Old 02-10-2014, 05:41 PM   #1
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Install Progressive Surge Protector
Installed in left rear corner alongside the shore power generator transfer switch is a Progressive Industries EMSHW30C Surge Protector with remote readout up in the electrical control panel. Cost from Amazon $269.50. Progressive does not supply a 4 conductor cord long enough to route up to the overhead but you can buy the wire and crimp-type ends from Radio Shack and make your own 4 conductor “data wire.” It looks just like telephone extension cord but the wires are not connected the same at the ends as it is for phones. I can now monitor my shore power, feel safe with high and low voltage and spikes. And it has a by-pass mode if necessary.
ID:	205313   Click image for larger version
Bikerbill is offline   Reply With Quote
Old 02-11-2014, 06:19 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Surge protectors are generally sacrificial; they commit suicide to protect the rest of your system from a significant surge. In other words, they'll protect from a lot of brownouts or other minor fluctuations, but only one surge from a lightning strike on the line or whatever. One reason why I never went with a permanent install; I use a portable surge protector, that's easy to replace if it ever gives its life in the performance of its duties.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-11-2014, 07:19 AM   #3
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I bought the progressive portable - but would be kinda nice installed permanent
PharmGeek is offline   Reply With Quote
Old 02-11-2014, 07:49 AM   #4
BikerBill
I don't like to have to worry about locking it to the post. People steal them when you're not there. Also, the Progressive DOES have a by-pass switch to allow you to override. AND since I know how to do the wiring, if necessary I can rewire in place to eliminate it completely. Different strokes for different folks. We can't all be like Henry Ford and hope that everyone drives a black Ford.
Old 02-11-2014, 08:28 AM   #5
No one has ever stolen mine, without locking it to anything. Or stolen anything else I've ever left out when I was away from camp for a few hours. Where do you camp that you have to worry about theft and pilferage, so I know to avoid those places?
WBCCI #1105
TAC LA-4
Old 02-11-2014, 09:30 AM   #6
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
I've never lost anything at a campsite either but due to the cost of the surge protector and the removable shore power cord I do lock them to the power post.
c21bill is offline   Reply With Quote
Old 02-11-2014, 11:43 AM   #7
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
I installed mine permanent but used connectors so I can easily by base it as mine does not have a by base switch.Click image for larger version
Name:	ImageUploadedByAirstream Forums1392144114.734421.jpg
ID:	205361Click image for larger version
Name:	ImageUploadedByAirstream Forums1392144196.174353.jpg
PSchw is offline   Reply With Quote
Old 02-15-2014, 09:15 PM   #8
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I also now use a portable surge protector, but would prefer a permanent install to eliminate one more thing I don't have to store and then drag out to hook-up.
The Progressive unit has this nice feature:
Modular Design:
Replacement parts are designed for simple plug and play, making repairs extremely user friendly.
So when the unit gets fried on a surge you just have to replace a circuit board and not the whole unit.
... and as Bikebill noted it also has a bypass mode.
- - Mike
Old 02-16-2014, 05:50 PM   #9
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Bought one of the permanent mount models from Phil May at last year's Alumapalooza. I really like it, especially the ability to constantly monitor inbound volts into my trailer. Was helpful last summer on a 103 degree day in a campground that was really struggling with adequate power. Really like the fact that this thing checks out the inbound power BEFORE bad stuff can happen from an improperly wired campground. Oh, and the surge protector is nice as well. It was very easy to install. I did it right there at JC, took about 40 minutes.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-05-2014, 07:49 AM   #10
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
Associated background noise ??
I've read where there maybe some background noise with installed units (TRC brand ) when they are running. Has anyone experienced with that with Progressive ?
LAWBC is offline   Reply With Quote
Old 03-12-2014, 12:23 PM   #11
BikerBill
Been sleeping now 2 weeks on the road and at campgrounds. My head is almost over location of my Progressive and no noise to comment on. If I listen very carefully I possibly can discern a slight and I stress slight hum. On a scale of 1-1-10 I'd place it at a 1 or less. I really have to listen carefully to even notice and when asleep nothing. In fact the BLM switching on and off to charge the engine battery is probably a 5+ as for any sounds and that's basically a click.
Old 05-02-2014, 06:10 AM   #12
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
I like the idea of a permanent install for one less thing to store and ease of use. On the other hand seems like the portable unit, once plugged in at the pedestal, will let you know if you have any power issues BEFORE you connect your RV to shore power. With a permanent install you connect first and then go inside to see what the monitor is telling you after you have already connected.
Probably am missing something here?
Ron_CA is offline   Reply With Quote
Old 05-02-2014, 06:18 AM   #13
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
That's my understanding as well and the reason we have a portable unit.
Doug and Cheryl
Old 05-02-2014, 06:45 AM   #14
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
When I plug mine in it does not conduct the electricity to the trade until all is well - it's about a 2 min delay after plugging everything in
Onan install – ’05 30’ Classic GetOutDoors Generators & Solar Power 16 09-10-2012 06:59 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Surge Guard Hookup Aquabud Batteries, Univolts, Converters & Inverters 2 07-28-2011 10:32 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
