Old 03-18-2015, 10:15 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by k9jackie View Post
My first aftermarket interior shades used suction cups. I didn't care for them, because the suction cups didn't always "suct" and the shade would fall off. Which kind of sucked. Plus they left round marks on the glass unless I washed the windows after every time I removed the shades.
The exterior shades are good for blocking sunlight. Not so good for privacy— at least when the van is in storage. Being on the outside, anyone who wants to peek inside and see if the van contains any goodies worth stealing can just move the cover out of the way. But fine for camping; a peeping Tom peeling back an exterior windshield cover to see inside is going to be noticed, either by you or your neighbors.
And a caveat, if you normally use a canvas exterior windshield cover, expect to sometimes have to put it away wet if you get rain overnight before you're due to break camp. And expect it to shrink over time if you put it away wet. If it dries while stretched out over the glass it won't shrink nearly as much as it will if it dries while rolled up in your wet bath.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-18-2015, 12:06 PM   #16
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
If I was doing it all over again....
I currently have a set of reflective and insulating shades from Outside Van. I believe Airstream has copied them on their newest models. They work very well in keeping out light and heat, but they are tricky to put up, and my wife always insists I align them perfectly to avoid any chance of peepers from outside. This is pretty inconvenient when we're stopping for the night at a truck stop or Walmart and just want to close up quickly.
So, if I was doing it all over again, I would go with a set of Remis from Eurocampers. These appear to need a time-consuming install that may be tricky, but in the end you have shades that can be closed and opened as easily as the coach shades. And in addition, if I wanted extra sun and heat protection, then I would attach an external shade such as used by Protag.
Best of both worlds.
Vent covers and outside propane covers robwok 1960 - 1964 Overlander 4 02-09-2011 12:56 PM
How do I install vent covers over my vent covers? bigjohn Roof Vents, Skylights & Fans 1 07-29-2010 04:34 PM
Front Window Covers 1950 & 1960 Ganglin Off Topic Forum 0 01-28-2008 08:17 PM
Looking for front window plexiglass covers tslanier Windows & Screens 5 07-30-2006 06:02 PM
front window covers Al1 All Argosy Trailers 13 08-05-2003 05:51 PM
