Old 12-01-2016, 01:27 PM   #1
AI Joe's Avatar
Key Largo , Florida
Images: 11
Interstate Bike Racks - Ladder vs. Hitch?
Anyone using the Surco Sprinter rear door ladder to carry one or two bikes; especially folding bikes. My wife and I are not in agreement over door vs. hitch options. I want the door as I want regular easy access to the rear. My wife is concerned she will not be able to reach up to hang her bike on the lower ladder rungs. Not finding much on the web. Any experience with the Surco ladder and bikes on it would be welcomed....
I do realize the ladder will limit the ability of the door to fold completely around, but that is not as much an issue as the need to remove the bikes and hitch every time we camp for a night just to get to the chairs, bbq and more that we store in the rear.
Wondering also how much weight one of the rear doors will handle with the ladder, 2 bikes (maybe electric folding) etc...
AI Joe
AI Joe is offline   Reply With Quote
Old 12-01-2016, 02:14 PM   #2
Hi, Joe. The issue of carrying bikes (and other items) has been debated extensively on other threads, and I don't recall any single solution being unanimously promoted as the obvious best option.
I will tell you that my husband and I had a similar debate, in that I initially wanted both back doors to remain completely unobstructed, whereas he wanted a rear carrying solution without regard to potential impacts on door usage. His concern focused mostly on optimizing the engineering, not the ergonomics.
We ended up compromising in a way that made us both very pleased. Unfortunately it was not a simple solution. We fabricated a hitch carrier ourselves, which leaves ONE door (the one with the handle) completely unobstructed, and the other door blocked unless we drop our cargo to the ground for the purposes of opening both doors fully while at a camp site.
We customized our carrier to fit a cooler, but we could just as easily have customized it for bikes - in fact, we may go back and make a supplemental insert for the left side of the carrier so that bikes can be easily secured there instead of the cooler.
This series of blog posts describes the carrier and our developmental process, in reverse order unfortunately (blame the Blogger interface).
Old 12-01-2016, 03:34 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Bikes bouncing around on a rack apply a great amount of force to what they are attached to. After a while, I wouldn't be surprised to have door hinge problems if you go the door route....I have a folding bike. It is about 50% heavier than my steel framed mountain bike. I am sure an electric bike is even heavier.
You can get a hitch mounted bike rack that folds down to allow rear door access.
CRH is offline   Reply With Quote
Old 12-02-2016, 06:17 AM   #4
Originally Posted by CRH View Post
...I wouldn't be surprised to have door hinge problems ....
More likely is sheet metal problems for ladders attached to the rear Sprinter doors. I researched this at length prior to making the decision to go with a hitch solution. While nobody's evidence was incontrovertible, most posters on other forums (not Air Forums threads) believed that there was a significant risk of sheet metal deformation from loading the rear doors with a ladder plus or minus other items. People do it, but the doors simply weren't designed for those kinds of stresses.
A better ladder solution is the kind that attaches to the top gutter and under the chassis, as those are supported by structural elements rather than the sheet metal skin of the vehicle (but of course that kind can't be used on the rear). Aluminess is probably the best known supplier; Outside Van (OSV) also offers their own versions. I screengrabbed this OSV photo from Instagram last night, to show the configuration. People sometimes put two ladders on the sides of Sprinters for the purposes of carrying surf boards. Anything else, like bikes, would probably stick out too far for side carry.
Here is OSV's ladder page and here is the Aluminess product. OSV has been careful to attach the upper portion of their rear door ladder to the very top of the door frame, not the sheet metal.
Old 12-02-2016, 07:15 AM   #5
Kwils25's Avatar
2020 27' Globetrotter
Taylor Ridge , Illinois
I purchased a Thule Swing Away bike rack last year. It works great. It will allow both doors to open. Although the door with the handle does not open all the way. I'm very pleased with this setup.
https://www.thule.com/en-us/us/bike-...31xt-_-1686826
Kwils25 is offline   Reply With Quote
Old 12-02-2016, 12:01 PM   #6
mrgolf's Avatar
2017 Interstate Grand Tour Ext
Charleston , South Carolina
We are avid road cyclists and wanted a stable solution for transporting our bikes. We chose a Thule T2 Pro rack (https://www.thule.com/en-us/us/bike-...9035-_-1689770) attached to a RakAttach (http://rakattach.com). This solution allows for a tray-based rack and a full ability to swing out of the way - to the left as well so that no obstruction when we set up awning, etc. on the right side. Yes, this does require more $ invested, but to me best meets our needs for stability, security, and clearance.
