Old 06-27-2014, 03:24 PM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by UKDUDE View Post
I'm also sorry to be completely off topic here, but I'm afraid I may be doing something very stupid and dangerous:
I have a Camco PowerGrip adapter that I use to plug the Interstate into a standard house socket in the garage. The PCI display panel then displays 30 Amps. I don't use any appliances in the Interstate while plugged in - it's just to keep the batteries maintained.
Are you saying this is not recommended?
If memory serves, the PCI display is for determining load-shedding. The energy management system will shut off appliances in sequence if the load exceeds the setting that's displayed; such as automatically interrupting power to the air conditioner when you start the microwave, until the microwave shuts off and the A/C can restart. If you have less than 30 amps available, you should manually reset the PCI to 20 amps (there is no setting for 15 amps that I recall). I believe it will automatically reset itself if you fire up the generator, which produces less than 30 amps.
If you leave it set on 30amps, the only downside is that you might trip a house breaker because your Interstate won't automatically start shutting off anything until the combined load hits 30 amps.
In your case, with nothing running but the inverter/charger in charge mode, no harm done.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-27-2014, 03:31 PM   #16
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Thank you Protag, we can always rely on your judgement.
Old 06-27-2014, 03:44 PM   #17
I believe you mean "…we can sometimes…" I don't always rely on my own judgment, so why should you?
WBCCI #1105
TAC LA-4
Old 06-27-2014, 04:46 PM   #18
UKDUDE's Avatar
Sedona , Arizona
I try to choose my words carefully since I frequently get into trouble when I inject my dry (very dry) English humour into the topic and its totally misinterpreted. So in this case I meant what I wrote.
Old 06-27-2014, 04:52 PM   #19
BikerBill
Poconos of Pa , Pennsylvania
Sorry about that. Typo not 540 amps but 50 amps. fat fingers on small keyboards and not proofing before sending. Yes our big garage has 200 amp service of its own and we have a dedicated 50 amp circuit for the m-home side. Originally we had a 40' bus which was 50 amps. I just plug in the 50-30 adapter for the Airstream.
Bikerbill is offline   Reply With Quote
winter cover for my 2004 airstream sprinter brucewaddell Member Introductions 1 06-26-2014 04:26 PM
Winter Cover- 2006 Classic ITowSilver 2006 - 2010 Classic (all lengths) 7 03-22-2006 08:16 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
Cover for Winter danesh Our Community 5 11-28-2005 01:56 PM
