Old 07-07-2019, 01:21 PM   #1
St Petersburg , Florida
Interstate Dump Hose Replacement
After much searching, I have determined (I think) that the OEM dump hose on my 2016 Interstate is manufactured by TIGERFLEX. (the pin holes arrived on their own...)
I just bought 100' of TIGERFLEX BW075 (1"OD/.75"ID) on Amazon for about $150. This is much lower than the Airstream OEM replacement that includes the ball valve assembly, is 20' long, and drop ships for about $250!
I'm going to have about 80' of replacement hose left over after I finish my project...I'll be putting that up on e-bay or offering it at my cost to others that may need it.
Hope this is helpful to others..it was a lengthy quest to find it, since the AI OEM macerator system manufacturer (CleanDump) does not provide Airstream with the hose, and their offered solution is 1.5"OD, which is too big for the Airstream reel.
Be well
PirateChris
PirateChris is offline   Reply With Quote
Old 07-07-2019, 02:21 PM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
You could have saved a lot by just buying this...
https://www.amazon.com/Clean-Dump-CD...df_B004OZR23A/
- - Mike
Old 07-07-2019, 08:33 PM   #3
Raymond , Iowa
I bought this, and had enough for two replacements. I have never needed the full length that it came with, and that full length was too much for the hose reel. This new hose seemed a bit more flexible, but perhaps just because it is new.
https://www.etrailer.com/RV-Sewer/Se...tion/SS25.html
Titus is offline   Reply With Quote
Old 07-08-2019, 07:21 AM   #4
Wrong one
Thanks Mike, but it’s the wrong hose. The one you suggest is is 1” ID, not the 3/4” needed.
This one doesn’t fit the reel... but it’s close
Old 07-08-2019, 08:12 AM   #5
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Thumbs up
Good to know. So the one Titus recommended fits fine as it is 3/4" ID
Added to my list. Thank you!
EDIT: Oh wait! You bought 100' !!
This one: https://www.amazon.com/Tigerflex-Tem...591765&sr=8-14
Added to my Amazon wish list. Thanks again.
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 07-08-2019, 08:34 AM   #6
Mansderm161's Avatar
NORTH MYRTLE BEACH , South Carolina
Tigerflex has a web site. May be able to buy direct and get length you want instead of so much extra for less. Didn't see a price list, but they had a catalog you could download.
Mansderm161 is offline   Reply With Quote
Old 07-08-2019, 09:32 AM   #7
wachuko's Avatar
Orlando , Florida
Not sure what the shipping cost would be but available here for $88.43
https://shop.andersonprocess.com/tig...x100-hose.html
Edit: $114.59 shipped to my house.
Safe travels!
Wachuko
WBCCI #26769
Old 07-08-2019, 09:35 AM   #8
Fulton , Maryland
You are correct. I just checked mine and it is 1" OD hose.
After a quick search is see that this same issue was discussed about 4 years ago in this thread...
http://www.airforums.com/forums/f240...nt-138401.html
I had some pin holes near the end valve and just cut off about a foot to repair. Others on this forum have done the same.
- - Mike
Old 07-12-2019, 11:21 PM   #9
WillieJ's Avatar
Bellingham , Washington
Tigerflex hose
I called CleanDump. I had a nice chat with the owner who mentioned that he tried to dissuade Airstream from using the 3/4 inch hose because he felt it was too small to flow properly. He said the 1 inch ID would have been much better. He had a small supply of the 3/4 inch ID hose of which I purchased enough to replace the pinholed hose on my reel.
I had already purchased the 1 inch ID hose from Amazon, and of course found it was too big for the nipple on the reel. That resides on a shelf in my garage.
WillieJ is offline   Reply With Quote
Old 07-13-2019, 01:06 PM   #10
Fulton , Maryland
Good info - I think Airstream uses 3/4” hose so they can get more on the hose reel they use.
- - Mike
Old 07-13-2019, 02:03 PM   #11
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I get plenty of flow through the 3/4" hose. I always make sure there is a weight on the sewer end because the sudden flow can pull the end out of the sewer opening. Not nice when it happens.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 07-15-2019, 09:21 PM   #12
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
JOHN - ^^^ Same here. Although be nice to have the 1" but as MIKE said below. If it were not for hose reel, we probably can get twice the length & even 1" ID in same space?
Alex AVI is offline   Reply With Quote
T1N Interstate (gravity dump) - best sewer hose? InterBlog Sprinter and B-van Forum 17 07-10-2019 03:10 PM
Black and Gray Dump Hose Replacement 3bcamper Sprinter and B-van Forum 8 06-15-2018 11:24 AM
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 02:53 PM
Dump Hose Replacement Funinthesun Sprinter and B-van Forum 19 07-26-2015 07:17 PM
dump hose connector Tin Hut Waste Systems, Tanks & Totes 5 10-11-2003 09:25 PM
