Speaking as the Queen of Refrigerator Angst both sea- and shore-based (
here and more recently
here), I offer the following:
(1) From your description of gradual failure, it doesn't sound like the "tin whiskers" problem (
here) that has reportedly plagued some RV refrigerator models, chiefly Norcold. It sounds more like a compressor and/or sealed system issue. For the price point of the refrigerator, it may not be worth paying to repair it, unless you can DIY it, which probably would involve cracking the sealed system. Anyone who does that kind of work for money in Texas needs a technical license because of the refrigerant issue.
(2) If you go to the enormous hassle of replacing a whole RV refrigerator, it's such a P.I.T.A. job that you might want to think about switching models to one which has the highest perceived reliability. I relied on Lewster for that analysis, which is why I chose a Vitrifrigo (it wasn't the only one he mentioned - he was mostly choosing based on the presence of a Danfoss compressor model). Especially after reading the previous comment from the other user that the Norcold failure rate might be as high as 80%, I decided to go with what is known and not to experiment.
I'm not plugging for any given brand, but our Vitrifrigo has had zero problems in its first year of life. In my original blog post, I complained about lack of product support, but guess what?? Vitrifrigo subsequently found that post and reached out to me (hallelujah - that's what blogs are for). So if any U.S.-based person has questions about the brand, I recommend starting with this source:
Shryl Conner
Marketing & Sales Support
Phone: +1 (954) 979-7737
Fax +1 (954) 979-7740
Email:
Shrylconner@vfamerica.com
VITRIFRIGO AMERICA LLC
2200 NW 32nd St. Suite 1200
Pompano Beach, FL 33069
Web:
www.vfamerica.com
(3) Measure ten times, buy once. If you decide to switch brands to get a hopefully-better compressor, note that there are subtle dimensional differences across models that might otherwise appear the same size. Make sure a new one would fit, or that you can modify your cabinetry accordingly (which might be a big job).
Good luck - this will likely be a roaring inconvenience and expense for you whichever way you decide to go.
