Originally Posted by Bikerbill
... I do not remember any message from Progressive about NOT wiring the generator into it...
There is no issue with installing the EMS after the transfer switch and it will certainly monitor the generator power.
I chose to install my Progressive EMS before the transfer switch as recommended by Progressive tech support. I called them to make sure I understood their reasoning as mentioned in their FAQ. The transfer switch has built in electronics that can be damaged. They think it is more important to protect the transfer switch since it is a bigger risk from possible damage from bad power than monitoring the generator that has its own protective circuitry built-in.
Also you can use regular telephone cable to extend the remote display if you use 4-wire telephone cord, also know as data cord, rather than the 2-wire type which looks almost the same. You can tell the type of wire by looking closely at the colored wires in the clear plastic connector ends.
Photo of remote control installation attached.
