Old 06-26-2014, 06:59 PM   #1
2004 22' Interstate
mercer island , Washington
interstate airstream winter cover
I have a 2004/2005 Airstream Interstate (Sprinter) and want a high quality winter cover that fits well. Any ideas ?
brucewaddell is offline   Reply With Quote
Old 06-26-2014, 07:29 PM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
We have discussed the covers on this forum in the recent past and as I recall the consensus was they were of no real use, difficult to install and would likely damage the paint on your Interstate.
- - Mike
Old 06-27-2014, 04:40 AM   #3
Lily&Me's Avatar
Normal , Illinois
We bought one for ours, and they are not inexpensive.
Seemed like a good idea at the time, but they are very difficult to keep in place if you have any winds to contend with. Whipping and blowing winds will take it right off.
The casualty on our Interstate, from the ever-shifting cover, was the AIRSTREAM lettering across the front. Pieces of several letters broke off, and the whole thing had to be replaced.
Also, if you have snow/sleet on your roof that melts and refreezes, this turns into a thick block of ice that is very difficult to remove so that you can take the cover off, if you are planning on leaving before the spring thaw.
The cover might be good just for dust, if your Interstate were otherwise in a covered area, but expensive for just that, IMO.
Maggie
Old 06-27-2014, 08:15 AM   #4
2005 22' Interstate
Pittsburgh , Pennsylvania
Naah. Those letters came off of ours after a few years, and we have NEVER used a cover of any kind. Ended up having the residue professionally removed.
Just standard Airstream adhesive dyslexia.
avanti is offline   Reply With Quote
Old 06-27-2014, 08:19 AM   #5
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
The best winter cover for an Airstream or an INTERSTATE is a barn or shed.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 06-27-2014, 08:29 AM   #6
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
If you have the space, there are portable structures of thin steel tubing or plastic tubing that you then cover with a heavy plastic. They are portable garages. That would be the only thing I would park my Interstate in if I did not have a garage. Fortunately we have a large garage that is heated ion the winter and conditioned in summer and has a dump location, water and 540 amps.
Bikerbill is offline   Reply With Quote
Old 06-27-2014, 09:54 AM   #7
Lily&Me's Avatar
Normal , Illinois
Hmmm, we have not had a problem with ours, other than when we were using a cover, and like having AIRSTREAM across the front.
Love that you are an 05. We're the lucky ones, in terms of our engines.
Maggie
Old 06-27-2014, 11:45 AM   #8
UKDUDE's Avatar
Sedona , Arizona
Originally Posted by Bikerbill View Post
....and 540 amps.
Bill, please explain. I thought home amps from a standard outlet are 30. What do you have there?
Peter
Old 06-27-2014, 02:13 PM   #9
Newbie
joemikeb's Avatar
Fort Worth , Texas
Peter
FYI the world standard Type A outlet found in homes are only rated for 15 Amps at 120 Volts. You might find a circuit in your home with Type A outlets and a 20 Amp breaker, but it is a violation of electrical standards and a fire waiting to ignite should you ever try to pull a 20 Amp load through it. Thirty Amp 120 V circuits should have some sort of appliance outlet. In the accompanying photo of a campground outlet the 15 Amp type A outlet is on the right and the 30 Amp outlet is on the left. In order to get 30 Amp service for my AI at our house, I had to have a dedicated 30 Amp breaker installed in the circuit breaker panel and a dedicated circuit run to the outlet.
I too am curious about the 540 Amps, most homes are wired for no more than 200 total Amps
Make errors otherwise the Great Spirit realizes
you have finished your purpose on earth.
Navajo saying
joemikeb is offline   Reply With Quote
Old 06-27-2014, 02:32 PM   #10
2005 22' Interstate
I don't believe that this is correct. As I understand it, it is fine to put a 15 amp outlet on a 20amp circuit (assuming the wire is properly sized for 20 amp. The reason this is OK is that 15 amp outlets *can't* draw 20 amps, because the plugs of 20 amp loads have one of the prongs turned at right angles, so it will not fit into a 15 amp outlet. 20 amp outlets have an extra notch to accommodate the rotated plug prong.
(not to go off topic or anything.)
Old 06-27-2014, 02:33 PM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Actually, still not a good idea. Cover plus dust means that any dust that does manage to get under the cover turns the cover into fine-grit sandpaper.
In a wetter climate, a cover impedes ventilation, and leads to mold.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-27-2014, 02:46 PM   #12
1976 Argosy 24
It may vary from place to place but Joemikes point is the Electrical Code law in ONTARIO.
Sergei
Old 06-27-2014, 03:14 PM   #13
UKDUDE's Avatar
Sedona , Arizona
I'm also sorry to be completely off topic here, but I'm afraid I may be doing something very stupid and dangerous:
I have a Camco PowerGrip adapter that I use to plug the Interstate into a standard house socket in the garage. The PCI display panel then displays 30 Amps. I don't use any appliances in the Interstate while plugged in - it's just to keep the batteries maintained.
Are you saying this is not recommended?
Old 06-27-2014, 03:19 PM   #14
Newbie
joemikeb's Avatar
Fort Worth , Texas
Lets say you put a duplex or triplex outlet adaptor on your 15 Amp outlet, (they are readily available at any hardware store) and then plug a 10 Amp device into two of the outlets and turn them on. You are now drawing 20 Amps through a plug designed to handle no more than 15 Amps. The circuit breaker will not pop because you have not exceeded the load on the breaker. Several minutes later you will find the 15 Amp outlet is very hot. Maybe even hot enough to cause surrounding materials to reach ignition temperature. A 15 Amp outlet should be on a 15 Amp breaker. The breaker may never blow until the insulation on the wiring melts in the ensuing fire.
Navajo saying
winter cover for my 2004 airstream sprinter brucewaddell Member Introductions 1 06-26-2014 04:26 PM
Winter Cover- 2006 Classic ITowSilver 2006 - 2010 Classic (all lengths) 7 03-22-2006 08:16 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
Cover for Winter danesh Our Community 5 11-28-2005 01:56 PM
