Old 07-15-2016, 08:30 PM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Mr. B View Post
What on you put it, two-sided tape or epoxy?
It came with double-sided automotive tape. With the proper surface prep (scuff the track slightly with sandpaper to roughen it, then use an alcohol prep pad to get it really clean) AND if you wait a few minutes before rolling the door over it, it should stick perfectly. Neither thunderstorms nor direct sunlight nor continued use have managed to dislodge it.
The doorstop I installed was black anodized because the track on my Interstate was black.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-15-2016, 09:25 PM   #16
2015 Interstate Ext. Coach
Lake Mary , Florida
I also put it on the enclosed tape at first, but I did not like how it moves for a little bit once heavy door comes over stopper.
What I've done is: I scratched with a knife a needed rectangular portion on the rail until the black layer is gone and a naked metal comes. Then, using the Dremel rotary tool, I scratched the inner surface of my black stopper until it's anodized layer is removed to a naked metal. Cleaned with acetone, glued together both prepared surfaces with JB-weld epoxy.
Mr. B is offline   Reply With Quote
Old 07-15-2016, 09:36 PM   #17
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
One thing for sure, it'll be tough to remove.
Old 07-16-2016, 12:12 AM   #18
Lake Mary , Florida
I remember how I did remove some items, that I previously glued on JB-weld epoxy, from flat surfaces: put a chiesel to the sim and made one sharp kick of a hammer - and it goes out as a Shattle )))
Old 03-21-2018, 10:02 PM   #19
Lake Mary , Florida
Update. As of today it works like a charm !
Old 03-22-2018, 11:11 AM   #20
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Originally Posted by Protagonist View Post
My mistake.
I thought that you misunderstood too. But even so, your reply about putting multiple stops was on my mind. So, I am glad you were mistaken, coz you answered my un-asked question. Even your mistake helps someone 👍😉
Alex AVI is offline   Reply With Quote
Old 03-22-2018, 02:37 PM   #21
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Thumbs up
This is such a great mod. No more needing to fully open the door. Funny that they add a note letting you know that they did not forget to send it, lol... it is wrap around an ice cream stick, it is that small...
I fixed it in place with some JB Weld.
Only issue for my daughter is that it works too well... She can't close the door with one pull... must push a little to rock the door and and get it off the ramp. I guess that I could grind the edge just a little bit to make it easier to get off and roll... nah
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 03-22-2018, 05:49 PM   #22
Sebastopol , California
When i ordered mine 2.5 years ago I missed seeing the door stop behind the popsicle stick. The seller told me he was going to start adding a note, glad to hear he followed thru.
Sebtown is offline   Reply With Quote
Old 03-22-2018, 07:24 PM   #23
73shark's Avatar
If only MB would allow the power door option that's available in Europe. Maybe when they start building the Sprinters here they'll allow it.
Old 03-22-2018, 09:00 PM   #24
Lake Mary , Florida
Oh yes for sure the automatic door would be one of the greatest upgrades here, because to close it when the engine is running and AC is on - sometimes annoying. Need to slam the door few times to properly close it. And this task is certainly not for women.
Old 03-23-2018, 04:40 PM   #25
73shark's Avatar
Especially if you're headed uphill. Found that it helps if a window is open slightly.
Old 03-23-2018, 05:10 PM   #26
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
I notice that the window on the door is momentarily pushed open about an inch when the door is slammed shut. Apparently, enough elasticity in the mechanism to allow that much motion.
I'm not where I can look, but the other opening windows may also react to slamming the door.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 03-23-2018, 10:40 PM   #27
Lake Mary , Florida
Yes thatís right.
But you canít open and close the window every time you use side door.
Old 03-23-2018, 10:44 PM   #28
Lake Mary , Florida
Absolutely!
And you canít prevent it from this momentarily push open. Unless you permanently glue it with a liquid nail ))).
PS: another Airstream flaw suggested to be upgraded: just donít install an open-close window on the side door.
sliding door stopper. Billshop Sprinter and B-van Forum 6 07-07-2013 10:41 PM
Museum Quality 1962 Overlander Airstream-SHOW STOPPER! eBay Watch Airstreams on eBay 0 04-01-2010 03:00 PM
Bathroom sink stopper sieve Sinks, Showers & Toilets 2 02-03-2010 06:55 AM
Side-to-Side Flooring Replacement in Classic MH Eddy Repairing/Replacing Floor &/or Frame 12 11-03-2006 01:08 PM
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 03:19 PM
