Old 07-30-2017, 05:17 AM   #1
MOS
2016 28' Flying Cloud
Queensbury , New York
Interstate vs Roadtrek ???
May make the switch from AS trailer to class B MoHo .
We like the Roadtrek CS Adventurous.
Need some input on comparing it with the AS Interstate please
MOS is offline   Reply With Quote
Old 07-30-2017, 05:29 AM   #2
Gainesville , Florida
Put road trek in the search function at the top of the page. Several links.
xrvr is online now   Reply With Quote
Old 07-30-2017, 07:32 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I test-drove a Roadtrek RS Adventurous before I ever saw an Interstate. The CS Adventurous hadn't come out yet, but from what I understand, the CS Adventurous isn't much different except for the wet bath.
As far as driving goes, the Roadtrek had more road noise (not as much floor insulation), plus more creaks and rattles inside. Back then (late 2011), Airstream didn't buy Sprinters with all of the options, and neither did Roadtrek. So the basic Sprinter vans were more-or-less identical, except that Roadtrek was already using the EXT model and Airstream wasn't.
As far as layout goes, Roadtrek had something unique; the four front swivel seats could be converted to two twin beds. The aisle was wider because the wet bath was even narrower— BUT the wet bath had double doors, that opened out to turn the aisle into part of the bathroom to effectively double the size of it, as long as you didn't mind trapping someone in the back end until you were done. As I understand it, the CS Adventurous still has double doors on the wet bath, but they come together at an angle to give more interior volume even when closed, so the shower pan can be larger.
Fit and finish weren't as good on the Roadtrek as on the Interstate. The difference was obvious to even a casual glance. But it was still WAY better than the el-cheapo Winnebago ERA that used vinyl-clad particle board for the cabinetry!
Also, there was more overhead clearance above the driver and front-seat passenger, but at the cost of less storage space above the driver and front-seat passenger.
That's about all I remember about my road-test of the RS Adventurous. Once I saw the Interstate, and took it on a 20-mile test drive, my mind was made up and there was no way I'd have settled for a Roadtrek.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-30-2017, 08:26 AM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
You might also want to take a look at this other Canadian make.
https://leisurevans.com/?_vsrefdom=a...X1cxoCCtrw_wcB
There is also another make called Pleasure way.
I spent quite a lot of time looking at details of Airstream / Roadtrek / Leisure vans / Pleasure way, and thought that if I opted for a class B my first choice would probably be the Leisure Van.
They really look nice - lots of youtube videos on line.
A Roadtrek would be good for us though since we live only an hour from the factory. Also, many of them they are short enough to fit into our driveway without blocking the sidewalk - most of the others are not.
In the end though, I have never been able to convince my wife that we should make the switch from our Classic 30 so i guess it ain't made to be! On the plus side, look at the $$ I'll save! Still would have liked one though!
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-30-2017, 08:50 AM   #5
Denis4x4's Avatar
Durango , Colorado
Retired our Airstream to a riverside guest house and bought a Leisure van for travel. It is the first and only RV we've owned that has had zero defects and quality components. It is built by Mennonites in Canada to very high standards. Interestingly enough, when the popularity of the Leisure van started to soar, the factory refused to as increase production and the wait time to be a factory order can be as much 10 months. Well worth the wait in my estimation after using our for four years.
If you don't go first class, your heirs will!
Denis4x4 is offline   Reply With Quote
Old 07-30-2017, 01:21 PM   #6
I think you're talking about the Agile, built on the 144" wheelbase Sprinter instead of the 170" wheelbase Sprinter. It had one unique feature that its bigger cousins could copy, a slide-out that slid out the rear doors! The rear sofa couldn't be made into a bed until you opened the doors at least 90°, and slid the extension out the back. But when the slide-out was slid in for sofa mode, the van really was agile compared to the 170" wheelbase models.
WBCCI #1105
TAC LA-4
Old 07-30-2017, 01:24 PM   #7
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento , California
We did some research on them and found the roadtrek is a little better layout and has a bathroom you CAN use... but, some have reported that the roadtrek... made in canada is not as good in the warnt'e dept. The owner is not smiling towards the US... and getting service on the RV part is hard find in the states... least as they report a good one that takes care of business... Otherwise dodge or MB seems to take care of the vehicle part... except some have found that the height becomes a problem in the service bays... Oh and one other thing... most have had problems with their on board alternator.... which is nothing more than a large car alternator that they run into a sine inverter... the problem is not with the inverter.. but rather overheating the alternator on the engine... Others seem to think the 600 amp hr ion bats are not worth it... fearing fire as well as the vehicle engine starting on its own without anyone around... Most suggest leaving that defective option (that the manufacture seems to know about ... but keeps putting it out their anyway....) and go with the standard onan gen set mounted under the frame... or use a external one like the honda or yamaha 3KW ...
cheaper as well as easier to service...
Other than they are overpriced... they seem to be a pretty good rig... by themselves... and don't expect to tow anything... or carry a large load.. as the little tires they put on them are just about max'd out... they should have put duals on the rear... but went cheap in that dept also...
As to the AS one... nope ..nope.. and nope... we have heard nothing but bad reports on them... seems AS still hasn't learned how to make a MH... even after all their experance from years before... just too cheap in the materials section... least that is the way others are finding out too...
