Old 10-31-2014, 07:50 AM   #29
fmrcaptevil's Avatar
Weldon Spring , Missouri
Any day now, I expect to be rear-ended and to have to hear: "dude, like, the 'adaptive' cruise control didn't apply the brakes...it's like, not my fault".
You mess with me, you mess with the whole trailer park.
fmrcaptevil is offline   Reply With Quote
Old 11-02-2014, 05:00 PM   #30
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Productive Sunday on the airstream to do list.
1) upgraded stock front speakers. (Amp, Sub & rear speakers still on the list).
2) installed 2nd LP Switch (silver plate left of magnum switch) rear curbside cabinet (finally) took easy route, ran wire out of cabinet through HDMI hole, then behind wall along window to the fresh water dump value. (Wasn't silicones so rob beside cold water dump for 14 gauge wire. Sliced into wire just above switch.
3) flipped wardrobe door to open from front instead of bed. (No clue why it opened from rear, was always awkward.
Total of about 4 hrs - heading from IL to Vegas (SEMA Show) on Tuesday after voting - trying to get the easy stuff. May get the step bypass done Monday.
Name:	ImageUploadedByAirstream Forums1414972570.985157.jpg
Name:	ImageUploadedByAirstream Forums1414972603.407763.jpg
Name:	ImageUploadedByAirstream Forums1414972675.663340.jpg
Mike
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 11-02-2014, 05:04 PM   #31
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Re: iPhone and bluetooth.
I think I solved the "phone" issue with my iPhone. It kept dropping the bluetooth connection and phone on radio has never worked.
Fiddling with menu and saw that OEM bluetooth was on. Turned it off- now phone and head unit act as expected.
Mike
Mike
Old 11-02-2014, 05:28 PM   #32
JRC
2013 Interstate Coach
Pinconning , Michigan
Great Job! I need to flip our wardrobe door as well. Do you have any hints for when I try it? Thanks
Randy
JRC is offline   Reply With Quote
Old 11-02-2014, 05:33 PM   #33
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Kenwood (Garmin) Map Updates
Randy
Was really simple. I made sure hinges were same distance from top and bottom of door. (mine were). So Removed the door & just put a piece of paper over the trim, punched holes where the screw holes were and transferred to the opposite side. Drilled a small pilot hole and mounted it. For the latch I didn't even remove the latch from the door; just flipped cabinet side upside dow and transferred to other side. Took about 15 min since I already had drill & screwdriver out.
Mike
Mike
Old 11-02-2014, 07:39 PM   #34
Boxster1971's Avatar
Fulton , Maryland
Mike
Glad to hear you have Bluetooth to your phone working. The telephone buttons on lower RH side of steering wheel will allow you to answer phone calls and hang-up phone when done. Works great with my iPhone 5.
- - Mike
Old 11-20-2014, 05:54 PM   #35
2014 Interstate Ext. Coach
Bound Brook , New Jersey
Mike
Which devices menu were you fiddling with. I've just started setting up my 2014.5 AI Lounge EXT and I'm trying to make sure I don't miss anything. It seems like a pretty complicated setup that will be nice if it works.
SCARLET BISON
Silver 2014.5 Interstate EXT
scarletbison is offline   Reply With Quote
Old 11-26-2014, 01:25 PM   #36
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Originally Posted by lsbrodsky View Post
OEM updates in cars cost more than that! But I like the free updates on my Garmin RV unit.
Larry
I'm with you on that Larry. I use my RV 760LMT for navigation and leave the Kenwood set on media. I really like planning routes on my computer (full screen) and downloading them into the Garmin RV760.
c21bill is offline   Reply With Quote
Old 11-26-2014, 02:10 PM   #37
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I also like planning on my PC and downloading the routes to my Garmin RV. I just ordered the camera for the unit to rig a rear view.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-26-2014, 07:27 PM   #38
Larry
The other thing I liked about my RV 760 was traffic/road construction alerts nearly 40 miles ahead and school zone audible and visual alarm. Very nice unit all in all. I did discover that in the AI it works better in the car mode as it trys to do too much rerouting when used in the RV mode. Guess it things were a big class A rig.
Old 07-21-2015, 05:58 PM   #39
fairfax station , va
The 2015 map updates are $95.
OK, whatever,
but the real insult is $8.50 to ship a 1/4 oz, SD card
VAtom is offline   Reply With Quote
Old 07-21-2015, 06:40 PM   #40
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
The OEM map updates for my 2010 Tahoe are $200 but got them off ebay for $75. Might check there.
Old 07-21-2015, 07:43 PM   #41
UKDUDE's Avatar
Sedona , Arizona
Can't you download it directly for nothing?
Old 07-21-2015, 07:59 PM   #42
73shark's Avatar
Mine is DVD based. GM is always a decade behind on tech.
Garmin recalls 1.25 million Nuvi GPS navigation devices for fire hazard Phoenix Computers, Internet & Satellite 3 08-29-2010 05:05 AM
garmin gps feedback Rollerboy Phone, CB & Ham Radio 21 04-11-2009 05:04 PM
Garmin 2620 GPS unit wingfoot321 Electronics & Connectivity 1 09-11-2005 05:11 AM
Garmin Street Pilot 2610 GPS JaceBeck On The Road... 6 10-08-2003 06:59 AM
