Old 11-12-2014, 08:06 PM   #1
Glamper1's Avatar
Inverter as it relates to charging house battery
Does inverter need to be on to charge house battery via solar , generator , or shore power?
I have a 14.5 AI
Also with only 50 amp solar,
What can it sustain when I'm not plugged to shore power?
Thank you!!!
I know almost nothing about electricity
Glamper1 is offline   Reply With Quote
Old 11-12-2014, 08:32 PM   #2
2007 22' International CCD
If it's an inverter that provides only 115 to AC outlets, no.
The converter is the battery charger.
That provides power to your lights, etc that run on 12 volts as does your battery. It needs to be left on to charge the battery
Solar works to charge the battery separately. It's mostly automatic..that said, my solar does have an on/off switch--but since it's a smarter charger than my current converter I leave it on to safely charge batteries in my rig.
KE4GNK/AE
Old 11-12-2014, 08:34 PM   #3
BTW, inverters and converters wirk the same in MH and regular AS trailers, generally.
KE4GNK/AE
Old 11-12-2014, 09:19 PM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I have a 14.5 AI
Thank you!!!
My solar panel will keep the house batteries and the starting battery charged w/ everything OFF including the inverter. It did seem to be able to keep up w/ the refrigerator ON also. YMMV
Old 11-12-2014, 10:45 PM   #5
Glamper1's Avatar
Thanks you !
Ben
Old 11-13-2014, 05:15 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The inverter/charger has to be on to charge the house batteries from shore power or generator. If set on "automatic" it detects incoming 120vAC power and switches to charger mode. The solar panel is directly connected to the house batteries through its own charge controller.
You can run the refrigerator for a few days, along with roof vents and interior lights, but the draw on the fridge is 24 hours a day, and the solar panel only charges during daylight hours, so the house batteries will eventually lose charge if solar is the only charging source in use.
That is a shocking () revelation! Here are a few books you might consider buying (or looking for in your local public libraryŚ support your library!) to help get on top of the learning curve:
RV Electrical Systems: A Basic Guide to Troubleshooting, Repairing and Improvement: Bill Moeller, Jan Moeller: 9780070427785: Amazon.com: Books
http://www.amazon.com/RV-Repair-Main...trical+systems
http://www.amazon.com/No~Shock~Zone-...trical+systems
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-13-2014, 05:29 AM   #7
Gainesville , Florida
I think the OP has an Interstate, which has an inverter,charger. No converter?
Old 11-13-2014, 06:14 AM   #8
Lineolated's Avatar
2014 Interstate Coach
Centre County , Pennsylvania
We have a 2014.5 also. With our inverter off, the batteries will recharge.
From the Magnum manual:
"The two modes of operation associated with this inverter charger are...
Inverter mode: DC from the batteries is transformed into pure sine wave AC for powering your mobile applications.
Standby mode: The unit operates as a battery charger to convert incoming AC power into DC power while continuing to pass the incoming AC power directly to the inverter's output to power any AC loads."
DJ
Lineolated is offline   Reply With Quote
Old 11-13-2014, 09:08 AM   #9
Brucet45410's Avatar
Norfolk , Virginia
Protagonist,
Of the three books you linked to, which would you suggest as most critical for first time RV owner with moderate DIY abilities (me)?
Brucet45410 is offline   Reply With Quote
Old 11-13-2014, 09:13 AM   #10
Originally Posted by Brucet45410 View Post
Protagonist,
The second one:
It provides a good general overview for all manner of troubleshooting and repairs, not just electrical.
WBCCI #1105
TAC LA-4
Old 11-13-2014, 08:31 PM   #11
Glamper1's Avatar
Thank you all I appreciate it.
I took a shower in my driveway today.
Powered by the generator.
That generator makes me nervous.
Nothing blew up so I guess I did it right.
Old 11-13-2014, 08:36 PM   #12
Glamper1's Avatar
Does the main house power switch near side door have to be on when the generator is on?
Old 11-13-2014, 08:38 PM   #13
It has to be on to even start the generator.
WBCCI #1105
TAC LA-4
Old 11-13-2014, 08:41 PM   #14
Glamper1's Avatar
Thank you (again)
Battery converter not charging battery airstreamz Electrical - Systems, Generators, Batteries & Solar 5 09-24-2014 03:55 PM
'02 LY 26' House Batteries not charging kardy Land Yacht/Legacy Motorhomes 13 05-04-2014 11:07 AM
House Battery charging question dgmelp General Motorhome Topics 7 01-12-2012 08:05 PM
Chassis/House Battery Charging 4 Motorhomes Jim Tyrney Airstream Motorhome Forums 41 03-11-2011 06:50 PM
Charging house battery from TV? JoePfznik Electrical - Systems, Generators, Batteries & Solar 2 02-18-2010 09:13 PM
