Old 05-08-2016, 07:25 AM   #15
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I hear less-knowledgeable RV'ers use the terms "inverter" and "charger" interchangeably all the time. Your neighbor is probably in that category. I would probably not take and stock market tips from him or her either.
Bob Martel
WBCCI# 5766
Old 05-08-2016, 07:49 AM   #16
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Originally Posted by gghayes View Post
We just replaced the 2 batteries that came with our 2015 interstate with 4 batteries in order to so some boondocking. My question is when should we use the inverter . The tech who put in the new batteries said to leave it off unless we want to watch the TV or use those plugs for other things when we are not hooked up to shore power. He also said we could let the batteries go down to 9 volts. From reading the forums some people say that at 12 Volts you are at 50 percent other forums say the inverter charges the batteries . Anyway I am totally confused . Can someone straighten me out.
Thanks Gloria
Is it possible he said 11.9? Not 9?
11.9 is more reasonable.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 05-08-2016, 11:39 AM   #17
2015 Interstate Ext. Coach
Tega Cay , South Carolina
Thank-you thank you. I finally understand how the inverter works. You all are great. No, scottinnj, he definitely said 9.
Gloria
gghayes is offline   Reply With Quote
Old 05-09-2016, 06:43 AM   #18
2015 22' FB Sport
Indianapolis , Indiana
listening
One of the many things I love about Air Forum is all the knowledgeable people. I learn things I haven't even had to ask yet Ha Ha!
Jim Arnold is offline   Reply With Quote
Old 05-09-2016, 07:06 AM   #19
BTB
San Diego , California
50%?
(Tongue in Cheek - to illustrate a point):
Wait - I can discharge my battery 50% before damaging it - isn't that SIX (6) volts???
I am confused!
BTB is offline   Reply With Quote
Old 01-30-2019, 09:01 AM   #20
Bshnid's Avatar
2019 Nest
2019 Nest
Phoenix , Arizona
Alarm for low battery?
Is there an device (iOS would be nice if away from rhe AS) to alert us when battery levels get below the half way point? Suggested products? Thanks!
Bshnid is offline   Reply With Quote
Old 01-30-2019, 12:42 PM   #21
richw46's Avatar
Lexington , Kentucky
Hi, you know you're replying to a 2 1/2 year old thread?
You should start a new thread to avoid confusion.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 01-30-2019, 03:03 PM   #22
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
A fully charged 12 volt battery measures about 12.6v. At about 12.1v it is half discharged. You can buy a small dc voltmeter on Amazon that you connect to the battery or any place you have a 12 volt light or receptacle for less than $20. Just make sure you check the voltage when the batteries arenít being used to power much of anything.
Dan
Old 01-30-2019, 08:44 PM   #23
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Here is a table showing the voltage versus the percent charged and an $8.99 voltmeter you can order from Amazon.
Dan
ID:	332662Click image for larger version
Old 01-30-2019, 09:42 PM   #24
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
On an Interstate, you don't need to buy a separate meter. The battery voltage for both the house and the chassis batteries is available with a button push on the tank monitor panel
John W. Irwin
WBCCI #9632
Old 01-31-2019, 01:58 AM   #25
Long Island , New York
FYI Bshnid, a good resource about RV batteries etc.:
http://www.batteriesnorthwest.com/ba...hool.cfm?TID=0
State of Charge: http://www.batteriesnorthwest.com/ba...cfm?TID=5#ANC5
FYI
Old 01-31-2019, 06:05 AM   #26
Zil
Curtis Wright
Eyren Haven , South Jersey
Reopen a 30 month old post with a relevant question? So What? If you know an answer, help someone. If not, make coffee.
Zil is offline   Reply With Quote
Misc. questions about a little bit of everything I don't understand... carmanahwoo 1970-79 Tradewind 4 10-09-2011 01:10 PM
Help Newbie Understand Numbers Craig Schrader Tow Vehicles 12 08-18-2008 06:47 AM
Trying to Understand How My Battery Works iHayley Batteries, Univolts, Converters & Inverters 11 07-19-2008 05:26 AM
Now I think I understand ... guy99 Commercial Listings 23 04-03-2006 02:36 PM
Please help me understand what these numbers mean joshua32064 Our Community 18 10-02-2003 07:24 AM
