11-25-2018, 12:15 PM
St Petersburg
Interstate Battery & Solar Panel Upgrade
Hi all,
I'll appreciate your experienced thinking on this matter. I have a 2016 Interstate (OEM 100 W Solar and 2 House Batteries). I will be in Ohio in early February and am planning on an overnight stop at Airstream Jackson Center and having them upgrade my Interstate to the 2019 configuration, which is 300 W Solar and 4 house batteries.
I'm told this is an easy one-day effort. Wondering if others may have already made the this modification, and are you pleased with it? Was it worth it? Any problems/issues I should be aware of.
Many thanks to the community
PirateChris
11-25-2018, 01:46 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard!! 👍
PC,
Don't rush...there are much better options outside of the JC offerings.
I'm sure other interstate owners will chime in. 👍
BTW
We also have a "Pirate" on board...
"You don't know where you've been until you leave, enjoy life" RLC
11-25-2018, 03:06 PM
Naples
Personally, I would not have Airstream do any modifications to your rig. I have no idea what they charge, but I'm sure that you can gat a similar upgrade done with 300 watts of hard panels (not their soft ones that will actually wear out in a couple of years), a Victron solar controller (far superior to the little POS that Airstream uses) and better batteries for the same price that they will charge.
Something to look at for sure!
lewster
11-25-2018, 06:31 PM
2007 22' International CCD
Corona
Yup. Do your research first. Look at AMSolar. They sell kits and have excellent installers available as well.
Airstream charges way too much for their solar systems.
We did a kit from AMSolar a few years ago, self installed, with a single rigid 150 watt panel. Never have a problem keeping our batteries (2 GC-2 flooded lead acid) well charged.
11-25-2018, 08:02 PM
2013 Interstate Coach
Waterloo
, Iowa
Regardless of who does it you need to make sure that the type of the solar panels match exactly. Also, you may run into issues putting two new batteries in with two 2016 batteries.
11-25-2018, 11:19 PM
2015 Interstate Grand Tour
Lake Oswego
, Oregon
You can have a competent retail operation that does batteries all day do a load test of your batteries if you are concerned about two new ones "matching" the OEM ones. But yeah it's best if they are all the same vintage.
Agree on going with fixed panels. I have one 100W flexible and I installed two 100W fixed panels from AM Solar myself. It was easy after watching their YouTube video on it. But I regret going with a Serial connection (I was nervous at first about too many amps going through the stock 10 gauge wire from the roof to the now Victron solar charge controller). With Serial, the whole array gets dragged down in output if you have a partial shadow, even a little one. I tested that myself by putting my hand on just one cell and watching the bluetooth readout on my phone.
I'm changing that to Parallel as soon as I can borrow a tall enough ladder. Should be an easy switch out using combiner Y connectors. With 300W I'm pretty sure I'll be safe with that 10 gauge wire, hopefully the only drawback is maybe I miss out on a couple % efficiency.
Definitely add battery capacity !! I also have a Grand Tour and even with upgraded 220Ah (110Ah usable) I barely have enough power for the 16 hours we need during an average dry camping overnight. Four batteries starts getting heavy but is probably your best bet unless you have the bucks for lithium and the extra stuff that goes with that.
11-26-2018, 06:54 AM
Townsend
, Tennessee
I went through this a couple of years ago. I wanted to put 400 watts (rigid panel) on the roof and add more AGM batteries...and new controller. While this would’ve met my immediate power needs, it felt like a “baby-step” towards my real goal.....extended boondocking.
I considered the amount of labor just to get that first step done, and what it might take to get “all the way”. Granted, lithium batteries aren’t cheap, but I would be so close to where I wanted to be anyway, so I took the plunge. Also gained the capability to use AC off batteries.
My system, all AM Solar supplied, was installed professionally (thank you Lew) and after 2 years I am convinced it was the best path for me. Performance has been flawless.
Good luck to you in your decision process!
FMCA # 436814
11-26-2018, 01:21 PM
2017 Interstate Grand Tour Ext
Marco Island
Solar conversion
Just completed a conversion to 400 W solar fixed panels, Victron 2400 watt inverter and 400 amp hour lithium. I used Lew Farber who spends half his time in SW Florida and half in Oregon. Haven't used it yet but am looking forward to boodocking. It should provide plenty of power for off the grid if we have sun and can also run the generator to charge the batteries. The lithiums are expensive but are much more capable and less prone to damage from over use. The Victron will actually shut down before we damage the batteries. There is a handy app which provides detailed stats on usage, charge etc.
We are going deep in the Everglades in January and will test them out.
Good luck!
11-27-2018, 09:17 PM
2015 Interstate Ext. Coach
Saint Louis
, Missouri
Good luck!
Would you mind sharing the cost? I have 2015 Ext Lounge. Thinking about upgrading whole system as controller versus battery issues going on now.
12-01-2018, 05:51 AM
Keswick
, Ontario
Check AMSOLAR for pricing
They are very helpful and reasonably priced. The installation isn’t that hard if you want to do it yourself. Or get Lew to do a professional job. We removed the airstream solar panel and solar controller then installed victron. My only regret was investing more in magnum controller and AGS rather than going all victron. Doing it again I would go victron all the way. Their app is awesome. Magnum is way behind in this respect. Batteries are easy enough to hang underneath if you stick with AGM.
