Leaking window on sliding door
Quick thanks to everyone who takes the time to share their knowledge about AI ownership. This forum is a great resource and you guys have saved me many times
I have a 2014 3500 EXT. We love it but like many others are always dealing with an issue. Our most recent is a leak on the sliding door window. I've read that this leak is not uncommon and that some have had to fully replace the 3 CR Lawrence panels and others have only had to replace the gasket. You can see from the pics where the water is. Water leaks inside and makes the fuzzy panel wet.
Can someone confirm they've had success with just replacing the gasket? Does anyone know the name and Part #?
Also, could I choose to make that entire window fully leak proof by filling all the space with a clean bead of .... what? Vulkem, Sikaflex? Would there be an increased risk (shatter) to that window if i sealed it?
That sliding door window takes and absolute beating and I can live with the vent window permanently shut and water tight/proof.
