Old 07-05-2013, 07:12 PM   #1
David M's Avatar
2013 Interstate Coach
Orange County , California
Is this the main drain for fresh water tank?
I'm sanitizing my fresh water tank and now need to drain it. Is this the drain? This picture is under the coach on the street side just aft of the driver's door.
David M is offline   Reply With Quote
Old 07-05-2013, 07:50 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Looks right
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-05-2013, 07:55 PM   #3
David M's Avatar
Originally Posted by cwf View Post
Looks right
Thank you!
Old 07-05-2013, 07:59 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
FYI, open slowly. If water not clear, tighten back up. DAMHIK
Channing
WBCCI# 30676
Old 07-05-2013, 08:58 PM   #5
David M's Avatar
That's exactly what I did I used Teflon tape in reinstalling the plug. I hope that's acceptable. Thanks!
Old 07-06-2013, 10:57 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup Teflon white. Just don't cross thread Congrata!
Channing
WBCCI# 30676
Old 07-06-2013, 02:54 PM   #7
2011 Interstate Coach
Muskogee , Oklahoma
I found that with repeated removal of the drain, the soft threads began to wear, so I replaced the plug with a 90 degree pvc fitting that threaded to the tank, and then attached a low profile valve. It hangs down about an 1" from the tank. Now, I just turn the valve. Don't later Interstates now have valves as well?
The cost-about 5 bucks.
Gerald
Attachment 190271
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 07-06-2013, 03:29 PM   #8
David M's Avatar
Gerald
That's a great idea! Can you post a picture? This should be on the Interstate mod thread
Old 07-07-2013, 09:04 AM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Nope. But the 2013s seem to have a different tank than the 2012s. Mine has the drain valve flush with the bottom of the tank, without the sump pictured for the 2013 model shown in the original post.
Last time I had to drain the water, I thought the drain valve on mine was the same size as an oil pan drain plug, just made of PVC. If so, then they make valves to replace the drain plug on an oil pan, and I thought of buying one. But then again, I don't have to drain the tank very often, and decided it wouldn't be worth the expense. Especially since the valve would stick down far enough that it could snag on something and get knocked open, knocked loose, or knocked off.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
