Old 03-11-2015, 10:15 PM   #1
2010 22' Interstate
New Bern , North Carolina
House Batteries Replacement
I need to replace the house batteries in my 2010 Interstate. Previous owner installed wet cell, deep cycle boat/RV batteries and its just too much trouble to get to them under the rear seat to check and fill them. Search function isn't working now or I would look at old threads. What's recommended now? Has anybody had experiences either good or bad? Thanks.
Prairie is offline   Reply With Quote
Old 03-12-2015, 12:42 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Not sure about the battery box for a 2010, so my answer is NOT definitive…
My 2012 came with two Discover Energy EV-24A-A "traction" batteries, which are deep-cycle AGMs designed for use on electric forklifts and such. Not ideal for RV use, but not too bad. (http://www.rectifier.co.za/Batteries...df/EV24A-A.pdf)
When the time comes to replace them, I'll be using Lifeline GPL-24T AGM batteries, which if memory serve is what comes standard in newer-model Interstates (Lifeline Batteries - Marine & RV Deep Cycle Batteries)
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-12-2015, 07:38 AM   #3
Originally Posted by Protagonist View Post
... When the time comes to replace them, I'll be using Lifeline ....
We had to replace ours a few months ago and we also chose the Lifeline. My husband did the headwork on that decision so I'm not sure of the rationale, but I am sure it was thoroughly researched.
InterBlog is online now   Reply With Quote
Old 03-12-2015, 09:31 AM   #4
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
My 2013 came with LifeLine AGM batteries. I think they are now standard.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 03-12-2015, 09:59 AM   #5
2010 22' Interstate
Batteries Plus here in Eastern NC quotes two GPL-24T at $589.24. Does anyone know of another vendor?
Old 03-12-2015, 10:01 AM   #6
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
That price is good. They ain't cheap
jkcru is offline   Reply With Quote
Old 03-12-2015, 05:12 PM   #7
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Some have gone with two 6 volt in series to achieve a greater amp/hour capacity.
Might check Amazon and eBay. Lifeline is the brand that I see mentioned most often.
Old 03-12-2015, 05:23 PM   #8
This only works with the right battery box. In Airstream Interstates where the two house batteries are stacked one atop the other with a wooden false floor in between, it's very tight; the posts of the top battery come very close to making contact with the metal lid of the battery box. The Lifeline 6v 230-amp-hour batteries are taller than the Group 24 12v batteries.
For EXT Interstates with a pull-out battery ttray where the batteries are side-by-side, this is a completely viable option, though.
WBCCI #1105
TAC LA-4
Old 03-12-2015, 06:45 PM   #9
ben322's Avatar
2009 Interstate
Bethesda , Maryland
Two GPL-24's give you 160AH. The lounge battery box will fit two GPL-6CT's which will almost double the capacity at 300AH. Unless you're adding another battery box, this is a large as you can go with the stock configuration.
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 03-12-2015, 07:33 PM   #10
73shark's Avatar
Someone described in excruciating detail on this forum how to use 2 of the 6 volt Lifeline batteries and make it fit.
Or maybe it was on the Sprinter forum.
Old 03-13-2015, 04:28 AM   #11
ben322's Avatar
2009 Interstate
Bethesda , Maryland
Here's what I did here in which I cut the lid but perhaps a thinner spacer between the batteries might make it unnecessary.
Old 03-13-2015, 06:43 AM   #12
lewster's Avatar
Naples, FL , Hood River, OR
Here are a few shots that might help:
First, remove the box
Next, replace the floor with a water proof material and seal with SikaFlex 221
Place batteries and restrain in place
You're done!
These are Lifeline GPL-6CT 300 amp/hour 6VDC batteries
Old 03-13-2015, 03:01 PM   #13
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
You're done!
Very interesting, Lew! So you removed the box altogether; and it hardly matters whether it's the old type (stacked) box or the newer type with the pull-out tray?
Some detail questions please:
How do you restrain the batteries?
What about the external vent? Sealed off or still required?
The carpet was held to the original box with velcro. Did you stick that onto one of the batteries?
How can you ensure nothing in the rear can touch the terminals?
Thanks, Peter
Old 03-14-2015, 12:18 PM   #14
lewster's Avatar
Thanks, Peter
Peter,
Nope, as a good friend from 'Nawlins' always says "it don't make no matta" what type of box you have.
The external vent gets sealed so no water can enter they it. Not required with Lifelines and the new Lithiums are incapable of gassing.
New Velcro tabs on batteries to hold the carpet. All positive terminals (2) are covered and insulated with red silicone boots.
I typically don't run more than 1 wire to the positive output terminal, preferring to use remote terminal blocks.
Let me know if you have any other questions.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
House batteries drain ic2jack5648 Batteries, Univolts, Converters & Inverters 5 04-17-2009 03:03 PM
Tie House & Coach Batteries for Winter Storage? N2XBW Electrical - Systems, Generators, Batteries & Solar 5 11-23-2007 11:29 PM
Help with House Batteries johndes Land Yacht/Legacy Motorhomes 7 12-20-2006 12:56 PM
house batteries wb13798 Mechanics Corner - Engines, Transmission & More... 16 02-07-2006 08:41 PM
30 Amp Power w/o House Batteries Installed Airrayd Electrical - Systems, Generators, Batteries & Solar 4 11-29-2004 01:49 PM
