Old 06-24-2013, 09:01 AM   #29
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by UKDUDE View Post
Sorry guys, I didn't intend to precipitate a heated argument on this topic. If you look at my opening post, you can clearly blame my wife for taking too long in the bathroom!!
I'll try to love my macerator in future.
You don't need to love it. Tolerating it should be enough. After all, it still has the crappy low-quality hose reel that winds up too fast and doesn't have a guide to keep the hose from binding.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-24-2013, 09:20 AM   #30
2005 22' Interstate
Pittsburgh , Pennsylvania
Actually, I am glad you did. The reason I made my contribution is that I am seriously considering doing a high-end Sprinter-based B-van build from scratch--as an upgrade of my '05 Interstate. If I do so, everything will be on the table, and discussions such as this help me to clarify my thinking. Again, I apologize if I pushed the thread beyond its original intent.
avanti is offline   Reply With Quote
Old 06-24-2013, 10:02 AM   #31
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Avanti,
You said "It is obvious that for a given volume of under-vehicle space, a single tank will have greater capacity than two tanks."
I don't think it's obvious at all. As long as we are willing to discuss the theoretical, it would depend entirely on the size and shape of the under-vehicle space. It's easy to visualize many scenarios where you could fit 2 25 gal. tanks but could not fit one 50 gal. tank.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 06-24-2013, 10:12 AM   #32
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Is this the hose reel that you have?
Shoreline Reels Black/Gray Water Hose Reel
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 06-24-2013, 10:19 AM   #33
Can't be certain without crawling underneath and finding a data plate or label, but I think so.
WBCCI #1105
TAC LA-4
Old 06-24-2013, 06:38 PM   #34
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
According to the owners manual my 2013 Interstate has a 27 gallon grey water tank and a 16 gallon black water tank -- still a 43 gallon total capacity. The fresh water tank is 26 gallons.
But you can fill 27 gallon grey tank quickly if you aren't careful.
- - Mike
Old 06-25-2013, 03:58 AM   #35
- - Mike
Son of a gun. After you posted this, I went back and checked my manual. You're right about the capacities. All this time I've been going by what the salesman told me, which was obviously wrong. Just goes to show that one should always read the manual cover-to-cover.
WBCCI #1105
TAC LA-4
Old 07-08-2013, 07:24 AM   #36
New user 2013 3500 EXT.
First long trip - 3 weeks for me and I learned a lot about hose, macerator, water use and dumping. I would like to share my experiences for my learning curve.
First, my hose pinched and cut open a few leaks. I removed 1" off my hose, replaced the fittings and put a screw on fastener to hold. Now I am careful how I reel up the hose.
My macerator failed because of paper. I tried to fix at various dealerships and everyone needed too much time (weeks) to fix. I pulled out owners manual and got a very big flat head screw driver, took off the rubber protective cover off the macerator screw and turned the screw clockwise until it freed up stuck paper. It was easier than I thought yet everyone was telling me all sorts of costly solutions. I decided to order a hand held bidet and installed from water supply supply on toilet. Although we use more water to black tank, it makes for a much more comfortable bathroom experience, especially for wife and now use very little paper if any. Also, I started using the GEO method for black water tank to help keep clean, this seems to work very well.
On water use, you really need to experiment how your use is. For example the first few days I found myself having to dump everyday. But after a while you become more efficient. My first night (no city hook up) I used too much water leaving my wife soapy for her first experience - this did not go over so well. Now we both know, for 1 night stay without city water but full tank water, we need about a third each for a shower and the other third for cooking, cleaning and toilet.
I found my dumping experience very easy once I fixed my macerator. I have a app that has dump sites, paid reasonable fees to dump and did the dump within 3 to 5 minutes. When I was in full service locations, I set up city water and dump hose and just monitored and dumped as necessary at two thirds to full. Again, just took minutes to do. Endless showers. I also ordered an outside shower for remote locations that I am looking forward to using soon.
Well, hit and miss for me, but I am very happy that I went through these issues to learn more about the capabilities, lack thereof and how to remedy by myself.
I had a wonderful trip and would rather sleep in the Interstate than at home, my home is not shabby at all, but I just love that vehicle. I too have a lot of suggestions and have started a few modifications as well, but overall a very good experience.
eliasurbina is offline   Reply With Quote
Old 07-08-2013, 07:49 AM   #37
Originally Posted by eliasurbina View Post
My macerator failed because of paper. I tried to fix at various dealerships and everyone needed too much time (weeks) to fix. I decided to order a hand held bidet and installed from water supply supply on toilet. Although we use more water to black tank, it makes for a much more comfortable bathroom experience, especially for wife and now use very little paper if any.
I find that a small covered wastebasket (with liner) for used toilet paper also works. If it never goes in the toilet, it can't clog anything.
The sponge is your friend. Fill the bathroom sink. Turn off water. Soak the sponge. Wet down with the sponge rather than the shower. Soap up. Turn on water. Rinse with shower head. You'll save a lot of water that way. Only use the shower head to wet down if you're washing an abundant head of hair, and turn it off as soon as you're wet.
Waterless hand sanitizer is also a great water-saver. Can be used on more than just your hands when you need a quick spot-wash. I use hand sanitizer on dirty feet, too.
Keep us informed on the mods. Especially if they're ones you found somewhere other than AirForums. They might be something we can use.
WBCCI #1105
TAC LA-4
