Old 08-03-2011, 06:35 AM   #1
ben322's Avatar
2009 Interstate
Bethesda , Maryland
House Battery Power Access Upfront
This is more applicable towards 2008+ Interstate Models although AS wiring may be similar.
I decided to add another radio/DVD/MP3/monitor in the single DIN spot above the Sprinter front interior lights but powered by the house batteries with use of the inverter. I was going to access the 12V outlet in the overhead storage compartment but found an extra set of unused power leads in the wiring bundle above the drivers head once I had the panel removed. The only thing about the wiring was the color, (Black +, White -), which you should check anyway.
In any case, if you need switched house power with 10g leads upfront, it may be up there already.
Ben
Name:	Overhead Harness.jpg
ID:	136594   Click image for larger version
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 08-03-2011, 08:30 AM   #2
ben322's Avatar
2009 Interstate
Bethesda , Maryland
Sorry, I meant to say "without" use of the inverter.
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Battery fixed; now on to DC power silverdream2 Classic Motorhomes 4 06-21-2011 12:01 PM
Radio on house battery michalakes Electrical - Systems, Generators, Batteries & Solar 1 01-05-2011 02:07 AM
