Old 09-28-2016, 09:17 AM   #15
Kwils25's Avatar
2014 Interstate Ext. Coach
Taylor Ridge , Illinois
Keep in mind that you need to be plugged in to shore power in order to use the tank heaters. If not, your house batteries will be drained very quickly.
Kwils25 is offline   Reply With Quote
Old 09-28-2016, 02:17 PM   #16
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by Amg View Post
Are you saying the toilet can be used even with solids so long as all the plumbing after the black tank has antifreeze. If so then it can be used then dumped and you would only have to put in more antifreeze into the plumbing after the black tank
Yes since the black tank is inside the AI, the only thing exposed to freezing temps is the piping, dump valve, macertor, and the hose. That assumes the interior is maintained above freezing.
Old 09-28-2016, 09:10 PM   #17
Trying to Retire
MILATV's Avatar
Decatur , Illinois
I used mine two winters on trips. Blew out lines with air, flushed toilet & sink drains with about 1/2 gal antifreeze, then put emptied tanks and flushed Mercator and line by emptying tanks and pouring antifreeze in black tank until pink froth came out of Mercator line.
Used toilet and flushed liberally with antifreeze. It was in teens & 20s and I didn't have any issues.
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Composting toilet: winter use? Joyfulgirl Sinks, Showers & Toilets 5 08-27-2011 08:45 PM
keeping MH avail for use all winter ducatist2 Winter Living 5 02-13-2011 01:36 PM
Need new LP heat source for short bursts of winter use pyrenees Winter Living 12 01-04-2011 08:41 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
Winter use ???? donnall General Motorhome Topics 3 01-08-2005 07:33 AM
