Old 04-14-2015, 12:57 AM   #491
2012 Interstate Coach
Palo Alto , California
Thanks Protagonist. As always, you're a wealth of information. I will try again using your tips.
roadmama is offline   Reply With Quote
Old 04-14-2015, 10:31 PM   #492
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by gambita View Post
Attachment 236146
Installed 24" LED lightbar below the front grill
Some food for thought about blocking the front grill from the Sprinter Body Builders manual...
Old 04-15-2015, 09:29 AM   #493
SprinterStore.com sells an oversized transmission cooler that mounts under the bumper that looks really nice but I don't think it's necessary in this case.
Vehicles are designed for worst case driving conditions without encountering any mechanical failures or thermal fluid breakdown. For a Sprinter that was defined as driving at max gross weight with a trailer up a continous grade [10%] in 1st gear at ~15 mph. If you're planning to drive Pike's Peak highway you can relax, it has an average grade of only 6.7%.
LB_3 is offline   Reply With Quote
Old 04-15-2015, 11:35 AM   #494
Fulton , Maryland
Like many vehicles today the Sprinter has a transmission cooler built into bottom of radiator - it also acts as a heater to get the transmission quickly up to operating temperature in cold weather.
- - Mike
Old 04-27-2015, 04:24 PM   #495
Teamaron's Avatar
2014 Interstate Ext. Coach
Boca Raton , Florida
Today's mod
Added felt pad stick on at seatbelt area on pillars to avoid smacking and scratching plastic.
Name:	ImageUploadedByAirstream Forums1430169878.437049.jpg
Teamaron is offline   Reply With Quote
Old 05-03-2015, 12:28 PM   #496
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Added Programmable LED lights under awning so I can turn up my techno and have Rave under the awning.
Name:	ImageUploadedByAirstream Forums1430674019.130149.jpg
ID:	237644Click image for larger version
Name:	ImageUploadedByAirstream Forums1430674035.208979.jpg
ID:	237645Click image for larger version
Name:	ImageUploadedByAirstream Forums1430674048.910605.jpg
Makes it easy to find the camper in large parking lots also (in addition to being 4' taller than all the other vehicles in the lot). Lol.
(double side taped to mounting bracket, perfect fit; will run wire through roof into front storage area once I decide they stay; for now just have running through slider opening)
Mike
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 05-04-2015, 02:40 PM   #497
weirdstuff's Avatar
2018 23' International
San Diego , California
milatv...the lights look cool. Are they HUE? I just found out about the HUE lights, and want to put some of those in my house.
weirdstuff is offline   Reply With Quote
Old 05-04-2015, 02:57 PM   #498
Figment of My Imagination
Protagonist's Avatar
Why not run them in through the existing "patio" light? There's already a penetration there.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-04-2015, 04:28 PM   #499
Trying to Retire
MILATV's Avatar
Decatur , Illinois
These are cheapo's just playing around (which is why I didn't drill) was going to run wires in back through the holes from awning into cabinet originally; but figured I'd be more likely to turn them on in the front so that is the plan).
http://www.amazon.com/SUPERNIGHT%C2%..._bxgy_hi_img_z
Protag; the porch light sets too low; I'd still end up with surface mounted wires to get to it. I'm looking at mounting a FLIR camera on the roof. I do some vehicle testing/training with the van; and FLIR IR/THERMAL camera is something I have on my ATV Side by Sides, and am looking at mounting on the VAN for the control center so there will need to be a wire in for that.
Mike
Old 05-10-2015, 04:09 PM   #500
2015 Interstate Ext. Coach
Tulsa , Oklahoma
Interesting. What FLIR unit have you used? What are you thinking about for Interestate?
Bobsprinter is offline   Reply With Quote
Old 05-10-2015, 10:11 PM   #501
pennstate95's Avatar
Falls Church , Virginia
Although the awning lights looks nice. My suggestion is to run the lights underneath the Interstate like they do with the Hondas. Also, put some red leds in the tailpipe and program it to light up red every time you hit the gas. How cool would that be. =)
pennstate95 is offline   Reply With Quote
Old 05-13-2015, 07:05 PM   #502
Flemington , New Jersey
Couple of my improvements:
Progressive Industries surge suppressor.
Name:	ImageUploadedByAirstream Forums1431561579.121060.jpg
Roadtrek TV covers.
Name:	ImageUploadedByAirstream Forums1431561633.458615.jpg
Had a leaking ceiling vent. Had the manual maxxfan replaced with the remote control full featured one. Click image for larger version
Name:	ImageUploadedByAirstream Forums1431561779.797432.jpg
Outside van window shades and ventshade wind deflectors. Click image for larger version
Name:	ImageUploadedByAirstream Forums1431561915.377626.jpg
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 05-13-2015, 07:22 PM   #503
UKDUDE's Avatar
Sedona , Arizona
Attachment 238371
Roadtrek TV covers.
Attachment 238372
Had a leaking ceiling vent. Had the manual maxxfan replaced with the remote control full featured one. Attachment 238373
Outside van window shades and ventshade wind deflectors. Attachment 238374
The OutSide Van shades are very efficient but tricky to put up, especially the side shades, and my wife is quite neurotic about any little gaps around them. Have you found a way to get them straight and tight first time?
Old 05-13-2015, 08:19 PM   #504
Attach some small suction cups to the cloth tabs. Stick the suction cups to the outside of the glass, and let them hold the tabs in place while you raise the windows.
WBCCI #1105
TAC LA-4
