Old 08-16-2010, 10:23 PM   #1
geoko
1995 19' "B" Van Airstream 190
Tucson , Arizona
Send a message via AIM to geoko
Thumbs up Intermittent generator operation
Generator on my 1995 B190 started becoming erratic. Had it serviced by competent Onan dealer and thought problem solved. It wasn't. On rework, found fuel line from under vehicle to generator was badly deteriated, so it was replaced. Still erratic. Finally dropped gas tank and found kinks in short stretch of generator fuel line was causing the intermittent fuel flow. Finally have dependable generator again. Cost of repairs would have been less had this all been done at one time. Suugest that all similar B190s of this vintage consider this solution if generator problems develop.
geoko is offline   Reply With Quote
Prodigy intermittent ol/sh?? 1JUICY1 Brakes & Brake Controllers 11 06-12-2010 08:29 PM
Intermittent brake loss problem solved 63air Brakes & Brake Controllers 2 07-27-2009 10:32 PM
Intermittent brake lockup gnored Brakes & Brake Controllers 27 03-20-2009 10:25 AM
Intermittent Chassis Vibration Chaplain Kent Mechanics Corner - Engines, Transmission & More... 29 10-29-2005 10:49 PM
intermittent water leak drcharles2 Plumbing - Systems & Fixtures 2 01-22-2004 11:32 AM
