Old 03-22-2016, 12:04 AM   #1
2014 27' Flying Cloud
Seguin , Texas
Inner Dual Wheel Going Flat
Never owned a dually much less one that weighs as much as an Interstate. Currently parked at House. Is it OK to drive at least 20 miles on just the outer wheel? Closest tire place....
Laidback1 is offline   Reply With Quote
Old 03-22-2016, 05:31 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
No! The flat inner tire will shred itself and may do some damage to the wheel well. Not to mention that the outer wheel will be seriously overloadedó by almost two tons. It will blow out as well in very short order and then you'll have TWO flats.
Time to drag out the spare and use it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-22-2016, 07:46 AM   #3
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Can you pump it up with an air compressor and see if you can locate to cause of leak. Could be a screw or nail. Pull it and tempoarily plug and the drive to tire place.
Ron_CA is offline   Reply With Quote
Old 03-22-2016, 09:43 AM   #4
Correctionó the outside tire would be overloaded by almost one ton, not two tons. The tire would have a two-ton load on it instead of its usual one-ton load. But everything else about my response remains unchanged.
That's what happens when I start posting before my morning dose of caffeine.
WBCCI #1105
TAC LA-4
Old 03-22-2016, 10:21 AM   #5
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You need to update your profile so people know what you have. If it is a new Interstate, it should come with emergency roadside assistance. Call the number, and have somebody come to you and take care of the problem.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 03-22-2016, 11:32 AM   #6
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Yes do as overlander63 suggests! That's what I did when I discovered an inner dual flat at a rest stop on a trip through Arkansas. Coach-Net got someone to the rest stop in the middle of nowhere to change the tire for me. I drove about 100 mile that morning before discovering the flat. I was lucky - no damage to the van.
Old 03-22-2016, 04:32 PM   #7
Seguin , Texas
Oh dang, forgot about CoachNet. Good call Overlander! Also, thanks for the info on what not to do Protag!
Mark
Old 03-23-2016, 08:34 AM   #8
Ron_CA's Avatar
Just for arguments sake, I do believe with a properly inflated outside rear tire, that you would make it 20 miles easy. Not sure what the condition of your inner tire would be afterwards, but it would probably be just fine too.
Old 03-23-2016, 10:39 AM   #9
Fulton , Maryland
I would agree if stuck on a roadside and you need to get to safe place. But OP said they were parked at home. In that case I'd use the provided Coach-Net assistance. Driving with one dual flat is just a risk you may need to take sometimes.
One company Advanced RV once recommended driving with a single dual on a Sprinter since they didn't include a spare. After one of their owners, who I know, had a flat on a front tire and the roadside assistance company would not move one of the rear duals to front. So he was stuck until he could get a new tire.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 03-23-2016, 04:38 PM   #10
Denis4x4's Avatar
Durango , Colorado
I'd be curious to know if the OP had aftermarket valve extenders on the inside wheels. Had the same problem with a MH and fixed it with quality metal extenders installed on the wheels
If you don't go first class, your heirs will!
Denis4x4 is offline   Reply With Quote
Old 04-07-2016, 12:24 PM   #11
Seguin , Texas
Dennis,
Nope still had the stupid (I can't believe Mercedes Benz put a white plastic valve extender on a $150k+ vehicle) one. My bad for not changing it out. Recommendations for a good one?
Mark
Old 04-07-2016, 01:39 PM   #12
Fulton , Maryland
Dennis,
Mark
I went with the ones in this link about two years ago and have had no problems. They are designed for Alcoa outer and OEM steel wheels like we have on our Interstates.
http://yourtireshopsupply.com/produc...-valve-dl1spal
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 04-08-2016, 04:11 PM   #13
Ravenna , Ohio
Maybe no damage to the coach but what about the damage to the outer dual when you ran it at 100% overload?
It probably should be replaced.
This is a great example of why TPMS are good insurance and learning you have a tire loosing air can allow you to stop before you destroy one tire and damage its mate.
Tireman9 is offline   Reply With Quote
Old 04-08-2016, 04:37 PM   #14
Fulton , Maryland
Yes - I considered the outer dual tire damaged and replaced it. Also added a TPMS which I consider a must have safety system.
Thinking of going Dual A/C Mr & Mrs S Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-04-2011 05:48 AM
Dual system? Am I going to blow it up? robwok Batteries, Univolts, Converters & Inverters 0 03-24-2011 07:45 AM
mb 52 C going going...... goransons Refrigerators 5 08-23-2007 03:51 PM
dual wheel tire pressure jpurdy Tires 2 10-14-2006 11:03 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
