Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 01-14-2014, 05:06 PM   #101
c21
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Yes, the readings are the same for my 1,000w Magnum in my 14 AI. Anxious to hear what you find out Sam!
c21 is offline   Reply With Quote
Old 01-15-2014, 10:01 AM   #102
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
OK....Tom Scavera at Magnum Energy replied to me this morning. "Yes your setup has all four modes of charging." Also said..."You may not see full charge unless you spend a lot of time at the remote".... Kinda makes sense...
Also, the only way I am going to improve my charging is to have the temp sensor installed. I did order one last week. It is sitting here, in a bag, waiting for me to decide who is going to install it.
toskeysam is offline   Reply With Quote
Old 01-15-2014, 10:28 AM   #103
c21
Thanks for obtaining and sharing the Magnum Invertor info Sam. Also, electrically challenged me installed the temp sensor on my rig and it was very easy. My batteries are in a steel box under one of the twin beds, I drilled a hole near the bottom of the box, used a rubber grommet with liberal silicone sealant around the line then had my phone guy attach a new RG connector (I cut the installed one off to facilitate feeding the line thru the grommet). The RG then plugs into the invertor.
Bill
Old 01-15-2014, 10:37 AM   #104
toskeysam's Avatar
Winter weather here in Tennessee is keeping me from doing the probe installation myself. Cold, rainy, just plain crappy weather. If I had a good break, would tackle it. May wait until spring.
Old 01-15-2014, 10:49 AM   #105
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Thanks from me too, Sam, for clearing this up with Magnum.
I guess I should install a temperature sensor too.
Old 01-15-2014, 10:56 AM   #106
c21
I ordered my battery temperatur sensor from a Company in Arizona called Tekris Power Electronics, Inc (wwww.tekrispower.com). You can call them at (877) 483-5747. I spoke to Shari and she is sold me one for $27 with free shipping. The Magnum part number is ME-BTS-15.
Old 01-15-2014, 07:36 PM   #107
Naples , Florida
GOOD MOVE!
Temperature sensing is very important, especially in high ambient temperatures, as it will keep your batteries from being overcharged. Don't forget that the prescribed voltages for 3 stage charging that everyone speaks of are measured at 77ºF. The higher the temp, the lower the voltage that is required for effective 3-stage charging.
lewster
Old 01-16-2014, 01:56 PM   #108
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
Originally Posted by lewster View Post
GOOD MOVE!
Lewster,
I noticed recently that the AGM 1 Battery Type setting for my Magnum MMS1012 does not quite match the Lifeline Float charge requirements. It's close but a little low, especially with any voltage drop between the Magnum unit and the batteries.
The Lifeline specification call for a Float Voltage of 13.30 +/- 0.1 volts at 77ºF. The Magnum AGM 1 Battery Type called for when using Lifeline AGMs is specified at 13.1 volts at 77ºF.
I've read several things lately that suggest many chargers newer get the batteries to desired full charge because their float voltages are wrong.
Is this significant?
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 01-16-2014, 06:58 PM   #109
Naples , Florida
Originally Posted by Boxster1971 View Post
Lewster,
Mike,
Full charge on a Lifeline is 12.8-13.2VDC, so floating at 13.1 is not as bad as you think. One place I would look is your battery capacity, as they might only have 90-95% capacity, which would not allow them to fully charge.
On another tack, you might look at the absorption time in the charge cycle, where the majority of the charging takes place. If the setting is insufficient for the size of your battery bank, they will never truly fill to capacity.
lewster
Old 01-16-2014, 09:34 PM   #110
2024 Interstate 19
Fulton , Maryland
Thanks Lew,
I'll have a look at my battery capacity and absorption time settings.
- - Mike
Old 01-17-2014, 11:28 AM   #111
c21
Lew, how does one determine the proper absorbtion time
Thanks?
Old 01-18-2014, 06:05 AM   #112
Naples , Florida
Thanks?
• Amp-hour (AH) capacity is a measurement of how many amps a battery can deliver for a specified length of time (usually 20 hours) until the voltage achieves (diminishes to) 1.75 VDC/cell at 80° F. (A 6 volt battery has 3 cells and a 12 volt battery has 6 cells, so the respective voltages are 5.25 VDC and 10.5 VDC)
Battery Bank AmpHrs Capacity
Suggested Absorb Time
200-300 A/H
60 minutes
310-500 A/H
90 minutes
510-700 A/H
120 minutes
710-900 A/H
150 minutes
910-1100 A/H
180 minutes
1110-1300 A/H
210 minutes
lewster
Old 01-18-2014, 08:55 AM   #113
c21
thank you
Old 01-18-2014, 09:00 AM   #114
c21
My batts are ea 80 A/H for a total of 160 so am I correct in assuming a 60 minute absorb time?
Old 01-18-2014, 11:17 AM   #115
Naples , Florida
Yep!
lewster
Old 01-18-2014, 01:04 PM   #116
c21
thank you Lew