mrgolf is offline   Reply With Quote
Old 12-02-2016, 01:02 PM   #7
Holy cow - that Thule swings left - that's very rare. The Stowaway people told me that under no circumstances would they ever develop or sell any device that swings left - too much liability if someone has to pull to the shoulder of the road and then open their rear door in an urgent situation (because the device would swing into the adjacent lane of active traffic).
That was one of my big stumbling blocks on a commercially-produced device because, with right-swinging devices, almost all of them at least partially block the rear door that has the handle on it. I didn't mind so much having the left door partially or wholly blocked because it's the passive door, but not the right - no way. So all right-pivoting hitch products were off the table for me. Nobody mentioned this product previously, I don't think.
Old 12-02-2016, 02:30 PM   #8
AI Joe's Avatar
Key Largo , Florida
Images: 11
Keep the ideas and experiences coming please...
Dear Mr. Golf and Interblog: The Rakattach sounds like a solution, especially if it swings off to the drivers side, so when camped it is out of the way of the passenger - awning side and allows the rear doors to both open 90 degrees to take advantage of fresh air and the great electric screen on the 2016 and 2017 AI. However, as Interblog points out, I too have never seen a hitch that swings to the drivers side. So, how did you do this. I have contacted Rakattach about availability, pricing and swing and will post what I learn to this thread.
I still don't like the added length for all this -- can you tell us how much length the Rakattach and Thule-Pro2 added to your AI?
I think the optimal solution would be the Suco door mount ladder and two 25-30 lb folding bikes that can be put inside the van in bad weather, city stops, etc. However, I'm not succeeding in finding any data on what the AI door can handle with the Surco - which hangs over the top back of the door and bolts to the bottom with 2 screws and bikes and the AI traveling down bumpy roads. I figure with the doors closed and the folders attached to the ladder there should be little to no movement or stress -- but I wouldn't know. Maybe I need to find an engineer, as I don't want to experiment with our new AI; besides my wife would kill me.
Anyway - thanks all for the input. Keep it coming and I will be sure to post my final decisions, etc.
Old 12-02-2016, 03:09 PM   #9
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
Wow - thanks for posting info on RakAttach. I'm getting one so I can use my platform carrier or a bike rack for my tandem. I stopped using the rear racks because it made it impossible to use rear storage area.
Edit: Looked at the photos on RakAttach web site. They all swing right. Did you modify yours to swing left? Or do they offer a model that swings left.
Old 12-02-2016, 03:23 PM   #10
mdf
2016 Interstate Lounge Ext
Belvedere , California
I installed a fiamma door mounted rack this summer and it worked flawlessly. Conveniently, you can easily open the door with the bike rack in use without any extra steps. I will try to find a picture for you.
mdf is offline   Reply With Quote
Old 12-02-2016, 03:26 PM   #11
mdf
Old 12-02-2016, 03:59 PM   #12
I know! I look it up, too. All swing right. I'm curious as well.
Old 12-02-2016, 05:50 PM   #13
Sebastopol , California
If you look closely it appears mrgolf mounted the rackattack upside down. I'm not sure if is engineered for this application!
Sebtown is offline   Reply With Quote
Old 12-02-2016, 06:23 PM   #14
? The label is right side up, though. And I specifically verified that the license plate numbers were not mirror image (photo flip) before I made my holy cow comment.
Old 12-03-2016, 08:35 AM   #15
AI Joe's Avatar
Key Largo , Florida
Images: 11
Rakattach solution to opening rear doors....
OK all . . . I got the answers to all our questions from Mr. Rakattach himself and they are pasted forthwith:
"Hi Joe,
Thanks for checking out the RakAttach!
We build the RakAttach in either a driver side or passenger side swing.
The large will clear the bike racks to the side as in the photo.
You will be able to get the van door open to the first hinge stop.
The RakAttach has a load limit of 300-350(max) pounds in any position open or closed.
