06-16-2019, 05:50 PM
League City
iPad mounted in Interstate cab?
Has anyone successfully mounted an iPad anywhere in the cab of their Interstate? If so, how did you do it?
I recall Pahaska put in a mini-PC, but I do not remember anyone talking about iPad.
I'm going to semi-dedicate an old iPad to our OBD. I can't run music AND maps AND the OBD all on my iPhone - it involves too much fiddling to get from screen to screen. Plus Carplay does not recognize the OBD.
Especially with the new engine, I'm more fixated with keeping an eye on the real-time OBD read-out.
Thanks.
06-16-2019, 05:57 PM
2013 Interstate Coach
Bellingham
Ram mounts for ipad
You might check out ram mounts. They have multiple mounting solutions, and specific cradles for various iPad models.
https://www.rammount.com/consumer/brands/apple
06-16-2019, 06:33 PM
League City
I have a Ram Mount for my iPhone and I love it
--BUT--
it will not stick to 3M Crystalline window tint. Nothing will. I've even attempted to GLUE that little sucker to the window and it STILL won't hold. 3M CR acts like it is Teflon.
Even with a mount, the question becomes where. The iPad is heavy.
If I had one of those little console tables I'd love to fabricate, a mount could clamp on the lip of it, and it could perch, with most of the weight then bearing on the table top, hence removing the moment arm issue. Hmmmm....
06-17-2019, 04:48 AM
League City
Well, this is an awkward photo, but you get the idea. Ideally, I'd find a low-profile bracket so that I could mount it here. And rotate / customize the display, of course. And run a power cord up there (easy).
I travel with the sun visor down almost 100% of the time, the exception being in very low-light conditions, so the visor would not interfere with it.
The headliner was not designed to bear that kind of weight, however, so I'd have to think this through, as to how it could be achieved.
Why aren't vehicles built more like bloody airplanes? There should be read-outs of every functional condition immediately available to the operator. If I'd had something like this in place, I might have spotted it sooner when things began going wrong with my now-replaced engine. Maybe I would have seen an incipient loss of compression in time to keep the piston from ruining the whole damned engine block.
06-18-2019, 10:45 AM
2014 Interstate Ext. Coach
Las Cruces
, New Mexico
iPad & Phone mounted in Interstate cab
Shortly after our purchase of the AI, search for a phone or iPad mount began. As referred to above, RAM mounts for us have been a mounting solution for all of our vehicles' "gadgets", and for the jacuzzi! The photos attached provide an illustration, but what is not shown is the RAM mount adapted for the RViBrake2 System monitor.
07-26-2019, 09:46 AM
League City
Channeling Dana Carvey, I used to call it "that useless piece of plastic" (his 1995 HBO special was the single best comedic routine in human history, IMO).
That little open slot thingy in the T1N dash - what was that even intended for? I never did have any idea.
Well, how about this: husband carved a solid block of wood so that we could put the Ram mount on it and shove it in there. The trick to putting an iPad in this location is that it *floats above* the dash, thereby not cutting off access to any of the controls.
It's tricky to get those wooden plug angles correct so that it fits snugly, because the slot thingy is tapered. But worth the effort.
I haven't painted it yet - left the wood raw for visibility here.
07-26-2019, 01:33 PM
League City
George Carlin says hi!
07-26-2019, 03:22 PM
Sneedville
, Tennessee
I removed that thing...would it hold a pack of cigs?...and replaced it with a piece of steel and then mounted my seat heater controls there.
07-26-2019, 08:11 PM
League City
Seat heaters... something we need on the Gulf Coast about as much as we need a baseball bat to the skull.
07-26-2019, 10:08 PM
2018 Interstate Lounge Ext
LV
, Nevada
TINCAMPERS - My heater controls are mounted on the dash too, it's convenient
07-27-2019, 02:49 AM
Sneedville
, Tennessee
Yeah, but when you are in BC and it is 32 degrees, they are quite comfy. Otherwise, they do not affect anything when not is use.
07-27-2019, 07:15 PM
2007 22' International CCD
Corona
I live in Southern California. Within a couple hundred miles I can get 4 seasons worth of climate and weather. Seat heaters (bun warmers per DW) and reliable air conditioning will get exercised heavily, often on the same day around here in the winter.
Gulf coast? Been there. Grew up in Florida. Try to avoid subjecting myself to that kind of humidity anymore.
07-28-2019, 11:49 AM
League City
Always road test your mods before setting out on a journey. I forgot about the potential for crossed nicols. The iPad's default assumption is landscape usage (movies, I presume). It cannot be used vertically with polarized sunglasses. Therefore, this became the interim final configuration, as opposed to what I showed above.
It's pretty cool - if I want to run into a store, I just yank the entire thing out of the dash hole, and stash it out of view. No need to unhook from the Ram mount.
Edit: You know what that means, right? It means I can eventually add a second receiver in the rear and mount it there for convenience as well.
07-29-2019, 07:29 AM
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
...It's pretty cool - if I want to run into a store, I just yank the entire thing out of the dash hole, and stash it out of view. No need to unhook from the Ram mount...
This gives me an idea for better cup holders... I currently have an insert that I use for the table. Easy to make another one for just cup holder use...
07-29-2019, 09:06 AM
League City
The T1N's cup holders are essentially on the floor. I thought about using them for such a device, but they are really too low for anything useful (including cups).
07-29-2019, 01:47 PM
Port Angeles
Looks like you have it solved.
I removed that little cigarette pack holder (or whatever it is) and installed my seat heaters (wonderful around here) and a voltmeter that I can switch between house and starter batteries (top right switch).
Below I fabricated an aluminum piece that holds an ‘on-off’ switch for my GPS/power outlet and a place for the power outlet added. Plus some USB outlets. All run off the house battery, but I can quickly switch on/off.
Below the cup holders is the controller for my hydraulic levelers.
08-18-2019, 05:00 AM
League City
Having boost information fed to me in real time has changed my driving habits substantially. I didn't realize previously how easy it was to hit maximum psi during normal driving. In mountainous areas, I've started driving by turbo rather than driving by speed limit. Where it is safe and non-disruptive to traffic to do so, this means that my speed is variable between about 35 mph and 75 mph.
People get annoyed at truckers because many of them engage in this same kind of variable speed behavior. But I've read that they are not doing that because they HAVE to, but because they WANT to, to minimize the stress on their engines. I get it now.
So, if the driving conditions allow it, I try to stay below 18 psi at all times. It may not help engine longevity that much - I don't know - but I doubt that it will hurt it.
08-18-2019, 05:53 AM
Waterloo
, Iowa
Interesting idea. Next time I'm out I'll have to plug in my code reader and see if I can find the boost pressure value. But I hafta wonder how many Sprinters give up the ghost because of a stress-related engine failure. I would guess that it is the nickel and dime (actually hundreds and thousands of dollars in the case of MB) repair bill that cause most Sprinters to be retired. I change my oil religiously, typically far more often than every 10,000 miles, because it is cheap insurance. But each time I do so I wonder if I am really extending the lifetime of the Sprinter.
08-19-2019, 05:03 AM
League City
Originally Posted by Titus
I... But I hafta wonder how many Sprinters give up the ghost because of a stress-related engine failure. ....
But that's just it - ours essentially did, at about 73,000 miles. More or less.
In other words, by default conclusion, it wasn't normal operation that blew out the number one piston in our original engine. I don't know exactly WHAT it was, but I feel safe in concluding that (1) always being close to GVWR and (2) being close to maximum boost more often than I realized did not help our situation. If I can control one of those variables going forward, my tendency is to do it.
