Old 12-12-2016, 11:48 AM   #1
2016 Interstate Lounge Ext
Lake Oswego , Oregon
house battery seem dead/ shore power dead
Drove to a golf outing, parked for 3 days (I thought, everything was shut off)
Get ready to return, no lights in interstate, and no kenwood radio, house batteries seem dead. (The Sprinter, has been rock solid, airstream, not so much) Get home, hook up shore power... no difference, everthing seems dead. except for the • No Comm - Remote is not receiving any information from the inverter. that is lit up. I disconnected, the inverter remote switch and reconnected it, per instructions, with no change. reads....NO Comm.
I have an 2016 extended lounge. Any Ideas?? anyone know where the actual "inverter" is located on this version? The Magnum booklet say that I should reset the inverter. no sure where that is.
any help is appreciated. seems like it's something, every time out.
joe rv guy is offline   Reply With Quote
Old 12-12-2016, 12:10 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
IIRC, it's under the street side rear side facing seat. could be wrong tho.
Old 12-12-2016, 01:32 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Inverter/Charger is under the read lounge seat. Easiest way to get to it is by removing the four screws that hold the back panel of the compartment under the lounge seat, also need to remove two screws that hold top to back panel. Get to them via rear doors, remove the black fuzzy covering and you should see the rear panel. The inverter is bolted to this back panel, but you can just drop it down with inverter attached as there is enough wire to allow access to the inverter.
Old 12-12-2016, 03:41 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
I may be mistaken, but I think the latest Lounge model may now have the same configuration as the Grand Tour, i.e. the Magnum under the driver's side jump seat. In which case it could be a lot easier to access.
Old 12-12-2016, 06:16 PM   #5
73shark's Avatar
That was my recollection too.
Old 12-12-2016, 09:21 PM   #6
Fulton , Maryland
My Bad, you and 73shark are correct. I've attached clip from the 110-Volt Location Route diagram in 2016 owners manual (page 9-31) showing location of inverter (INV1).
Old 12-12-2016, 11:38 PM   #7
FlyFishinRVr's Avatar
2017 Interstate Lounge Ext
Northern , California
If I remember correctly from my walkthrough, the reset button is on the top of the Magnum and can be accessed through the mesh on the top of the metal box that it sits in. Just lift the driver-side rear seat and use something like a screwdriver to press the button until the status LED starts to blink, then let go. It's a 30 second process and should restore COMs. If it doesn't, yours may be suffering from a faulty cable that others on this site have reported.
FlyFishinRVr is offline   Reply With Quote
Old 12-13-2016, 07:37 AM   #8
house-battery-seem-dead-shore-power-dead
thank you all for your help in locating the inverter. wonder how one gains access.??
here's what airstream asked me to do......It sounds like the relay for the battery disconnect is unable to get enough power to kick over and is therefore not allowing a charge to go through to the house batteries when plugged into shore power. Try running the engine for about 25 minutes and see if the fault NO COMM goes away. If it does, plug the unit back into shore power with the engine still running, and set the battery disconnect to the use position. Let it run for another 5 minutes or so and then shut the engine off. If that doesn’t do the trick, then we’ll need to take a look at the vehicle as the relay solenoid may have failed.
I'll be trying this, and let you know how it goes.
Old 12-13-2016, 04:46 PM   #9
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
This very same thing happens to me with my 2009 classic TT. After looking at disconnect relay (what a mess getting to it) I decided to charge the batter with a aux battery charger. After about an hour charging at 20 amps I tried the disconnect switch. All was back to normal. I would have thought that you would be able to charge the batteries through the shore power, but with the batteries disconnected the internal battery charger is also disabled. Now I know why I carry this 1952 batter charger weighing around 15 pounds around with me in my emergency pack. It's old, but like me, still work better than the younger ones. Once you get the batteries over 9 VDC you should be okay to reconnect the batteries with the switch and finish charging with the shore power. I think I am going to add a couple of 10 ga lead off the battery so I can charge the battery without removing the battery from its housing.
