Old 01-13-2014, 06:15 PM   #85
2006 22' Parkway
Lubbock , Texas
Thank you, I will look into that. Leads to another question, do AGM batteries need a special charger or care? Would the charging system on the Parkway be ok?
electrodx is offline   Reply With Quote
Old 01-14-2014, 01:39 AM   #86
lewster's Avatar
Naples, FL , Hood River, OR
That depends. The better the charging system, the longer the battery life. What do you have now?
Old 01-14-2014, 08:04 AM   #87
2006 22' Parkway
Lubbock , Texas
It is a Magna Tec 7355 converter/charging system.
Old 01-14-2014, 09:18 AM   #88
lewster's Avatar
That unit will not do, as it does not have 3 stage charging. A better choice is a PD-9255 with Charge Wizard from Progressive Dynamics, but that is still not optimal.
The BEST charger for Lifelines is a Magnum inverter/charger with fully adjustable charging profiles and temperature compensation. They keep Lifelines very happy.
Old 01-14-2014, 09:39 AM   #89
2006 22' Parkway
Lubbock , Texas
Thanks for all your help. I feel empowered!
Old 01-14-2014, 10:21 AM   #90
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
@lewster.....Awhile back I commented I had never seen "Full Charge" on my inverter contrl panel. I have the MMS1012 Inverter Charger with the remote panel. The manual discusses its 4-stage charging profile....bulk,absorb,float, and full charge. Like your response earlier, I felt "Float" meant the batteries were indeed full and float just kept them topped off. The manual also states that in "Full Charge" if the battery voltage drops below 12.7 it initiates another "float" cycle......I am wondering if that is why I have never "seen" a full charge on the panel....I just may not be catching it....and/or I may have a drain I have not identified. your thoughts??
toskeysam is online now   Reply With Quote
Old 01-14-2014, 11:01 AM   #91
lewster's Avatar
Which batteries do you have?
Old 01-14-2014, 02:38 PM   #92
toskeysam's Avatar
I have Lifeline, came with my 2013 Interstate
Old 01-14-2014, 02:53 PM   #93
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Upgrading to a 3 stage charger is a pretty simple operation. Airstream should have done this at the factory. Little or no price difference in putting a"smart" charger into the system at the factory. This of course does not apply to the older Airstreams
TinCan
graysailor is offline   Reply With Quote
Old 01-14-2014, 03:29 PM   #94
toskeysam's Avatar
The inverter/charger is the Magnum unit MMS 1012
FMCA # 436814
Old 01-14-2014, 04:02 PM   #95
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
toskeysam, it depends which controller and controller documentation you are referring to:
If you have the ME-MR Remote Control, and the Owner's Manual dated "2010 Magnum Energy, Inc" PN 64-0031 Rev C, you will find no reference to a "Full Charge" state.
This is the hardcopy supplied with my own 2014 Interstate.
But if you attempt to download the documentation like I did, I pulled down a 2010 version of the doc, and it does refer to a "Full Charge" state.
I'm concluding it doesn't exist on my version of the ME-MR.
Incidentally, both copies of the doc state clearly that the ME-MR has minimal settings, and that if you want full function, go with the ME-RC.
Hope that helps…..Peter
Old 01-14-2014, 04:04 PM   #96
UKDUDE's Avatar
Sedona , Arizona
Small typo - the manual I downloaded was a 2009 version - PN: 64-0031 Rev A.
Old 01-14-2014, 04:14 PM   #97
toskeysam's Avatar
UKDUDE...The control panel is the ME-MR, the hardcopy manual I have is PN: 64-0031 Rev A.
Old 01-14-2014, 04:27 PM   #98
UKDUDE's Avatar
Sedona , Arizona
Can you check out the firmware versions using Tech Menu on the Controller? Mine says Inverter Revision 1.6, Controller Revision 1.0.
Then I would suggest a call to Magnum to ask if these Revisions support the "Full power" state.
I'd be interested in their response….Peter
