Old 12-15-2014, 02:19 PM   #1
Past Prez.NEU/Membership
AirHog's Avatar
2005 34' Classic
2015 Interstate Ext. Coach
N Smithfield , Rhode Island
Images: 21
Interstate Brake Controller
I was told by the dealer, the only way to install a brake controller is to hard wire the unit to the wires which is located under the driver seat. Run it underneath the carpet and install the controller somewhere near the dash board. In all my previous dealing with controllers they were always snap on connections specific for auto manufacturer (got the wiring from E-Trailer) and no need to strip wire to do a hard wire connection. The dealer also stated this is how MB does it.
Any thoughts or comment will be appreciated. I will use a P3 Prodigy unit.
Many thanks.
Titu.
T & Gail
2015 Airstream Interstate Ext
2005 34'Classic- Mercury (Goddess of Travel)
2016 GMC Sierra Denali 2500HD Diesel
WBCCI #2905-NEU
AirHog is offline   Reply With Quote
Old 12-15-2014, 02:24 PM   #2
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Many thanks.
Titu.
That was my experiance. I had my dealer install a P2 prior to taking delivery and they did have to run wire from under the driver seat to the dash. Seems like MBZ only runs the wiring from the hitch location to the driver seat. Kind of dumb if you ask me.
c21bill is offline   Reply With Quote
Old 12-15-2014, 02:38 PM   #3
AirHog's Avatar
2005 34' Classic
Images: 21
Thanks. That is what I will do.
T & Gail
WBCCI #2905-NEU
Old 12-15-2014, 03:19 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Dumb if you're towing a trailer. Not necessarily dumb if you're towing a toad. The supplemental brakes on my toad are activated by the brake light circuit, no separate brake controller required.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-15-2014, 06:01 PM   #5
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I thought I read that connecting anything to the brake lite ckt would create chaos w/ the computer and how it senses bad bulbs.
Old 12-15-2014, 07:50 PM   #6
I don't know. It has worked just fine on mine since February 2013
WBCCI #1105
TAC LA-4
Old 12-15-2014, 08:01 PM   #7
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
If you have a light trailer you can just mount the control under the seat. You won't be able to see it but it will work fine.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 12-16-2014, 06:59 AM   #8
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
I installed mine myself and purchased a connector to fit the existing connector so did not have to cut into MB wires. Worked fine no problem.
PSchw is offline   Reply With Quote
Old 12-16-2014, 07:06 AM   #9
AirHog's Avatar
2005 34' Classic
Images: 21
Thanks Andy. Hope all is well. Hope to visit you folks next year.
Also thanks PSCHW. Good advice.
Titu.
T & Gail
WBCCI #2905-NEU
Old 12-16-2014, 12:57 PM   #10
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
+1 on PSchw's comment. There is a Mercedes connector under seat and if you get the correct matching connector there is no need to cut wires.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is online now   Reply With Quote
Old 01-04-2015, 04:08 PM   #11
Flemington , New Jersey
Some more info to tie into the MB connector under the seat. Used this to wire a prodigy into the sprinter and extends the chassis ESP control to the trailer.
Parts: Brake controller install - Sprinter-Forum
Lead connections: install electric trailer brake controller on 07 - Sprinter-Forum
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 05-07-2015, 12:39 PM   #12
hamiltonmj's Avatar
1965 17' Caravel
Opelika , Alabama
Anyone have any luck installing a Tekonsha Wireless brake controller ? Even after talking to Tekonsha techs have not been able to pair the controller.
Mike Hamilton
WBCCI # 2766
2013 Airstream Interstate (Darth Vader)
1965 17' Caravel (R2D2)
hamiltonmj is offline   Reply With Quote
What Brake Controller Are You Using On Hydraulic Brake Classics? KJRitchie 2006 - 2010 Classic (all lengths) 30 09-25-2014 12:03 PM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
E53 w/ Tekonsha brake controller lights 3rd brake light when manual lever applied warmrain Brakes & Brake Controllers 10 11-14-2013 09:35 AM
Brake controller or trailer brake problem? (newbie alert) jornvango Brakes & Brake Controllers 2 11-01-2012 02:17 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
