Old 07-17-2013, 07:55 AM   #1
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Interstate Owner's Manual Errors
Over the past year and a half of Airstream Interstate ownership, I've discovered several errors in the owner's manual. I don't always know what the correct text should be, though.
Here's an important one for me, since I pull a toad. On page B-7:
The towing vehicle’s braking system is rated for operation at GVWR (GROSS VEHICLE WEIGHT RATING), NOT at the GCWR (GROSS COMBINED WEIGHT RATING). A separate functioning brake system is required for any towed vehicles or trailers weighing more than 1000 lbs. (450 kg) when fully loaded.
This conflicts with the Sprinter Owner's Manual, which doesn't list any such 1000-pound limitiation. Not sure where this came from; maybe cut from a different Airstream motorhome manual altogether and pasted into the Interstate manual.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-17-2013, 08:00 AM   #2
Another error, from Page B-1:
The Cargo Carrying capacity tag shown below is installed on every motorhome and can be found on the inside of the screen door on your vehicle.
What screen door? And I have yet to find a capacity plate made by Airstream on mine; all it's got are the standard DOT capacity plates on the driver's seap pedestal and the driver's door post.
WBCCI #1105
TAC LA-4
Old 07-17-2013, 08:07 AM   #3
Gainesville , Florida
The Interstate in effect is a fully loaded truck. AS obviously feels the tow rating must be reduced. The Interstate is near its lad capacity with cargo added. The brakes are designed to stop the vehicle per a max load. AS obviously feels for safety the addition of a thousand pound more to the weight the Interstate must stop is the max. If I remember correctly most Sptinters are not used at nearly the weight of an Interstate, and if they are by commercial users, trailer brakes are installed. Just my thoughts, jim
Old 07-17-2013, 08:07 AM   #4
And from page C-1 (the Forum doesn't handle column formatting well, so it may not come out quite right):
Sprinter Van Serviced by Sprinter or its suppliers.
In the United States: In Canada:
Chrysler Motors Company LLC Chrysler Canada, Inc.
Customer Center Customer Center
PO Box 21-8004 PO Box 1621
Auburn Hills, MI. 48321-8004 Windsor, Ontario N9A-4H6
Ph.: 800-992-1997 Ph.: 800 465-2001
This went out-of-date for the 2011 Sprinter model year (2012 Interstates) when Mercedes Benz took over the marque from Chrysler. Yet it still appears in the 2012 manual, at least. What does it say in later editions?
WBCCI #1105
TAC LA-4
Old 07-17-2013, 08:13 AM   #5
Page C-10:
Front Wheel Simulators
The wheel simulators are installed by Airstream.
Not on mine. Mine has the Alcoa aluminum wheels, not simulators over steel wheels. But I suppose it might be true for some.
WBCCI #1105
TAC LA-4
Old 07-17-2013, 08:15 AM   #6
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
It's fixed in the 2013 manual:
Customer Assistance Center
Three Mercedes Drive
Montvale, New Jersey 07645-0350
1-877-762-8267
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 07-17-2013, 08:17 AM   #7
Page D-14:
Your LP gas detector is wired directly to your vehicle battery and incorporates a 1-amp in-line fuse. When the device is operating normally the green LED will be lit.
If there's an in-line fuse, I sure can't find it. Maybe it's tucked behind the wardrobe closet so I'd have to dismantle the interior to get to it?
WBCCI #1105
TAC LA-4
Old 07-17-2013, 08:26 AM   #8
Page E-8:
Awning Motor Pre-wire: Units equipped with the standard manual awning are prewired for the addition of a motor to convert to power operation. Four wires are located inside the removable rear panel of the rear roof locker. Those four wires run through the body to under the passenger cab seat where two other wires are run from the chassis fuse panel under the driver’s seat. The switch can be mounted inside the compartment on the side of the passenger seat.
Don't know about earlier model years, but for 2012, the awning comes standard as an electric model, not manual. The backup manual crank is so short that you can't use it without a ladder.
I seem to remember that the electric awning is wired to the chassis battery, not the house batteries, but my memory on that may be faulty. If so, it would have been nice of Airstream to say so.
WBCCI #1105
TAC LA-4
Old 07-17-2013, 08:29 AM   #9
Page F-2:
The table pedestal is stored in back of the rear center sofa on the rear lounge model accessed by opening the two rear cargo doors and inside the roadside wardrobe in the twin bed model.
This error is really minor, but on my 2012 sofa/lounge model, the pedestal is stored in the rear overhead locker, not behind the seat. Much easier to access.
WBCCI #1105
TAC LA-4
Old 07-17-2013, 08:33 AM   #10
Page F-3:
Galley Sink/Faucet:
SMEV
Mine's a Dometic, but looks and works the same as described. Another minor error. But it sure would have been nice if the manual told people to make sure the faucet lever is in the "Cold" position before closing the sink lid. In the "hot" position the lid will open the faucet.
WBCCI #1105
TAC LA-4
Old 07-17-2013, 08:40 AM   #11
Page F-8:
All interior lights are sealed LED requiring fixture replacement if a light burns out or malfuctions. The exterior lights are the same except for the porch light which uses a B7038 bulb replacement.
There is only one exterior light, the porch light. There are no exterior lights that require fixture replacement if a bulb burns out. (Pity. A light over on the driver's side by the macerator pump controls would have been nice for those of us who like to be on the road early.)
All of the Sprinter-standard lights use replaceable incandescent bulbs, but you might be able to find LED replacements for the taillight bulbs.
WBCCI #1105
TAC LA-4
Old 07-17-2013, 08:44 AM   #12
Page G-1:
The switch rotates ¼ turn. This switch should be turned off during the filling of the LP tank. NOTE: The electric gas shut-off solenoid closes automatically when 12-volt power is disconnected. It will reopen when power is restored.
The switch on mine doesn't rotate; it's a toggle switch, up=open, down=closed.
Reports differ on whether the solenoid actually closes when the house battery disconnect is switched off, too. Verify for yourself whether that's true on your unit.
WBCCI #1105
TAC LA-4
Old 07-17-2013, 08:50 AM   #13
Page G-4 has a significant omission:
WATER SYSTEM - SELF-CONTAINED
There is no mention that the water pump is not as self-priming as it's supposed to be. Information on how to prime the pump would have been useful.
WBCCI #1105
TAC LA-4
Old 07-17-2013, 09:02 AM   #14
Page H-12:
Battery Disconnect Switch
The diagrams are wrong. On mine, switch horizontal=on, vertical=off. The diagrams need to be rotated 90° counterclockwise in order to be accurate. Also, the knob is not removable.
WBCCI #1105
TAC LA-4