A Kuat NV or Thule T2 Pro and your two electric bikes will be well under within the weight limit.
I have the driver side swing in stock.
Price is $454 includes hitch pin, anti rattle clamp and FedEx ground to you.
The packed box weighs 60pounds.
We build the RakAttach in Utah with US steel and locally sourced parts.
The unit is powder coated black and has a 1 yr warranty.
Thanks!
Walter"
Walter can be reached at: walter@rakattach.com
I think this clarifies that the RakAttach might be the solution that so many of us are looking for. I know the hitch will handle the weight of the device, a bike rack and two bikes but not sure how the vehicle itself will handle, or how much lower to the ground the rakattach will bring the vehicle to the road -- hopefully we will hear from Mr. Golf on some of that as this was his ingenious solution -- thanks again MrGolf.
Old 12-03-2016, 10:10 AM   #16
ScottP's Avatar
2019 Interstate Lounge Ext
Jackson Hole - Tetons , Wyoming
I'd say you should assert yourself and remind your wife it's "your" ASI and you're not compromising.
Seriously though...
We're using two solutions - a Kuat rack which is either 4 or two place ...and an aluminum trailer which we can leave at our site if necessary.Click image for larger version
Name:	ImageUploadedByAirstream Forums1480784989.508901.jpg
ID:	276306Click image for larger version
Name:	ImageUploadedByAirstream Forums1480785003.157591.jpg
2017 4x4 Interstate
Bend, Oregon
ScottP is offline   Reply With Quote
Old 12-03-2016, 01:23 PM   #17
AI Joe's Avatar
Key Largo , Florida
Images: 11
Bikes or Smart Car w/Trailer?
Scott: I started out wanting to tow a Smart Car so we could have ready transportation without breaking down the AI -- and thought then we could carry folding (electric?) bikes as well - in other words lots of options. But, not sure I want to tow anything yet -- probably still new to all this as we purchased our AI in January 2016. Time will tell. Thanks for the mention of a tow trailer. jch
Old 12-03-2016, 01:26 PM   #18
2024 Interstate 19
Fulton , Maryland
I didn't think it was mounted upside down because the lettering was not inside down. Nice that is available to swing either way. A bit pricey but sure well made. I've looked at other swing away hitch adapter but this one is the best I've seen.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 12-03-2016, 03:19 PM   #19
ScottP's Avatar
Towing:
I suppose it depends on your perception of whether towing is a hassle or not. For me, it feels like second nature for some reason. Our aluminum trailer is very light, and usually carries just a motorcycle, or two kayaks, four bicycles and perhaps some light camping gear. Occasionally we will tow our jeep, and it will serve as a trailer-of-sorts for us. Camping gear, and mtn bikes, and provisions for our trips to MOAB in the past.
Everyone is different, but somehow I feel more comfortable towing than attaching a ladder and rack to the van. Don't get me wrong, I admire some of those cool ladder/roof rack combos with light packages....in just not comfortable with the ladder attached to the rear door. Also, I don't want to eliminate the wrap-around feature of the rear doors.
Your mileage may vary, of course...
Name:	ImageUploadedByAirstream Forums1480803461.759874.jpg
ID:	276321Click image for larger version
Name:	ImageUploadedByAirstream Forums1480803490.707778.jpg
ID:	276322Click image for larger version
Name:	ImageUploadedByAirstream Forums1480803506.843771.jpg
2017 4x4 Interstate
Bend, Oregon
Old 12-03-2016, 09:16 PM   #20
2015 Interstate Grand Tour
Anywhere USA , USA
This works just fine for me and our 2 bicycles. Allows both doors to be opened fully around to the sides without removing the bicycles.
http://www.heininger.biz/sportsrack_glideaway2.php
JayP is offline   Reply With Quote
Bike racks for Interstate camlivy Sprinter and B-van Forum 38 08-12-2017 12:28 PM
Hitch type bike racks phowe46 Hitches, Couplers & Balls 9 05-12-2015 09:56 PM
Hitch cargo boxes and bike racks Jcmitchell Sprinter and B-van Forum 7 03-18-2013 05:36 PM
Any ideas for bike racks on a Bambi? Tink&3Girls 1997 - 2004 Bambi 3 10-11-2006 02:01 PM