Cameron Sturgess
Interstate grand tour 2016
12-01-2018, 12:08 PM
Madison
, WISCONSIN
Last month I had my local AS dealer install second tray and a second set of batteries. While they were the same type, the were newer. I know this wasn't ideal but I am hopeful that the four batteries will last and perform for a good period of time.
I have the one solar panel that came with my Interstate. I believe I have room for two more in the aft part of the roof. I see no reason to get rid of the existing one which leads me to the conclusion of adding two more of the same flexible panels. I would wire them in parallel. There is always going to be some shading (yes, I know that there are a few days a year for a few minutes that the sun would be perpendicular - but even then I have an antenna which does shade the existing panel unless it is in the deployed (up) position).
My calculations tell me that the existing 10 ga. wire will be fine. As to the charge controller, I do want it to fit in the "box" I do not want it outside. So I calculated that a realistic maximum current of 18 amps. So to keep the size of the controller down my plan is to use the Victron 100/20.
My primary objective is to ensure that I have enough capacity to get through a night with the refrigerator-freezer and other phantom power drains.
I have no current (pun?) plans to change the inverter or other electronics.
I would appreciate any critical comments on what I've done and propose to do.
Kevin N9JKP
12-01-2018, 01:41 PM
2024 Interstate 19
Fulton
, Maryland
Overall it sounds OK. If you add more panels upgrading to wire heavier than 10 ga would be a good idea. My 400 watt system has a 6 ga wire drop to controller as recommended by AM Solar. Also be aware that flexible solar panels only have about a 5 year lifespan before their efficiency drops off significantly. Glass panels are good for 25 years. What you use depends on how long you plan to use your coach.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
12-01-2018, 02:55 PM
Naples
Actually, The flex solar panels have a dedicated life span of 5 years. Their actual life span is closer to 2 years TOPS! I have experimented with the soft panels quite a bit over the last 4 years or so and have found every type to be unsatisfactory. YMMV on this topic, but I would NOT use a flex panel for any installation that I am involved with.
On the Interstate vans, I remove all of them and replace with the 100 watt glass versions which last about 25 years. Huge difference!!!!!
lewster
12-01-2018, 09:22 PM
2024 Interstate 19
Fulton
, Maryland
Right on Lew! I just can't believe Airstream puts those crap flexible solar panels on a van at their market topping price point. Goes along with the crap solar controller they use. What a rip off.
- - Mike
12-02-2018, 06:43 AM
Madison
, WISCONSIN
OK, so no flexible solar panels. That means tearing off the existing solar panel, any tips on doing that?
As to the glass version will the Renogy Mono work? What do others use?
I can only fit 3 panels on the roof, amateur radio antennas, etc. limit any further real estate.
Kevin N9JKP
12-02-2018, 06:56 AM
2017 27' Flying Cloud
Fort Worth
I have been working on a 400W system for my FC. I spoke to AMSolar and they are out of stock on 100W panels. I ended up purchasing Renogy Eclipse panels from Amazon for about 50% off a few weeks ago. The price has since gone up....don’t know if I got a Black Friday deal or something else.
12-02-2018, 07:58 AM
Naples
I use AM Solar's 100 watt panels, of which there are no more. They have started to use the Zamp 90 watt panels in their place, which come in at about 97 watts or about the same as our older 100 watt units.
I would call AM Solar and see when they expect the next shipment of panels to arrive. The Zamp units are excellent to work with.
Removing your old panel is not a big deal. You have to take off the screws that hold it to your roof, then scrape off the double sided tape that holds the panel to the roof. After that, clean your roof with alcohol, fill the remaining screw holes with SikaFlex 221 and you're good to mount your new hard panel in the same area.
Good luck!
lewster
12-03-2018, 08:27 AM
Madison
, WISCONSIN
Any idea why the Renogy (both the Eclipse and the Mono) appear to be considerably less expensive than the Zamp?
Also from whom did you purchase your panels?
I now have to carefully measure my available real estate and determine what size/shape panels will fit on my roof.
Kevin N9JKP
12-03-2018, 01:57 PM
Registered User
2016 25' Flying Cloud
Fairfield
Use cardboard cut outs the size of the panels you are looking at buying to work out the placement.
12-04-2018, 12:16 AM
2018 Interstate Lounge Ext
LV
, Nevada
LEW - Does the 5yr/2yr longevity figure get affected by whether unit is garaged or not? Or is it just based on cell age degradation, irrespective of UV exposure? I live in Las Vegas, my rig is always garaged (fully enclosed) when not in use. My usage has averaged outdoor exposure is 2 days per week since new (9 mos & 9,000 miles). Las Vegas UV exposure is horrible and will destroy anything. About the only material that has stood up to it are the casings used by pool equipment manufacturers, specifically StaRite. My pool filter lasted 20yrs of 24hr UV exposure before developing a leak.
I am asking so I can proactively plan on when to remove my 3 flex to upgrade to glass panels.
Thanks for your contributions to this forum. Very informative.
