Old 07-08-2013, 03:28 PM   #225
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Teamaron View Post
Simple and easy upgrade to generator exhaust pipe:
Attachment 190516
A little light sanding and can of gloss black paint!
High-temperature paint? Like that used on steel engine blocks?
If not, expect the paint to cook off over time.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-08-2013, 05:47 PM   #226
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Or even better would be VHT exhaust pipe paint.
I still like my DIY chrome tip.
Old 07-08-2013, 05:52 PM   #227
Teamaron's Avatar
2014 Interstate Ext. Coach
Boca Raton , Florida
Post picture please
Teamaron is offline   Reply With Quote
Old 07-08-2013, 05:56 PM   #228
Teamaron's Avatar
Your probably correct, but I thought for a few dollars it gets rid of the unsightly pipe just sitting there and makes it less noticeable.
If it does 'burn' off I can always touch up. Certainly a lot of paint left in the can. But I notice that the exhaust pipe never gets that hot. It is quite a but away from generator. And I only painted exposed part beyond body.
Old 07-08-2013, 06:12 PM   #229
73shark's Avatar
Post picture please
It's just a lavatory sink chrome plated drain pipe that I cut off and drilled and tapped for two screws to clamp on the pipe. Most hardware stores carry them.
Old 07-08-2013, 06:54 PM   #230
2013 Interstate Coach
I put my Fiamma privacy room for F65S this weekend. I used the video and manual together to help figure out. Took about 3 hrs for me to do in blazing Texas heat so probably 2 hours without breaks and cooler weather. The process going forward expecting half hour or so to put up and take down and stow.
I absolutely love it, with two cots can sleep two people easily with room to move around, see outside TV etc.
I also put up an outside shower that is very cool as well.
Looking forward to using this on extended stays.
eliasurbina is offline   Reply With Quote
Old 07-08-2013, 10:14 PM   #231
Here are pics
Outside Gear Packed
Outside Shower very cool
Outside Look at Fiamma Privacy Room
Inside Look at Fiamma Privacy Room
Old 07-09-2013, 03:36 AM   #232
Using a stepladder, it now takes me about 45 minutes to put up my Privacy Room, solo. For two people it could be done in half an hour or so with practice.
Side note, the "fast clip" rails that hold up the side walls can be used by themselves, to keep the awning from flapping so much when the wind picks up, and can be removed quickly when the wind picks up enough to require the awning be retracted.
WBCCI #1105
TAC LA-4
Old 07-09-2013, 06:04 AM   #233
Yes, you will need a ladder. I have a 4' ladder that folds into 53" long by 4" weighs about 17lbs.
Old 07-09-2013, 06:23 AM   #234
This one? This is what I use. It may not be the best ladder around, but it's the most stepladder I can carry in my Interstate behind the rear seat.
5' Compact Folding Step Ladder - GP Logistics SLD-S5 - Ladders - Camping World
WBCCI #1105
TAC LA-4
Old 07-09-2013, 06:26 AM   #235
Yes that is it with red top to hold
Old 07-10-2013, 08:08 PM   #236
73shark's Avatar
Post picture please
Here's a couple of the tip plus the Magnaflow tip on the main exhaust.
Name:	RV gen exhaust tip 2.jpg
ID:	190672   Click image for larger version
Name:	RV generator exhaust tip 1.jpg
Old 07-27-2013, 10:07 PM   #237
David M's Avatar
Orange County , California
Originally Posted by gmillerok1 View Post
That someone was me, and yes, I did go back later and put the original switch back so both switches have to be "On" for the valve to open. You are welcome. I am glad you found the write-up useful.
I have pretty much modified, repaired, replaced, or inspected about everything Airstream installed in the chassis and have a good understanding of their components. Some of these were by necessity, some by curiosity, and some for no reason at all.
Gerald
I just did the propane switch mod. I want to thank Gerald for posting the instructions, without which I wouldn't have even attempted doing it myself. It turned out great! Thanks Gerald!
David M is offline   Reply With Quote
Old 07-28-2013, 08:16 AM   #238
2010 22' Interstate
Vincennes , Indiana
I found an interesting ladder this weekend while getting paint supplies at Sherwin Williams.
Xtend & ClimbŪ 12-1/2' Aluminum Telescoping Extension Ladder - Type II - Homeowners - Sherwin-Williams
There are various sizes and they fold onto about a ten to twelve inch stack, then fold out to full height. I think they would store well.
Phil
aa9zz is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
InterBlog, Tronadora
