Old 10-27-2014, 12:17 PM   #15
fmrcaptevil's Avatar
Weldon Spring , Missouri
Ford wants $150 for the new map update for my '13 Edge, and if I order it before Dec. 31st, they'll waive the 'shipping'...lucky me.
You mess with me, you mess with the whole trailer park.
fmrcaptevil is offline   Reply With Quote
Old 10-27-2014, 12:27 PM   #16
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by MILATV View Post
I ended up paying the $70......
.....Now to get a reliable BT connection so I can use the weather and personalization features in the SmartLink app on my iPhone.
Mike
If you are having Bluetooth issues make sure you have the latest software update in your unit. They are free from Kenwood. BT was one of the problems they were fixing with updates. Mine works OK now, not great BT if you switch devices often.
- - Mike
2013 AS Interstate on 2012 MB Sprinter
- - Mike
Old 10-28-2014, 07:35 AM   #17
Trying to Retire
MILATV's Avatar
Decatur , Illinois
DNX890HD Maps Update Process
Here is what I had to do to update the maps on my Kenwood DNX890HD.
1) Update firmware to unit:
Kenwood / firmware updater
Instructions:
http://www.kenwood.com/cs/ce/mm/firm...Wupdate_en.pdf
2) Update Map Data
https://kenwood.garmin.com/kenwood/s...playDeviceList
Updating maps required the following actions:
a. insert an SD Card (I used 8GB) into radio slot behind the screen. I pressed the eject button, but still had to use some force on rear of screen to push it down further to reveal the SD slot.
b. in Navigations setting menu; choose upgrade maps. This writes an XML file to the memory card with information Garmin uses to license the update to a single device (from best I can tell).
c. place SD card in laptop and visit the UPDATE MAPS link above.
d. purchase the maps (actually GarminExpress; which manages your updates).
e. Run Garmin Express to install the new map on the SD Card.
f. install the SD card back in radio in van.
I confirmed with Garmin that the SD card MUST stay in the slot to use the new maps; the map is not copied to the radio; the navigation reads it from the SD card.
And now I have all the updated waypoints and cul-de-sacs in North America
I really want to get the bluetooth & SmartLink working properly - that will be next time.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 10-28-2014, 09:34 AM   #18
Newbie
joemikeb's Avatar
Fort Worth , Texas
Originally Posted by Protagonist View Post
You mean the micro SD card size? You might be right, but it could also be that was the largest card size available when the manual was printed. Since the cards all have the same contacts on the edge, it's entirely possible that the unit will accept higher-capacity cards just fine; it's just that Garmin won't guarantee that they'll work. You try it at your own risk.
It isn't just the electrical contacts that determine if an SD card can be read or not. The cards come in three different capacity ranges SDSC (standard Capacity - 8 GB), SDHC (High capacity up to 32 GB), and SDXC (eXtended Capacity - up to 2 TB). The firmware in the reader device must recognize and know how to access the different SD card versions. Any reader can handle SD, but not all can read SDHC, and even fewer comprehend SDXC. If the firmware in the system only comprehends SD then you are limited to 8 GB capacity.
On top of that there are different SD bus speeds but fortunately those are backward compatible where the capacity ranges not so much.
Make errors otherwise the Great Spirit realizes
you have finished your purpose on earth.
Navajo saying
joemikeb is offline   Reply With Quote
Old 10-28-2014, 10:38 AM   #19
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Just so everyone knows: it is full size SD card. I used 8GB because it was plenty big and was the one I had laying around. All files with the 2014 map is 3.9 GB.
Mike
Old 10-28-2014, 11:29 AM   #20
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
There was also mention of the Nuvi, which takes a micro SD card, and my question about card size was related to that comment.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-29-2014, 09:27 PM   #21
2014 Interstate Ext. Coach
Monroe , Washington
I am pretty annoyed by the $70 charge for a GPS map update. The blame lies entirely on Airstream here.
I have a 2014.5 Interstate with the DNN990HD and integrated Garmin GPS.
Almost all Garmin units are available in a version that includes Lifetime Maps. You can buy a Garmin unit without Lifetime Maps, but I assume nobody dies. On Amazon, across a wide range of models, adding Lifetime Maps adds at most $10 or $20 to the cost of a model.
So Airstream configured this system without Lifetime Maps. I assume Airstream got a great price break on the unit from Garmin, perhaps even getting it for free. Airstream gets to advertise GPS built in, Garmin gets its profit on the map updates, and they're both happy. The customer ends up screwed.
A comparable Garmin unit with Lifetime Maps costs only $100 on Amazon right now. I'll replace the Garmin portion of the Kenwood unit, or replace the entire Kenwood unit (which I loath) before I spend $200 updating maps in the current unit every other year for the next five or six years.
Airstream got a good deal on the GPS at my expense. It is pretty annoying to get burned for a $70 map update on a vehicle I spent north of $140k on, and I totally blame Airstream.
Bruce
coder is offline   Reply With Quote
Old 10-30-2014, 04:55 AM   #22
However annoyed you might be, the map updates are still worth the price. Just minutes ago, on my way to work, I just narrowly missed a head-on collision with a guy going the wrong way on a one-way street. The guy wasn't willing to back up to clear the street even though he was going the wrong way, and we argued for a bit before I backed up far enough to let him past— despite having the right of way. He said he was "just doing what my GPS told me to do, and it's not my fault!" I didn't ask him when was the last time he updated his maps, but I'd wager he never has, since Garmin updated that particular street as being one-way nearly five years ago.
Keeping your maps updated doesn't just keep you from getting lost as often; it can keep you out of a collision…
WBCCI #1105
TAC LA-4
Old 10-30-2014, 07:24 AM   #23
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Wow, not his fault
Old 10-30-2014, 09:27 AM   #24
...plus the attitude (being unwilling to back up). Is this the 'new normal'?
Old 10-30-2014, 09:36 AM   #25
If I had to guess, more like the "new drunk."
WBCCI #1105
TAC LA-4
Old 10-30-2014, 09:41 AM   #26
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
I ended up paying the $70. Not worth that to chase down all the options after looking into it. Note: it doesn't actually "update" the unit, just downloads new maps to SD card that has to stay in unit.
Mike
Hopefull you didn't just buy the update that came in my 2015. In my first 12,000 miles it has been completely wrong a few times.
Ron_CA is offline   Reply With Quote
Old 10-30-2014, 07:28 PM   #27
Brucet45410's Avatar
2014 Interstate Coach
Norfolk , Virginia
Protagonist, that is a funny story! Stay thirsty my friend!
2014 Airstream Interstate
Currently a "Weekender" but planning a cross country trip during the summer.
Wherever you go, there you are!
Brucet45410 is offline   Reply With Quote
Old 10-31-2014, 03:55 AM   #28
Funny now. Not so funny when I was slamming on my brakes!
WBCCI #1105
TAC LA-4
Garmin recalls 1.25 million Nuvi GPS navigation devices for fire hazard Phoenix Computers, Internet & Satellite 3 08-29-2010 05:05 AM
garmin gps feedback Rollerboy Phone, CB & Ham Radio 21 04-11-2009 05:04 PM
Garmin 2620 GPS unit wingfoot321 Electronics & Connectivity 1 09-11-2005 05:11 AM
Garmin Street Pilot 2610 GPS JaceBeck On The Road... 6 10-08-2003 06:59 AM
