02-23-2018, 04:14 PM
#21
2014 Interstate Ext. Coach
Boca Raton
Well
The new lifelines came in today and are already installed. Stayed with the GPL24T 12v’s.
It so nice to have ‘fresh’ power. Forgot what it was like.
07-28-2018, 10:07 PM
#22
2020 27' Globetrotter
Taylor Ridge
Originally Posted by FlyFishinRVr
Check out what Mister B has done. For about the same money, if you can fit 2 6V 220Ahr deep cycle AGM batteries into your coach, you're better off. The 6V batteries are more robust due to their greater plate thickness (i.e. they can generally take more abuse), and at 220Ahr vs. a total of 160Ahr for 2 of the 12v model, you get 30% more capacity. It's a win any way you look at it. Not sure how much brand matters in this scenario, but certainly Lifeline has a great reputation, both in the RV and marine industries.
I have decided to go this route to replace my almost 5 year old 12 volt Lifelines.
Since I will be putting in two 6 volt batteries wired in series do I need to change my three stage charging settings?
07-29-2018, 06:24 PM
#23
2024 Interstate 19
Fulton
, Maryland
Depends on what type of batteries you are installing. If they are the same Lifeline brand then the charge stage voltages are the same. You may have to make a change for the new capacity of two 6V's.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
08-04-2018, 06:40 AM
#24
2015 Interstate Grand Tour
Rancho Mirage
8D Battery
I recently bought a 2015 Grand Tour and the two house batteries were bad. I had a new Lifeline 8D battery out of my Class A motorhome so I modified the two battery brackets and made one bracket the holds the 8D battery. I believe it will provide almost as much power as 4 of the group 24 batteries.
08-04-2018, 02:33 PM
#25
2017 Interstate Lounge Ext
Jacksonville
, Jacksonville, Fla, Sautee, Ga, Boca Grande, Fl, Breckenridge, Co
Great idea. How hard was it to modify, how did you do it? Should have asked about the location of the batteries in your unit first. Thanks
08-04-2018, 02:47 PM
#26
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
So I guess that the "without any mods" part of the title is now out ...
Take a look at lithiums. They give you way more power in a finite sized package. They can drop in without any changes to your electrical system.
08-04-2018, 08:10 PM
#27
Rancho Mirage
I took the two factory battery boxes that are riveted to the unibody on the drivers side behind the rear axel and drilled out the factory rivets, thane took a grinder to separate the welds creating two halves. A left and right half. Then welded a piece of steel spanning the two halves on the bottom and then a piece to join the back two halves. I cut the bracket that holds the batteries into the bracket to create a "keeper" to hold the 8D in place and utilized the factory bolts. Then I drilled out the holes in the unibody and installed Riv Nuts to hold the bracket to the unibody.
08-04-2018, 09:11 PM
#28
2024 Interstate 19
Fulton
, Maryland
MAIL4SBLAIR - nice job. But how did you get that heavy 8D into that bracket under the van? I installed four 6V's in two custom swing-down brackets behind the rear wheels, two on each side under my 2013 Interstate. I used a small floor jack to lift them in place. It was a real struggle to get them mounted. I can't imagine doing it with an 8D.
- - Mike
08-05-2018, 06:15 AM
#29
Rancho Mirage
I used a forklift that I have in my shop. I put to 2x6's on the forks and laid the 8D on it's side on top of the 2x6's, this gave me clearance between the body and the forks. Once I had it up into position I had to tip the top of the battery back slightly so it would clear the frame rail. I had my wife run the forklift while I typed the battery back and slid it in. I think I could have done it with a floor jack but, the forklift was the easy way.
08-05-2018, 04:34 PM
#30
2024 Interstate 19
Fulton
, Maryland
Thanks for the info. I stayed away from going with an 8D battery mostly due to weight limit I could handle. The 6V Lifelines were at my limit.
- - Mike
08-05-2018, 05:49 PM
#31
Taylor Ridge
Thanks Boxster!
08-05-2018, 07:50 PM
#32
2013 Interstate Coach
Idaho Falls
, Idaho
Boxster - I don’t want to hijiack this thread but I would be interested in seeing pictures of your battery racks. I have been considering doing the same thing.
08-05-2018, 09:19 PM
#33
2024 Interstate 19
Fulton
, Maryland
Here is link to my thread on the battery upgrade I did in 2015.
http://www.airforums.com/forums/f240...de-142327.html
- - Mike
08-06-2018, 05:39 AM
#34
Idaho Falls
, Idaho
Nice install. Thanks.
08-06-2018, 09:53 AM
#35
2024 Interstate 19
Fulton
, Maryland
Thank you. After reading it again yesterday I realized that I never updated the thread with final photos. I’ll do that later today.
- - Mike
