Old 08-23-2013, 11:03 AM   #281
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by doug&maggie View Post
Hmmmm, that's not what ours did.
You may have a different kind of problem.
I'm sure I do. I have all kinds of problems. Just ask the voices in my head, they'll tell you!
But in this case, even though it's not the same latch problem it's still a latch problem. Close enough to note the coincidence, at least.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-23-2013, 11:12 AM   #282
jquayle's Avatar
2013 Interstate Coach
Napa , California
I've had a problem with the sliding door since I bought mine just over a year ago. You've always had to REALLY slam the door to get it closed. Dealer blew it off when I brought it in for service saying that was normal. Yesterday when I was sitting in the van waiting for my wife to finish getting her nails done, I happen to be looking at the trim and noticed that the black trim around the slider wasn't even all along the edge. Opening the door and looking at it closer I found the rubber molding had come out of its track and was basically smashed to the outside of the door. All the extra rubber sticking out is what was making the door hard to close. I was able to mostly put it back to normal, but I'm going to insist mbz replace it since it's actually 2 separate pieces and held in place with some double sided. (Which is all mangled)
jquayle is offline   Reply With Quote
Old 08-23-2013, 11:33 AM   #283
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by Protagonist View Post
Your latch broke? Funny you should say that. In the past couple of weeks, I've noticed that, if I slide the side door ALL the way open, and try to close it from inside, it gets stuck back there. Opens fine from inside or outside, and closes fine from outside. Which tells the that somewhere between the button at the top of the inside handle and the hold-open latch, there's a disconnect.
Hopefully there's a linkage adjustment that will correct this. May require judicious bending or duct tape.
Old 08-24-2013, 11:53 PM   #284
Palo Alto , California
I may have said this before— apologies if I have— but the one modification that I'd like to see above all others is sliding steps for the front doors like the one for the sliding side door. Especially if they could offer a retrofit kit for older Interstates so I wouldn't have to trade mine in to get them. Those molded-in steps are ankle-breakers!
Totally agree. I also feel like I'm tripping over myself getting in and out of the driver's seat.
roadmama is offline   Reply With Quote
Old 08-25-2013, 06:42 PM   #285
Boxster1971's Avatar
Fulton , Maryland
Extended Lounge Broken Bed Expander Fix
Several months ago the fold down bed expanders on my EXT Lounge model broke. The screws in hinges of these fold down cushions pulled out from dropping in without the center brace pulled out.
Yesterday I pulled the folding cushions completely out of the van and opened the zippered end. The screws were inserted into the end grain of the chip board base that had split. There is no way these will hold up under normal use. So I glued up the cracked/split ends of the base board and added new stronger hinges to hold the cushions. Fortunately I had some aluminum piano hinges that were perfect for the job. Picture attached.
Name:	Rear Bed Extension Fix.jpg
- - Mike
Old 08-25-2013, 07:29 PM   #286
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Good work Mike. But chipboard? I thought plywood was used everywhere. With all the issues I've had on my new Interstate, I'm losing faith in Airstream's quality.
Peter
Old 08-25-2013, 08:04 PM   #287
73shark's Avatar
Peter
+1 on that.
Old 09-10-2013, 04:11 PM   #288
Trying to Retire
MILATV's Avatar
Decatur , Illinois
After having stuff fall out on me when opening rear doors I added eye hooks for bungee cords. The EXT has around 8-10" behind the bed (even with bolsters down) so I like to leave table, grill, chairs in the camper.
Just pulled out the factory screw and replaced with eye hooks.
MUCH BETTER! May replace with tailgate net when I get back to home base.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 09-10-2013, 04:25 PM   #289
73shark's Avatar
I guess that's one of the drawbacks to having that extra space back there.
Old 09-10-2013, 04:36 PM   #290
Trying to Retire
MILATV's Avatar
Decatur , Illinois
I assure you - there are NO drawbacks to space in an AS!
Mike
Old 09-10-2013, 08:39 PM   #291
Fulton , Maryland
Non-skid tape on rear bumper
During our long summer trip the rear bumper got some bad scratches from the load I had on rear carrier. I had planned to add some non-skid safety tape to the bumper anyway to make it safer climbing in and out of rear area. It came out even better than planned. Got a 12 foot roll of 4" tape off amazon as the local Lowes/HD only had 25 foot rolls - a lot more than I needed.
- - Mike
Old 09-10-2013, 08:56 PM   #292
Trying to Retire
MILATV's Avatar
Decatur , Illinois
I love it, I have 2-3 cuts in mine already at 3,000 miles. I'll have the tape waiting for me when I get home!
Mike
Old 09-25-2013, 11:56 AM   #293
Lancaster , Pennsylvania
Added quick valve for Fresh water
Name:	Fresh Water VAlve.jpg
fb47243 is offline   Reply With Quote
Old 09-26-2013, 04:59 PM   #294
norman , Oklahoma
I like it. Where did you get that valve? Got a part number?
russ240 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