Hope this helps. Happy streaming....
gr.austin is offline   Reply With Quote
Old 12-13-2016, 04:57 PM   #10
San Jose , California
We have a 2016 Interstate Grand Tour Extended and a similar thing happened to us when we were on the road. Turns out it was a bad inverter solenoid. Replaced it and we were back on the road the same day.
pleight is offline   Reply With Quote
Old 12-13-2016, 05:53 PM   #11
I've got an appointment set with Airstream and they seem to think it's the solenoid as well. I'm not going in, until Friday as our weather here stinks for the next couple days.
I'll keep you posted, and thank for all the input, appreciate it!
Old 12-14-2016, 07:37 AM   #12
2017 Interstate Grand Tour Ext
Bozeman , Montana
Had the same problem with 2016 Grand Tour Ext. Ran the engine about 20 minutes and Comm was re-established, did not need to reset the inverter. Might be worth a try.
ArcherTC is offline   Reply With Quote
Old 12-14-2016, 02:57 PM   #13
house-battery-seem-dead-shore-power-dead-
I hooked up a Battery Charger to the house batteries and wow it must have triggered that disconnect relay solenoid, and it's charging and getting back to normal. Should I still have that disconnect relay replaced?
Old 12-14-2016, 03:13 PM   #14
Bellevue , Washington
That solenoid creates nothing but grief with no value. I would ask them to bypass it or look for a thread here on SB160 and do it yourself.
amirm is offline   Reply With Quote
Old 12-14-2016, 08:47 PM   #15
Fulton , Maryland
Correction - search for SB164, not SB 160, to find info on this solenoid. Here is link to first main thread that discussed it.
http://www.airforums.com/forums/f240...aw-144101.html
Old 12-15-2016, 07:42 AM   #16
2015 Interstate Ext. Coach
Vienna , Virginia
Here is another thread on the topic. I followed Lewster's advice and bypassed the solenoid. I've had no problems since.
http://www.airforums.com/forums/f240...mm-145217.html
Dennis
bigfishdog is offline   Reply With Quote
Old 12-15-2016, 01:52 PM   #17
Dennis
Just just to recap for myself and others, if you bypass this solenoid, you end up with the Magnum drawing 0.5A per hour just sitting there, even with nothing on (Main Disconnect is OFF, i.e. red LED off, no power to house), correct? So people like myself who maintain their coach via the stock 100W solar panel would need to recover an additional 12A per 24hrs, correct? If so, this wouldn't work, at least for me. The 100W solar panel just barely keeps my batteries healthy as is. An additional 0.5A per hour draw would kill my batteries, slowly but surely......
@Amirm, I presume you installed a manual disconnect for your inverter in your new Lithium build, or don't you care given your 400W solar setup? Or maybe your new inverter doesn't have this parasitic draw when "off" so it's moot? Just trying to figure out what my future looks like.....
Old 12-15-2016, 04:14 PM   #18
Vienna , Virginia
The problem I was solving was the NO COMM caused by the poor quality solenoid that AS used for the service bulletin. The 0.5A draw hadn't been a problem for me but I can see that it could be for others. I think one of the threads recommended a better quality solenoid.
Dennis
Old 12-15-2016, 05:32 PM   #19
Dennis
If you're plugged into shore power, you're right, the 0.5A draw makes no difference, so you should be fine if you decide to bypass it and eliminate that worry.
As for a replacement for the solenoid, something with a 200A capacity seems to be the popular choice so far, so I'll probably look into that at some point just for peace of mind. Since I currently maintain my rig via solar, I really don't need to address it any time soon.
Old 12-15-2016, 10:42 PM   #20
I only have a 100 watt solar and it doesn't do much this time of year in pacific northwest.
But yes, I redesigned the system so that the current motorized disconnect is a true master disconnect. It shuts off everything including the inverter power.
I leave it plugged in all the time though so it is not a concern in my situation.
Battery Good No DC Power with shore power off. F Ross Batteries, Univolts, Converters & Inverters 18 10-25-2018 11:06 AM
Long Term Shore Power and House Battery cbrittan Batteries, Univolts, Converters & Inverters 30 11-02-2015 02:15 AM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 02:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 07:32 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 09:23 AM
