Old 10-18-2015, 02:48 PM   #1
2013 Interstate Coach
Virginia Beach , Virginia
House battery drainage
After charging the house batteries using shore power or solar with the batteries off .....
once turned on the battery's drain quickly, any ideas? Thank you in advance.
nancyo is offline   Reply With Quote
Old 10-18-2015, 03:34 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Get a hygrometer and test them. All cells should be equal. If one or more cells are lower than the rest they will pull the system down.
This is something you can do if you know how to get to the batteries.
A common problem when batteries are grouped.
2004 Excursion 4x4
Old 10-18-2015, 05:03 PM   #3
iaqstuff's Avatar
Yarnell , Arizona
Battery drainage
I'd suggest you read Lifelines Technical Manual regarding your sealed AGM batteries . It can be found at www.lifelinebatteries.com/manual.pdf
It should answer your question, along with the many more that you're likely to have as you consider how to resolve your issue.
Mine were sulfated and swollen to the point that I had to trim the molded casing in the area that held the carrying straps to get them out of the
sealed battery compartment. Two new batteries cost me about $300 each from a non-Airstream dealer (the dealer wanted $450 each plus $240 installation).
iaqstuff is offline   Reply With Quote
Old 10-18-2015, 09:20 PM   #4
Boxster1971's Avatar
Fulton , Maryland
Nancyo - your profile says you have a 2013 Interstate, which should have Lifeline AGM batteries unless they have been changed since new. HowieE's suggestion to use a hygrometer won't work on Lifeline AGM batteries as they are sealed. A RV or battery dealer that is familiar with AGM batteries can test them for you.
If you can give us more history on your Interstate and the typical use the group here may have more suggestions. What do you mean by the statement that the batteries drain quickly. What length of time are you indicating with what equipment turned on? Have you ever drained these batteries totally flat? Have you had this van since new?
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 10-18-2015, 09:53 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
The latest, most accurate method for battery testing is a device called a 'conductance meter'. The good ones are not cheap ($650+) but once programmed with the particular characteristics of the battery in question, it will provide a useful and accurate answer to whether the battery is good or not.....and by how much!
If you don't have the time (many hours usually) to perform a draw-down test at the stated 20 amp rate, then a conductance meter will provide you with a definitive answer.
Be sure to ask the tech looking at your batteries if the facility uses one. If not.......find one that does!
Old 10-19-2015, 06:26 AM   #6
This forum is awesome . Thanks all for responding.
Mike
We bought it used, previous owners used it once or twice and decided it was not for them.
We started with a full battery, drove 5 hours, with battery on using nothing but fridge, left over night again with battery on. Next day battery was at 0. We tried to plug in to shore power to charge or just start generator and got nothing. Thank you again for replying
Old 10-19-2015, 05:51 PM   #7
Fulton , Maryland
Previous owner probably didn't keep the batteries charged if they didn't use it much. The batteries will go flat in 3-4 days if the van isn't plugged into show power.
Full charged battery should be able to run the refrigerator overnight. Sounds like you do have bad batteries and need to get them checked. You van start the Sprinter engine and then have enough power to get the generator started. That a nice feature of having the Battery Isolation Module (BIM) that connect the two battery systems together with smart electronics. The Boost switch in the lower dash under the steering wheel on left side will force the relay connecting the two battery systems together.
- - Mike
- - Mike
Old 10-19-2015, 06:39 PM   #8
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
- - Mike
If everything is turned off, then the solar should keep the batteries @100%.
Old 10-19-2015, 07:01 PM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Assuming you park in direct sun, of course…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-19-2015, 07:28 PM   #10
73shark's Avatar
Not necessarily. I've seen a charge rate on overcast days.
Old 10-20-2015, 08:06 AM   #11
Fulton , Maryland
Since nancyo has the same model, 2013 Interstate, as mine with only a 50 watt solar panel it would have to be in direct sunlight all day for the batteries to stay charged. Yes it will get charged with overcast sky but not so much in a shaded area. I park my van in the driveway behind my tall townhouse on the north west side. It only gets direct sunlight about 5-6 hours a day. That was not enough to keep my batteries charged. It needed to be plugged in after 3-4 days. With my upgraded 400 watt solar system the batteries stay charged.
- - Mike
- - Mike
Old 10-21-2015, 07:26 PM   #12
2014 Interstate Ext. Coach
Antrim , New Hampshire
Open the battery compartment, pull out the tray and you will likely see that the batteries are swollen. Get yourself an electronic battery tester like a Solar BA5. Good chance your batteries can no longer hold a charge. They appear to be charged but go down quickly.
felixkagi is offline   Reply With Quote
Old 10-21-2015, 07:45 PM   #13
Thanks all for info
Old 10-21-2015, 09:15 PM   #14
Only the EXT models have a pull-out battery tray. The non-EXT sofa/lounge models require disassembling the sofa to perform a battery-ectomy. Kind of like pulling teeth through the sinuses…
WBCCI #1105
TAC LA-4
Refrigerator and battery drainage nesoutlook Sprinter and B-van Forum 26 01-28-2015 05:08 PM
ABS drainage system - 2005 Classic RoadToad 2001 - 2005 Classic 16 01-29-2009 01:36 PM
Urgent vintage grey water drainage question! 1959newbie Waste Systems, Tanks & Totes 6 04-21-2007 09:58 PM
Water Tank Drainage popeyedoyle1 Fresh Water Systems 8 03-07-2006 04:50 PM
16' ccd Bambi drainage system question. gbrentsmith Waste Systems, Tanks & Totes 12 10-17-2005 09:08 PM
