Old 08-10-2015, 08:15 AM   #1
2009 22' Interstate
Boylston , Massachusetts
Interstate Microwave/Convection
I have a 2009 Interstate. The Apollo micro/oven unit is dead. I believe Airstream now uses a Sharp unit-- anyone know the model number?
sneebot is offline   Reply With Quote
Old 08-10-2015, 09:02 AM   #2
2009 22' Interstate
It looks like in 2013/14 Airstream used a Cuisinart CMW-200-- does anyone know if this was the standard CMW-200 or if any extra vent fans were used?
Old 08-10-2015, 09:13 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You can get both the Apollo and the Cuisinart at Amazon.
http://www.amazon.com/s/ref=nb_sb_ss...en%2Caps%2C166
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-10-2015, 09:23 AM   #4
2009 22' Interstate
I'd rather go with the Cuisinart after reading reviews of the Apollo. However, Cuisinart instructions supposedly call out 12" clearance above the oven-- so I was wondering if AS used additional venting/ fan with this unit.
Old 08-10-2015, 12:19 PM   #5
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
I'm on my third Cuisinart, for what it's worth.
Old 08-10-2015, 12:37 PM   #6
Do they wear out that quickly?
WBCCI #1105
TAC LA-4
Old 08-10-2015, 12:48 PM   #7
2009 22' Interstate
Ouch.
Is that the Cuisinart CMW-200?
If so did Airstream add any additional venting/ fan to the unit or do you just buy a off the shelf unit to replace the units that fail?
What has been going wrong with the units that have failed?
Old 08-10-2015, 03:04 PM   #8
UKDUDE's Avatar
Sedona , Arizona
First one would run for 3 minutes and then cut out. The second one had a loose part inside the motor that rattled badly on a smooth road above 5mph.
Both replaced under warranty.
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 6 02-23-2016 10:58 PM
Swap stove for convection microwave? cosmotini Stoves, Ovens & Microwaves 13 01-21-2015 09:02 AM
Anybody replace their microwave to convection microwave in a 16 sport scamp 2005 and newer - Bambi all models 0 07-10-2014 04:34 AM
Inverter sizing for factory convection/microwave oven? myoung Electrical - Systems, Generators, Batteries & Solar 11 10-03-2005 07:24 PM
Stove.. replace with convection microwave? Happycampers Stoves, Ovens & Microwaves 9 08-22-2003 06:06 AM