GM Airstream is offline   Reply With Quote
Old 07-30-2017, 01:49 PM   #8
The E-Trek is a completely different critter
Are you talking about the same Roadtreks? The one I test-drove back in 2011 had duals! And the RS and CS Adventurous models still have duals!
I've had my Airstream Interstate for 5½ years now, and have no particular complaints about fit finish, durability, layout… Otherwise I would have traded it in on something else long ago.
Far from being cheap in the materials department, the Airstream Interstate uses many of the exact same components as other Sprinter-based B-vans, such as the appliances. The only truly unique-to-Airstream bits are the interior furnishings, i.e. the cabinetry, floor, walls, etc. And there, Airstream is very much the best, with their solid wood laminates, Corian countertops, etc.
Fact of life, this is the Airstream Forums. People come here to discuss problems with their Airstreams, including their Airstream Interstates. They don't come here to discuss their problems with Roadtreks, or Winnebago ERAs, or Pleasureways, etc. So you may get a skewed perspective.
And the number of people who come here to compain about their Airstream Interstates are a very tiny fraction of all Interstate owners. And the ones who do complain are the perfectionists who won't settle for second best. Even the best B-van on the market— no matter which one you think is best— is not perfect. There is always room for improvement on any brand and any model, and we all have different ideas of exactly how to improve our beloved B-vans.
WBCCI #1105
TAC LA-4
Old 07-30-2017, 03:48 PM   #9
1991 25' Excella
Santa Ynez , California
Just returned from our local AS dealer Sky River and they had a Roadtrek, Pleasure way and an Interstate next to each other open for viewing. Never setting foot in any one of them before but we were first struck by the compact feel of them with the AI being the slightly more roomy. They all were of high quality fit and finish but liked the AI better than the other two, can't say what models we were looking at but all we based on the same Mercedes platform from outside appearance. They also had a Tommy Bahama open with a tag of $181,900.
Alan
AlinCal is offline   Reply With Quote
Old 07-30-2017, 09:11 PM   #10
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I think you will find the forum a bit biased toward the Interstates. I've had mine for over four years and 90,000 miles. It has been a good choice for me, but I do all my own repair and maintenance on the Airstream installed systems. The style and finish of the interior structures are some of the best I saw when buying in 2012. I think the materials used by Airstream are top quality, but their workmanship isn't top quality. The electrics are not up to their competitors, which is why I modified mine with more solar and more batteries plus a 2000 watt inverter.
I recommend you drive both and draw some of your own views on each. Also go over to the Class B forum and read some unfiltered comments about Roadtreks and other B-vans.
http://www.classbforum.com/forums
Don't rely on the major Roadtreking Facebook and web pages run by Mike Wendland. Those sites are heavily biased and don't allow people to complain much about their Roadtreks. Mike is compensated by Roadtrek for his positive blog and posts.
It was suggested in this thread to also look at Leisure Travel Vans (LTV) - they have good quality but no longer make B-vans. For last few years they have only made Class-C motorhomes. A good choice if you want more space, but then it's a larger vehicle that has some limitations compared to a B-van.
- - Mike
Old 07-31-2017, 08:29 AM   #11
2017 Interstate Grand Tour Ext
Houston , Texas
Here is another source of cross-brand Sprinter van information:
https://sprinter-source.com/forum/forumdisplay.php?f=57
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
TayaraTravel is offline   Reply With Quote
Old 07-31-2017, 12:01 PM   #12
2018 30' Classic
Newport , Pennsylvania
Well I looked sat the Interstate and the Road Trek and bought a Winnebago View. I like real beds and a dry bath room
I do like the 33FB Classic
Choices we all have them
Earl
EarlM is offline   Reply With Quote
Old 07-31-2017, 12:19 PM   #13
Being an apartment-dweller and not wanting to rent a separate place to store my motorhome, a B-van was essential. If I was a homeowner and had a place on my own property to store a motorhome, I might have made the same choice you did, to go with a small class C instead.
From day one I took full advantage of the Interstate's "stealth" characteristics. When I showed my landlady the brochure for the Interstate, she said, "Oh, it's a Mercedes! That's fine. I thought you wanted to park one of those ugly motorhomes here. Go right ahead!"
WBCCI #1105
TAC LA-4
Old 07-31-2017, 12:28 PM   #14
2018 30' Classic
My View is a Mercedes also
enjoy
Glad to see you back posting
Airstream Interstate vs. Roadtrek matrixdutch Sprinter and B-van Forum 35 10-22-2013 03:38 PM
2008 roadtrek roadtrek 170 popular era airstream pleasureway eBay Watch Airstreams on eBay 0 06-21-2013 11:50 AM
Airstream Parkway Diesel Sprinter Interstate Roadtrek eBay Watch Airstreams on eBay 0 10-15-2009 10:40 PM
Airstream Parkway Diesel Sprinter Interstate Roadtrek eBay Watch Airstreams on eBay 0 10-04-2009 09:00 PM
Airstream Parkway Diesel Sprinter Interstate Roadtrek eBay Watch Airstreams on eBay 0 09-26-2009 10:40 PM
