Avatar
Sedona , Arizona
Actually the same considerations apply when you run the generator: you have just 20 amps available.
Fresh water tank filling when connected to shore water redzebra Fresh Water Systems 7 12-20-2013 02:52 PM
Battery charging when connected to shore power. Wingeezer Batteries, Univolts, Converters & Inverters 3 07-15-2011 10:12 AM
No 110 power connected to shore bonginator Electrical - Systems, Generators, Batteries & Solar 3 06-25-2010 07:53 PM
Battery at 45% even though connected to shore power SilverGate Batteries, Univolts, Converters & Inverters 27 04-17-2009 04:35 PM
TV connected & on shore power? Kistler Audio, Video & TV 4 04-03-2004 05:12 AM
