Old 02-18-2016, 07:56 AM   #1
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
Installing TPMS
I have searched but could not find the thread.
Somewhere I read that before I install the TPMS I should apply some type of grease to the tire stem. Does anyone know what type of grease I should use?
Dalwyn is offline   Reply With Quote
Old 02-18-2016, 09:48 AM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I've never heard about applying grease to valve stems. But make sure you upgrade the inner dual tires to metal cable stems. Those stock rubber valve stems will fail if you attach a TPMS sensor on them. I have the TST system for last three years with good performance.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 02-18-2016, 09:48 AM   #3
ctdair's Avatar
I use anti-seize compound. The reason for the use of it is I have steel valve stems and the insert on the tire monitor is brass. The dissimimular metals could possibly
react and cause the 2 parts to seize together. Even if You have brass valve stems anti-seize would not hurt any thing.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 02-18-2016, 10:50 AM   #4
Images: 59
I don't know what the inner workings of the TPMS sensor look like. I don't use anti seize (my stems are brass) and I wouldn't use grease in case any got into the diaphragm of the sensor and fouled it. Low risk of failure, but I've never had a sensor get stuck on the stem either.
Old 02-18-2016, 10:57 AM   #5
Fulton , Maryland
Those valve stems you think are steel are probably plated brass.
- - Mike
- - Mike
Old 02-18-2016, 12:12 PM   #6
ctdair's Avatar
I don't know if plated or not but the plated metal would still react with the brass.
Please see pressure pro installation tips.
http://www.advantagepressurepro.com/...ad/Regular.pdf
NOTE - When installing Sensors on vehicles with aluminum valve stems: New autos may include factory installed TPMS Systems. New vehicles with TPMS utilize aluminum valve stems while PressurePro Sensors are made with brass threads. Brass will bond to aluminum due to the Galvanic action between the different metals. When installing PressurePro Sensors to aluminum stems, carefully apply dielectric grease, an anti-seize compound, to the aluminum stem being careful to apply only to the threaded area of the valve stem. IMPORTANT: Remove Sensors every 4 weeks to ensure that the aluminum stem and brass threads don’t bond. If storing the vehicle for extended periods, remove the Sensors from the aluminum stems.
S/OS #010
Old 02-18-2016, 12:39 PM   #7
Images: 59
OK, I'll agree with using antiseize if installed on aluminum stems. That makes sense.
Old 02-18-2016, 01:37 PM   #8
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Here's a couple of threads re: TPMS
http://www.airforums.com/forums/f240...ms-140047.html
http://www.airforums.com/forums/f240...em-137672.html
Old 02-18-2016, 02:53 PM   #9
Dalwyn's Avatar
Originally Posted by 73shark View Post
Thanks. I had already searched these and did not find what I thought I had read somewhere about applying grease around the thread of the valve stem before attaching the TPMS valve.
Appreciate everyone's comments.
Old 02-18-2016, 03:21 PM   #10
Fulton , Maryland
Applying a dielectric grease won't hurt and is definitely required for aluminum against brass.
- - Mike
- - Mike
Old 02-18-2016, 04:06 PM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you look at the galvanic series, aluminum is an anode for every metal except zinc and magnesium. That includes brass— the reaction between aluminum and brass is even worse than between aluminum and steel. So if you have aluminum valve stems and want to keep them when you add brass-threaded TPMS, use dielectric grease on the threads to exclude water and ensure that galvanic corrosion of the stems does not occur when the stems get wet, as they inevitably will every time it rains.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 02-18-2016, 06:44 PM   #12
1998 30' Excella 1000
Livingston , Texas
Exactly my thinking. And why I will not put a brass valve in the Atwood water heater drain hole. But I understand a lot of other people do, and don't report galvanic corrosion. Go figure....
Siegmann is offline   Reply With Quote
Old 02-18-2016, 07:29 PM   #13
I did it. I used thread tape to minimize metal-to-metal contact. But it's a lot harder to put thread tape on valve stems than on drain plugs, so dielectric grease, replenished from time to time, has to do the job.
WBCCI #1105
TAC LA-4
Old 02-18-2016, 07:34 PM   #14
Dalwyn's Avatar
Thanks everyone. I believe what I had read somewhere was about dielectric grease.
TPMS - Dill internal mount system wingfoot321 Tires 10 04-19-2016 08:39 AM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Installing TPMS sensors aliner Wheels, Hubs & Bearings 2 06-05-2015 09:59 AM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
Another TPMS... reday Tires 3 07-05-2009 04:53 PM
