Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 05-22-2008, 10:26 AM   #1
SCOOTER
Profile:  ORLANDO , Florida
Send a message via AIM to EIDAM3
Interstate house battery change
Is there a 'reasonably' easy way to swap out the house batteries without removing the seat assembly on an 03?
Scott
EIDAM3 is offline   Reply With Quote
Old 05-23-2008, 07:50 AM   #2
Profile:  Pittsburgh , Pennsylvania
seat removal
Removing the seat takes about 5 minutes. Anything else I could imagine would end up being much more work.
avanti is offline   Reply With Quote
Old 05-23-2008, 03:35 PM   #3
SCOOTER
That's a huge relief! I figured it couldn't be a monumental task, but I haven't had a chance to really look at it yet.
Scott
Old 05-23-2008, 08:50 PM   #4
Just to be clear: You don't remove the entire seat assembly--just unbolt the bottom cushion from the frame.
Old 05-24-2008, 02:10 PM   #5
SCOOTER
I'm going to get around to that this evening. I took a look at the whole thing last nite and I figured that was going to be the solution.
Thanks again,
Scott
Old 07-13-2009, 11:14 AM   #6
Profile:  Cabin John , Maryland
I was topping off the battery in my '07 yesterday (see related thread) and would up unbolting the upperhalf of the assembly. Getting it back in, aligned, and getting the spring back on was a major pain.
How do you remove just the seat cushion? I looked hard, and even tried removing the small Torx screws along the sides, but couldn't figure it out. Suggestions welcome!
Pat
patrickdylan is offline   Reply With Quote
Interstate Batteries Tin Hut Batteries, Univolts, Converters & Inverters 34 10-27-2009 02:33 PM
Chassis/House Battery Charging 4 Motorhomes Jim Tyrney Airstream Motorhome Forums 40 02-15-2008 10:45 AM
Interstate 86 Steve & Susan On The Road... 0 09-07-2006 07:46 AM
House battery types ralley Electrical - Systems, Generators, Batteries & Solar 12 02-13-2006 09:18 PM
Battery replacement..have SRM27 Interstate Kistler Our Community 3 11-27-2004 10:41 PM
