Old 08-01-2012, 06:24 AM   #1
2013 Interstate Coach
Milton , Florida
Keurig Coffee Maker
Has anyone tried using the Keurig B130 DeskPro coffee maker on their 750w inverter?
The B130 is rated at 700w.
I plan on doing alot of boondocking and don't like the thought of having to use the generator to brew a cup of coffee.
Glenn
gastockman is offline   Reply With Quote
Old 08-01-2012, 06:26 AM   #2
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Good question! I will be carrying a Keurig in my AS.
surfpod is offline   Reply With Quote
Old 08-01-2012, 08:08 AM   #3
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Get a stainless French Press and use your propane stove. Makes better coffe than the Keurig.
Ahab is offline   Reply With Quote
Old 08-01-2012, 08:11 AM   #4
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Not to mention it's much much less expensive and a lot more friendly to the environment!
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 08-01-2012, 08:19 AM   #5
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
We just bought an old percolator with the glass top at Goodwill and use that. Pretty good and easy to use and clean.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 08-01-2012, 08:37 AM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use a Keurig and French press at home. Too much trouble to deal with the Keurig in the trailer. I use a French press for camping. I have a plastic bodied press so don't have to worry about it breaking.
MICHAEL
Old 08-01-2012, 09:06 AM   #7
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Us too. I like tea and my wife coffee. I boil water in a kettle so we both get what we want.
But I do love the smell of coffee. I bought a bean roaster and roast Beans for my wife, at home and before each trip. Man I love the smell of fresh coffee. U It also covers the smell of four kids in the car, as the smell is strong for a good 5-8 days.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-01-2012, 11:01 AM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
What hasn't been said here is that any resistance appliance (coffee maker, toaster, hair dryer) run through an inverter will chew into batteries' amp hour capacity pretty fast. And sadly, TVs to... Note that best lead-acid battery lifetime and reasonable amp-hour capacity during that life will occur if you avoid discharging below 45-50%. That's what we hear often enough. I don't have any specific reference on that. Experts?
Airstream has been installing Interstate SRM-24s in trailers. What do you have? Here is Interstate's data on them - Interstate Batteries.
Here is a fair read on amp-hour capacity. The brief Keurig cycle may work to your advantage but I don't think I'd move away from my French press if I was doing a lot of boondocking. And no, rooftop solar wouldn't provide much relief in substantially recharging a lot of amp-hours every day -- not that there is a lot of open surface on top of any Airstream.
Also note the following section in the last link that discusses measuring voltage to determine state of discharge. Measuring individual battery voltage works best if I disconnect the batteries.
Name:	State of charge.png
You'll learn a lot more as you experience your actual boondock/plug-in ratio. Burning lights is a no-low when we're boondocking. We use LED lanterns and they last forever.
[on edit: forgot to throw this link in ... Keurig Coffee Makers ]
5 meter Langford Nahanni
Old 08-01-2012, 11:08 AM   #9
2005 19' Safari
GLENDALE , AZ
Bodum makes several sizes of stainless-steel French presses. They are insulated; and if pre-heated, will keep your second servings relatively warm for about 30-45 minutes. Polished to a bright chrome finish, they compliment most Airstream interiors; however, these are a little pricey.
Old 08-01-2012, 04:07 PM   #10
Milton , Florida
Thanks everyone for your responses.
CanoeStream, your post provided more of the kind of info I was looking for.
I've got a Bodum French press. I'm not that impressed with it-but may have to use it when boondocking.
Thanks again for all your responses.
Glenn
Old 08-01-2012, 04:37 PM   #11
1966 17' Caravel
Bethel Park near Pittsburgh , Pennsylvania
Send a message via Skype™ to aceflys
K-Cup-Reusable-Coffee-Filter
We love our Keurig. It makes great coffee and tea. We use a K-cup reusable filter. We use way less coffee and don't pour out unused coffee in the pot. It is much cheaper then using the store brought k-cups.
Keurig My K-Cup Reusable Coffee Filter: Amazon.com: Kitchen & Dining
Ace in PA
aceflys is offline   Reply With Quote
Old 08-01-2012, 04:53 PM   #12
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hello ... We boondocked for 3 months last winter with our solar panels 350 watts and had no problem with our Keurig mini plus. Love it. Even use the breadmaker.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 08-01-2012, 05:18 PM   #13
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
The kids smell strong for 5-8 days!? Wow! ;-D
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-01-2012, 05:35 PM   #14
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Yeah, that is pretty funny, Purman. What sort of [home] bean roaster and would you recommend it to others? I'm tired of my drip maker, yet am resisting the Keurig at present (not that I really want to hijack thread, just learn the name of a quality piece of cookware or appliance) as I don't really want another electrical appliance aboard the TT.
