Old 08-22-2015, 06:15 PM   #1
k9jackie's Avatar
2015 Interstate Ext. Coach
Great Falls , Virginia
How can I set a truck route on the AI GPS
On my way through Connecticut this weekend, the GPS sent me nervously through a couple of parkways that had VERY low overpasses. I'm talking 8'8"!!! Luckily, I was able to get off the road and take a side street without overpasses but Id like to avoid this time suck in the future. Is there a way to set a "truck route" so I only go on roads without restrictions?
2014.5 Airstream Interstate Ext.
k9jackie is offline   Reply With Quote
Old 08-22-2015, 06:27 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Check out the Rand McNally RV GPS. Software designed for RVs and travel trailers. Including height restrictions. Always have to remember that GPS is only as accurate as the updates. I always keep track of my routes using a commercial paper atlas as back up.
MICHAEL
Old 08-23-2015, 07:05 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
There is no way to set a truck route on your built-in Kenwood/Garmin unit.
The way to avoid that predicament in the future is buy a separate GPS that does have that feature, as AWCHIEF suggested. I won't do that, because the map updates come from Magellan and I am boycotting Magellan for the rest of my life after a particularly bad experience with their customer service department. So what I do is this…
Since I have a smartphone and a tablet (both Android in my case), I got the Allstays Low Clearance app for the phone and tablet. I plot a route using Google Maps, cross-check with the Allstays low clearance app to see if that route offers any restrictions, and if it does, I simply click-and-drag the Google Maps route to a safer alternative.
Then I make a note of highway intersections along the route I chose, and when I program my route in the Kenwood/Garmin unit, I don't just enter the destination, I enter the key highway intersections as waypoints as well. That way the Garmin routes me exactly where I want to go, as opposed to where its program wants me to go.
I tried using Google Maps directly from my phone for trip routing during my last trip instead of programming the Kenwood/Garmin with half a dozen waypoints. It worked well enough, but I could barely hear the directions my phone gave me (can't put Google Maps on speakerphone, darn it!), which forced me to look down at the map every time I heard the phone mumbling at me, and that was kind of dangerous. My phone is a lot newer than the Kenwood/Garmin unit and the two don't pair via Bluetooth very well. I have a Bluetooth earpiece that I've never used with this phone that may pair up better, that I'll try on my next trip. If that works, then I'll give up using the Garmin and just use my phone for trip routing.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-23-2015, 07:17 AM   #4
2014 Interstate Ext. Coach
melrose , Massachusetts
We use good sam's trip planner to map out our routes
It flags all restrictions including overpass heights and tunnel propane restrictions.
jennian is offline   Reply With Quote
Old 08-23-2015, 07:40 AM   #5
Rats's Avatar
Hilliard , Ohio
All parkways in New York, MA, CT mostly New England are truck restricted. There are signs posted at entry ways warning low clearance . Be safe do not use any parkways in New England.
Rats is offline   Reply With Quote
Old 08-23-2015, 07:45 AM   #6
AWCHIEF's Avatar
Images: 33
The new 2016 commercial motor carriers atlas is out. One of the best features is the over head heights are clearly labeled.
http://www.amazon.com/gp/product/052...=ATVPDKIKX0DER
MICHAEL
Old 08-23-2015, 10:38 AM   #7
k9jackie's Avatar
Thanks for the tips... I'm still kind of mad at airstream though. You'd think they'd equip our spaceships with the appropriate GPS systems for 150k!
Old 08-23-2015, 12:00 PM   #8
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I agree that the Garmin Nav in our Kenwood is not great. It's way too slow at recalculating an alternate route if you make a wrong turn in a large city like Chicago. As a backup I use the Copilot App on my iPhone. It recalculated very fast and has saved me more than once. Copilot does have an RV mode that takes height restrictions into account. However they are only set table to 12'-6" or 13'; that's plenty safe for our Interstates.
AWCHIEF - thanks for the tip on motor carrier atlas. I'm adding that to my paper backup strategy in place of the regular atlas I use now.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 08-23-2015, 12:13 PM   #9
Center Moriches , New York
My Rand McNally 7710RVND has tried to get me on NY parkways more than once. NY parkway overpasses can be LESS than 8'. My new Dynamax DX3 had Rand McNally 720 software pre-installed and, has tried to get me on NY parkways too. While there is NO "perfect" GPS software, in my opinion, Rand McNally is at the bottom of the pack.
I am having better luck with CoPilot software. It can be purchased for iOS, Android or Win OS computers (it's NOT available for Mac OS computers even though it runs great on iOS).
NY24 is offline   Reply With Quote
Old 08-23-2015, 12:53 PM   #10
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Most Smartphone maps are reliant on having a data connection, as the maps are not stored locally in the phone. In areas with bad reception, you could be out of luck. Plus you are burning through your data plan.
I use the Garmin RV 760 which has a means to program in your RV information and it then routes accordingly. It also supports a wireless rear view camera, which I currently have peering out my back window.
The nice thing about the Garmin is that it works in conjunction with PC based software; BaseCamp. You can do all your planning and routing from the comfort of your computer (large screen, mouse, keyboard) and then transfer all waypoints and routes to the GPS. After your trip, you can also transfer your tracks from the GPS to BaseCamp to see where you have been and assist in future planning. I don't believe any Smartphone apps have this capability.
Greg
greghoro is offline   Reply With Quote
Old 08-23-2015, 01:13 PM   #11
In a five-hour trip using Google Maps from my smartphone for trip routing, my phone only used a tiny fraction of my 3GB monthly plan. If I was using the phone for trip routing every day, then I might be concerned, but for one trip a week or less, no worries.
WBCCI #1105
TAC LA-4
Old 08-23-2015, 03:56 PM   #12
Fulton , Maryland
Greg
The Copilot App for smartphones does not require a data connection - that's why I bought it. For the current price of $10 you get maps of North America, which is about 2.5 GB on my iPhone. It worked great on my Alaska trip last summer and all the Canadian trips we've made over the past few years.
That Garmin RV 760 sounds great if it interfaces with PC software. I have been using Microsoft Streets &Trips for my planning. But Microsoft dropped this product so you can't get updated versions with good POI data.
- - Mike
- - Mike
Old 08-25-2015, 05:58 PM   #13
Tega Cay , South Carolina
The good Sam's Rand mcNally GPS works great when it works. It too quit working (along with my refregerator, step, black tank pump) on this trip to the Michigan UP. It keeps saying battery not charged. We called Rand McNally and they told us to return it when we get home. Meanwhile I use my Ipad, phone and the sprinter GPS. Not much fun
gghayes is offline   Reply With Quote
Old 08-25-2015, 06:11 PM   #14
UKDUDE's Avatar
Sedona , Arizona
Greg
I just returned from a trip to the UK, and using the free Waze app installed on my Verizon iPhone, I was able to navigate around with the iPhone in Airplane Mode so it wouldn't roam to any unwanted signals. It has a GPS chip.
Rand McNally GPS Rand McNally TripMaker RVND 7710 7-Inch GPS adonh Computers, Internet & Satellite 5 03-26-2013 09:39 AM
Questions on hitch set set up for my Dodge Astriking Hitches, Couplers & Balls 13 04-25-2011 05:03 AM
GPS for truck routes.. khlear Phone, CB & Ham Radio 13 10-23-2009 09:24 PM
Low Bridges - can GPS help? Trooper-D Our Community 12 08-03-2009 10:44 PM
To GPS or not to GPS? autoist Airstream Motorhome Forums 8 02-27-2003 09:03 AM
