Old 10-16-2019, 11:53 AM   #1
St auguatine , Florida
Interstate key not working-HELP!
Hi all, I have been unable to use my AI for 5 months now. It was in the shop for body work during part of that time. This is my first chance to check on it and everything appears to
Be working except the ignition! And I dont mean the battery is dead because the key moves slightly. When battery is dead key usually moves but engine doesnt turn.
Carla
carpenc is offline   Reply With Quote
Old 10-16-2019, 12:12 PM   #2
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
If it were me....Id try this.
1)Remove key from ignition, and wait a minute.
2)Disconnect the power cable down by the accelerator pedal, wait a few minutes.
3)Put key back in the ignition, then reattach the power cable.
This gives the system a chance to recognize the key again.
Hope it helps.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 10-16-2019, 12:54 PM   #3
2012 Avenue Coach
Corpus Christi , Texas
This may be a dumb question, but is there any possibility you drove it to the shop with your primary key and left them your second key? Then picked it up with your primary key and they mixed up your second key with another customer's and that is the one that does not work?
If the key fob and key unlock the doors, please disregard the above.
rowiebowie is offline   Reply With Quote
Refrigerator not working on gas 2006 Interstate Lotus54 Sprinter and B-van Forum 7 10-26-2016 09:56 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 4 04-03-2016 10:16 PM
Dometic heater zone 2 not working on furnace, not hot on HP sfgirl General Repair Forum 13 11-06-2015 02:21 PM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 10:15 PM
