08-14-2023, 06:10 PM
#621
diesel maniac
Airstream - Other
Tucson
, AZ
As promised here's my current setup and why I did it this way, although I am still tempted by that big Sprinter kit. I'm in charge of 5 vehicles, and 3 of those vehicles need some sort of tool kit when traveling. So the tool roll is both S.A.E. and Metric and goes along in each of those three vehicles including the Sprinter, although I don't need the S.A.E. on the Sprinter unless towing the Jeep so theoretically I could remove the S.A.E. stuff to save weight when not towing.
Then, in addition to the tool roll, I have a few special tools specific to each vehicle which remain in those vehicles at all times, so between the tool roll and the specialty tools I can handle most repairs for each vehicle. The one thing that gets transferred around is a big torque wrench for the wheels but the correct socket for each vehicle stays with that vehicle. The Sprinter by far has the most specialty tools like E Torx, ratcheting box wrenches, and Torx screwdrivers (I don't like the little bits that fit one handle, have dropped and lost way too many of those), in addition to a few household tools and electrical stuff.
The tool roll is easy enough to toss in each vehicle and the wrench rolls along with the socket trays keep everything well organized, although I just noticed today a couple of the numbers came off the socket trays. These particular socket trays hold the sockets in place by twisting and they don't fall out.
The Sprinter kit looks like a great idea for those who want a tool set to do just about anything both on the road and at home. I leave stuff like brake tools, oil change stuff and anything for major work at home because I'm not going to be doing any of that stuff on the road.
Just another idea. Your mileage may vary.
Brian
08-15-2023, 02:04 PM
#622
2024 Interstate 19
Fulton
, Maryland
ITSNO60 - nice tool rolls! I thought of those too, as an option, since the soft sided rolls back easily.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
08-19-2023, 03:05 PM
#623
League City
Yesterday I introduced my Interstate to a curious client as “My nine thousand pound wallet-eater.” I had driven it to a work meeting on the other side of Houston to give it some exercise (because one can go to a “work meeting on the other side of Houston” and easily drive 100 miles… here is a scaled outline of the state of Connecticut overlain on a map of the Houston metro area).
Today in wallet-snacking, I am no expert, but this serpentine belt looks awfully bad for the 40,000 miles that it is SUPPOSED to have on it. It’s a $30 item that was SUPPOSED to have been replaced in 2019 when I had a new long block put in. But now I wonder if what I was told had been factual, and my bad for not automatically engaging the process of “trust but verify”.
^^ ***God give me patience and stamina both.***
At any rate, here’s the upside to alternator #3 that mysteriously burned out with just 40,000 miles on it. My husband noticed this belt condition when he installed the new alternator and he is replacing it today, along with the belt tensioner because that is presumably 17 years old as well at this point.
EDIT: For non-technical readers, the belt WITHOUT all the little cracks in its ribbing is the new one.
08-31-2023, 04:09 PM
#624
Here and There
, West Coast
Here are some of our recent adds and fixes:
2021 AI-19 on 2020, 2500 - MBUX radio sounded terrible! Like really terrible! A wire harness MB used was made up incorrectly causing audio to go to in dash center tweet speaker. Door speakers were so quiet they could not be heard. Result was a tinny screech quality. Center of dash is a small dual coil single cone speaker. Corrected the two pair (4 wire) connections and WOW, what a difference. Apparently this is an issue for a large number of vehicles.
Added a smaller wand and a shut off to the wet bath faucet. Now can set the water temperature with the faucet handle and then start or stop the water flow easily. Additionally, set the main water temperature mixer valve to allow 118° hot water per the spec. With the original setting the valve was temperamental (forgive the pun) and hot water would disappear but seems to be settled in now.
Added a suction cup caddy in the wet bath and removed the pump soap dispenser provided by AS. The same company selling the caddy also sells hooks with suction cups. Purchased a set of the hooks and then reappropriated a suction cup to the caddy. This removed the potential to make vibration noise when driving and possible failure to stay in place.
Added the teak wet bath floor mat.
Added a blackout curtain right behind the cab seats. Can put it up quickly and store it easily by rolling it up and placing it on the cab shelf added a while back. Quick privacy in the back part leaving full view out the windows in the cab.
Added a puck light to the cubby under the TV.
Replaced the pantry slide out 5# latch with a 10#.
09-01-2023, 09:18 PM
#625
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Please do share details on the wet bath faucet improvements. Did you replace the actual faucet? If so, with what did you replace it and how difficult was the swap?
09-01-2023, 10:40 PM
#626
Here and There
, West Coast
Here are Amazon links
Shut off
https://www.amazon.com/dp/B00VCL5DRG...t_details&th=1
Wand
https://www.amazon.com/dp/B08BCQ3BFS...roduct_details
The new wand will come with a bunch of adapter parts and a hose. I left those in the box and used only the wand. I put the shut off valve on the new wand. I then replaced the original wand with the new one. The faucet is still the original. I am searching for a replacement to the lever handle. I would like to find a ball or at least a shorter handle. Using the original hose made it a quick and easy project. The new wand rests easily in the faucet body and reaches the wall hook just like the original. I used a little bit of the provided tape on the threads. Doesn't look bad and works well. The wand will provide either a straight stream or spray.
09-02-2023, 09:00 AM
#627
Green Cove Springs
Sounds pretty cool, ordered for our van. Let us know if you find an easy replacement for the faucet handle as well! Thanks.
09-02-2023, 03:43 PM
#628
2017 Interstate Grand Tour Ext
Niceville
, Destin
Rocinante: here is a good replacement faucet from Dudadiesl, it’s a set and forget temperature , it also circulate the water in the valve so you don’t get a blast of cold water.
Sorry about the angle
09-05-2023, 08:13 AM
#629
Green Cove Springs
Interstate Maintenance & Upkeep
Oh, that looks promising as well, thanks! How difficult was it to remove the old faucet, including the flex hose that hides in the wall, and install this new one?
Found it here, but for now it is out of stock:
https://www.dudadiesel.com/choose_it...tchenValve-002
09-15-2023, 07:29 PM
#630
Here and There
, West Coast
Added two things to the Sprinter:
- An engine oil dipstick (comes with a capped tube but no stick)
- Hood struts (Owl)
09-15-2023, 07:41 PM
#631
2013 Interstate Coach
Waterloo
, Iowa
What year is yours that has no oil dipstick? What are Owl hood struts and how are they better than what the Sprinter came with?
09-15-2023, 11:17 PM
#632
Here and There
, West Coast
Chassis is 2020 (2021 AI-19) Sprinter 2500
The hood from factory has a single prop. Owl Vans is a distributor of after market parts. The prop is just a rod which hinges from the hood into a slot at the fender. The struts come as a pair so one on each side. They are gas filled so they help lift the hood and hold it up. Makes it a one handed raise and lower (like a rear hatch on a SUV).
Don't really need either but what the heck As it comes from the factory checking engine oil is via a dash display. I'm old fashioned and want to actually see the oil on a stick. I was adding DEF recently and thought the hood could use an upgrade to struts, especially with a dipstick to look at
