Old 08-24-2013, 09:52 PM   #57
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Originally Posted by MILATV View Post
Trying to ground the park wire but can't find a green wire on my DNX890HD.
I feel stupid because the videos show it bright as day!
Here is pic of harness.
Di you think it is wirienext to purple one to tught of data link? It's the only thing close to light green (more so in pic than it looks for real)
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 08-24-2013, 09:58 PM   #58
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
On mine in addition to controlling volume of the Kenwood unit the "End Call" button (bottom RH) will advance the audio mode forward on the menu. I discovered this by accident once when turning the steering wheel and having the radio advance from SIRIUS to FM.
- - Mike
Old 08-24-2013, 10:25 PM   #59
David M's Avatar
Orange County , California
That's the one I was thinking of too. On the picture, it looks to be light green (unless my iPhone color is off)
David M is offline   Reply With Quote
Old 08-25-2013, 07:31 AM   #60
2012 Interstate Coach
norman , Oklahoma
My mechanic ran the video outs from the head unit up to the front TV so I can use the Kenwood as the DVD player for the 2nd row passengers and run the audio through the stereo speakers. I discovered something fun the other day. On the Kenwood remote, there is a video out source button (I'll have to look to see exactly what it says) and by pushing it and scrolling through I can select navigation ... and that send the nav screen to the TV. My wife said it was like being on an airplane where you can see the flight status on the screen. Cool stuff.
russ240 is offline   Reply With Quote
Old 08-25-2013, 07:50 AM   #61
Trying to Retire
MILATV's Avatar
Decatur , Illinois
[QUOTE="russ240;1345372"] I can select navigation ... and that send the nav screen to the TV. /QUOTE]
I'd like to pull RCA cables down from my blueray/Netflix to the stereo and connect to video I in, then I'd have stereo out in front, rear or both when watching a blue ray or Netflix.
I have iphone5 so I converted the iPhone input (30 pin) to just AV2 input and run a long 1/8" aux cable to headphone jack for now. Works for bedtime movies but don't like the cord stringing across the floor.
Mike
Old 08-25-2013, 02:40 PM   #62
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Yep that was it, just looks white to naked eye, barely green in iPhone, not nearly as green as others I've seen, and on a different plug!
Ran an RCA plug out Video out jack for video to front TV, I like that wife can watch movie or GPS on the screen. Will take the time to properly route the wire when I get back to house.
Thanks for the help David M
Mike
Old 08-25-2013, 04:26 PM   #63
David M's Avatar
MILATV, no problem. Glad it worked out.
David
Old 09-01-2013, 03:47 PM   #64
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Added in dash USB and Aux-In jacks
USB connected to USB
AUX connected to Audio on Video Input.
Mike
Old 09-02-2013, 08:56 AM   #65
kaylorsan's Avatar
Los Gatos , California
Where did the find the add-on USB port? I've been searching for one to add to my dash and to the rear lounge area.
kaylorsan is offline   Reply With Quote
Old 09-02-2013, 09:03 AM   #66
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Amazon of course (as a retailer I hate buying there - but they have everything and its CHEAP with 30 day return. . .)
USB Connector:
PAC Usbcbl 6' USB Cable with Mounting Bracket: Amazon.com: Industrial & Scientific
Line in Jack
Amazon.com: iSimple IS335 Dash Mountable Auxiliary Input Adapter: Car Electronics
Looking at Photo I installed the USB a little further to the left than I meant to; In hind site; you could install in the ash tray, or in the cubby hole below the radio - there is plenty of cable.
Mike
Old 09-02-2013, 09:22 AM   #67
kaylorsan's Avatar
Thanks MILATV. I'm looking for a hardwired version that I can wire into a 12V line, but I think I can make something work with some of the products on Amazon (haven't found a direct match yet)
Old 09-02-2013, 11:44 AM   #68
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
I have two of these to add at (not yet determined) locations in the galley and rear bed area in my Twin. Dual USB Charger Socket - Blue Sea Systems. I found them at Amazon. They seem to be very high quality.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 09-02-2013, 12:31 PM   #69
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Got it: my goal was to make it easy to connect my iPhone 5 (the connector on it AS is only compatible with the 4 right now).
Here is link for charge only port connections.
Amazon.com: DC to DC Converter 12V to 5V USB Connector 3 Amp
Mike
