07-07-2013, 06:27 PM
#221
2013 Interstate Coach
Orange County
Originally Posted by jquayle
I'm embarrassed it took me this long, but I finally got this done and it worked perfectly. Here is the stock configuration. I've shown which wire needs to be removed to prevent the step from retracting with the engine running.
Thanks again for the help Russ!
Oh, and for anyone else thinking of performing this mod, use a small jeweler's screwdriver to release the pin as pictured:
07-07-2013, 07:04 PM
#222
Napa
That's funny. I used that exact tool and thought about taking a picture but forgot.
07-08-2013, 09:58 AM
#223
Orange County
Great minds think alike
07-08-2013, 02:47 PM
#224
2014 Interstate Ext. Coach
Boca Raton
Simple and easy upgrade to generator exhaust pipe:
A little light sanding and can of gloss black paint!
07-08-2013, 03:28 PM
#225
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Attachment 190516
High-temperature paint? Like that used on steel engine blocks?
If not, expect the paint to cook off over time.
07-08-2013, 05:47 PM
#226
2011 Interstate Coach
Overland Park
, Kansas
Or even better would be VHT exhaust pipe paint.
I still like my DIY chrome tip.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
07-08-2013, 05:52 PM
#227
Boca Raton
Post picture please
07-08-2013, 05:56 PM
#228
Boca Raton
Your probably correct, but I thought for a few dollars it gets rid of the unsightly pipe just sitting there and makes it less noticeable.
If it does 'burn' off I can always touch up. Certainly a lot of paint left in the can. But I notice that the exhaust pipe never gets that hot. It is quite a but away from generator. And I only painted exposed part beyond body.
07-08-2013, 06:12 PM
#229
Overland Park
, Kansas
Post picture please
It's just a lavatory sink chrome plated drain pipe that I cut off and drilled and tapped for two screws to clamp on the pipe. Most hardware stores carry them.
07-08-2013, 06:54 PM
#230
Austin
I put my Fiamma privacy room for F65S this weekend. I used the video and manual together to help figure out. Took about 3 hrs for me to do in blazing Texas heat so probably 2 hours without breaks and cooler weather. The process going forward expecting half hour or so to put up and take down and stow.
I absolutely love it, with two cots can sleep two people easily with room to move around, see outside TV etc.
I also put up an outside shower that is very cool as well.
Looking forward to using this on extended stays.
07-08-2013, 10:14 PM
#231
Austin
Here are pics
Outside Gear Packed
Outside Shower very cool
Outside Look at Fiamma Privacy Room
Inside Look at Fiamma Privacy Room
07-09-2013, 03:36 AM
#232
From All Over
Using a stepladder, it now takes me about 45 minutes to put up my Privacy Room, solo. For two people it could be done in half an hour or so with practice.
Side note, the "fast clip" rails that hold up the side walls can be used by themselves, to keep the awning from flapping so much when the wind picks up, and can be removed quickly when the wind picks up enough to require the awning be retracted.
07-09-2013, 06:04 AM
#233
Austin
Yes, you will need a ladder. I have a 4' ladder that folds into 53" long by 4" weighs about 17lbs.
07-09-2013, 06:23 AM
#234
From All Over
This one? This is what I use. It may not be the best ladder around, but it's the most stepladder I can carry in my Interstate behind the rear seat.
5' Compact Folding Step Ladder - GP Logistics SLD-S5 - Ladders - Camping World
07-09-2013, 06:26 AM
#235
Austin
Yes that is it with red top to hold
07-10-2013, 08:08 PM
#236
Overland Park
, Kansas
Post picture please
Here's a couple of the tip plus the Magnaflow tip on the main exhaust.
07-27-2013, 10:07 PM
#237
Orange County
Originally Posted by gmillerok1
That someone was me, and yes, I did go back later and put the original switch back so both switches have to be "On" for the valve to open. You are welcome. I am glad you found the write-up useful.
I have pretty much modified, repaired, replaced, or inspected about everything Airstream installed in the chassis and have a good understanding of their components. Some of these were by necessity, some by curiosity, and some for no reason at all.
Gerald
I just did the propane switch mod. I want to thank Gerald for posting the instructions, without which I wouldn't have even attempted doing it myself. It turned out great! Thanks Gerald!
07-28-2013, 08:16 AM
#238
2010 22' Interstate
Vincennes
, Indiana
I found an interesting ladder this weekend while getting paint supplies at Sherwin Williams.
Xtend & Climb® 12-1/2' Aluminum Telescoping Extension Ladder - Type II - Homeowners - Sherwin-Williams
There are various sizes and they fold onto about a ten to twelve inch stack, then fold out to full height. I think they would store well.
Phil
07-28-2013, 08:18 AM
#239
Trying to Retire
Decatur
USB Relocate from Glove box
I moved the USB/iPhone cables from the glove box to the compartment over the radio (2013 Interstate EXT). Popped radio cover off; removed four screws to pull Kenwood out; dremmeled hole large enough for USB cable in corner closest to driver; and pulled cables through.
Now the glovebox can store my front privacy screen.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
07-29-2013, 09:11 PM
#240
dallas
Hi, your outside shower looks awesome! Where did you get it? Thanks!
