Old 03-13-2015, 01:26 PM   #1
X New Yorker
X New Yorker's Avatar
2013 Interstate Coach
Springfield , Massachusetts
How can I secure my potable water access?
So... I pretty much lock-up everything (I live in the city and hail from NY), and it is driving me nuts that it seems the only thing not locked on my Interstate is the potable water access. I think the water I will use it pretty important and I have already had to tell a couple of gas station attendents - hands off! Not to mention my biggest fear is some nut or kid playing pranks will put something in there.
I think safe water is pretty important, but apparently Airstream doesn't as the dealer could not find a solution for me with them. Any suggestions or ideas?
X New Yorker is offline   Reply With Quote
Old 03-13-2015, 01:39 PM   #2
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Locking cap?
BambiTex is offline   Reply With Quote
Old 03-13-2015, 01:42 PM   #3
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Marine Style Water Fill
Old 03-13-2015, 01:51 PM   #4
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
A locksmith will be able to put a locking cover on your fill tube.
Eagle & Bear is offline   Reply With Quote
Old 03-13-2015, 02:14 PM   #5
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
There was a similar thread a while back:
http://www.airforums.com/forums/f240...ty-116084.html
Old 03-13-2015, 02:44 PM   #6
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
http://www.inlandrv.com/catalog/images/14725.jpg
Old 03-13-2015, 03:36 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Part of the problem there is that the fuel filler is hidden, so someone who doesn't know Sprinters will reach for the thing that looks like a fuel filler. The best answer for that is to put a label on the side of the van that says "Water Only" right over the fresh tank fill.
Not as bad as someone adding sugar to the fuel (does anyone still do that as a prank?) because you'd have to add a lot of sugar to a 26-gallon water tank to make the water undrinkable; all you'd have to do to fix it is pour Kool-Aid powdered drink mix in as well, drive a mile or two over a bumpy road to stir thoroughly, and you're all set!
But seriously, I second BambiTex's recommendation; unlike drboyd's suggestion, BambiTex's is almost a direct bolt-in replacement and doesn't require doing any cutting on the side of your van. Be sure you get at least three keys; one to put on the keyring with each of your van keys, and one to keep twist-tied to your freshwater hose with a piece of wire so it's there every time you fill your tank.
Cats and ultraleather Airstream upholstery don't mix!
Old 03-13-2015, 04:45 PM   #8
toskeysam's Avatar
Townsend , Tennessee
Just tried to order the Marine Style cap.....out of stock. They are supposed to email me when it is available.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 03-14-2015, 04:57 PM   #9
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Search marine suppliers for the same item. West Marine, Defender, Fisheries Supply. It's made by either Perko or SeaDog.
Here's the SeaDog product page:
Sea-Dog : Quality Marine, Industrial and Rigging Hardware
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 03-14-2015, 06:17 PM   #10
Boxster1971's Avatar
Fulton , Maryland
The PERKO “locking insert” #0525DPOBLK is the only locking device that will work on the Interstate's water filler. It is available from Amazon and other sources. I have one and it does work OK, just I bit tricky to remove. It requires a bit of finesse.
http://www.amazon.com/Perko-0525DP0B.../dp/B00144AIAI
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 03-17-2015, 01:11 PM   #11
Reno , Nevada
so has anyone actually installed the stainless Marine Style Water Fill that was suggested by BambiTex and seconded by Protag? It looks like a nice product, but how simple to install? Can it be done completely from the outside of the Interstate?
EddieTheWire is offline   Reply With Quote
Old 03-17-2015, 01:20 PM   #12
Haven't installed one, but I'd say you probably need some inside access, if only to connect the fill port to the tank's filler tube. I don't think there's enough slack in the filler tube to pull it out to make the connection.
Old 03-17-2015, 05:10 PM   #13
BikerBill
Poconos of Pa , Pennsylvania
Yup Perko is the way to go. Intact I have one that I removed when I traded off my Airstream last year. Have not taken the time to post it for sale. If you are interested, send me a private message.
Bikerbill is offline   Reply With Quote
Secure water fill cap for safety Bikerbill Sprinter and B-van Forum 3 02-11-2014 10:44 AM
City Water Connection to Potable Tank? Motoman Fresh Water Systems 2 12-19-2006 06:22 AM
No Potable Water Key Lee Davis Doors & Locks 3 11-07-2005 08:10 PM
Potable water balrgn All Argosy Trailers 4 03-11-2005 11:07 AM
Potable Water Tank Lee Pace Fresh Water Systems 4 09-01-2004 07:44 PM
