Old 07-07-2018, 03:37 PM   #1
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Hottest/Coldest Place your Interstate has ever been parked on/in
After reading these threads:
- MAGGIE's Locating new-to-me Interstate (bailed on camping due to 115 °F heat)
- INTERBLOG's Declaring war on Interstate summer heat gain (her inspirational mods to incrementally reduce inside temps, taking many tips from here)
- PAHASKA's Refrigerator ventilation (how temps affect fridge performance, taking many tips from here),
- numerous window tint threads (done all tips from there)
- my own inverter meltdown experience (on-going)
I was inspired to dig up my pics of the temps I have recorded outside & inside the AI this past month when summer came with a bang. I think my local temps in Las Vegas will easily put me within the Top 10 Hottest places anyone has ever parked their Interstate. Maybe only HITTENSTIEHL & INTERBLOG can top my "heat" numbers. Since I no longer live in Chicago, I can no longer complain about the cold midwest winters, but would love to see what numbers we are talking about on the other cold extreme.
The Airstream Interstate Manual comes with very well known winterizing procedures but hardly anything is documented (other than above threads) about "summerizing" the AI. This qoute from OTRA15 in Maggie's thread yesterday struck a cord in me: "No RV is designed to be habitable in that kind of heat. " This is so true, but I wonder why that is? My stick house in Las Vegas and Chicago were built such that they would be livable & interchangeable in either extreme weather conditions experienced in either city (save for the regional aesthetic architectural difference). Shouldn't RV's be built that way, since it is clear they get transported from one extreme weather to another? And after all, most consider RV's a 2nd home, rolling home, condo-on-wheels, etc. etc.
Here are my top heat numbers so far (only 2 weeks into summer):
Dealer's parking lot, midday, exterior using MB temp sensor = 114 °F
Name:	Exterior in dealers lot.jpg
Dealer's parking lot, midday, interior using Firefly temp display = 117 °F
Name:	Interior in dealers lot.jpg
Dealer's parking lot, midday, under R/S jumpseat measuring Magnum casing temp = 118.8 °F
Name:	Magnum casing parked on driveway.jpg
Inside insulated garage, yesterday, 8am, TST temps on "cold" (97 °F) tire pressure with AI resting inside the past 36hrs.
Name:	Tire cold temps 8am in garage.jpg
Pool Kool Decking near waters edge, yesterday, midday, same identical decking extends to side of house used as a patio and AI parking when not in garage = 133 °F
Name:	Pool Kool Decking.jpg
Asphalt at edge of front driveway, yesterday, midday, temp reading taken same time as above Kool Decking temp was taken. Notice 27 degree difference in temp from asphalt vs. Kool Decking (Concrete driveway was only marginally cooler than asphalt) = 160.6 °F
Name:	Asphalt at driveway.jpg
Alex AVI is offline   Reply With Quote
Old 07-08-2018, 05:55 AM   #2
2013 Interstate Coach
Raymond , Iowa
I do not trust my dash temperature display. Under steady-state driving conditions on pavement it reads about 5 deg F high. It jumps up immediately after re-starting to be 20ish degrees high. I assume that is because it is an area that receives engine (radiator?) heat while it is sitting.
What has surprised/impressed me is not the air temperature, but rather the coolant temperature while under load at high air temperatures. On the Colorado Million Dollar Highway on a hot day (high 90's) the coolant temperature did not reach 250. I do chicken out a bit and turn off the AC when going up a long hill on a hot day. AC load is not all that much, but the AC heat exchanger is located in front of the radiator/intercooler and heats the air even more before the radiator gets it. Coolant temp drops about 10-15 degrees when I do that.
Titus is offline   Reply With Quote
Old 07-08-2018, 05:58 AM   #3
In one July many years ago, in order to complete an environmental inspection of a client's property, I flew from Houston to Phoenix, drove down to Tucson, did the job, and was so horrified by my surroundings that I drove straight back to Phoenix so that I could hop a plane back to Houston in order to get some relief from the heat. (In those pre-TSA days, we frequent flyers could board pretty much any Southwest flight on the spot and at will, as long as we had some sort of ticket in hand). It ended up being close to a 24-hour working day but I just wanted to get the hell out of Arizona.
In our case here in Houston, our issue is heat index moreso than absolute temperature. It's 7 a.m. as I write this and our relative humidity across various local Wunderground stations is 95 to 99 percent, with dew points between 74 and 77 degrees. Heat indices are typically well over 100 degrees in the summer.
I actually don't have the best temperature data on our Interstate because the Honeywell thermostat that we installed to replace the OEM Atwood which controls the furnace has a temperature reading that is only two digits. It pegs at 99 degrees and then I never know how much over that we are. I ought to buy a better thermometer.
Edit: Did y'all see the Australian melting roadway stories a few days ago? We actually had the same thing happen in our neighboring city of Kemah last year (something like 40 cars were disabled before they shut down traffic). Here's a link:
http://www.abc.net.au/news/2018-07-0...nsland/9942800
Old 07-08-2018, 09:42 PM   #4
Alex AVI's Avatar
TITUS - My dash gauge is pretty spot on ( +/- 1 degree) once on the move & steady state speed, basing it on local radio weather reports as I drive around town. But it is 10 degrees high during first few minutes after startup.
I do get very attentive on high heat & long hills, eagle eyes on temp gauge but have not tried turning off A/C just to test. May do that on my next trip. Hard to do when temps are this hot, unless it is really necessary. So far, my gauge is never above the hash mark between 175/250
Old 07-08-2018, 09:48 PM   #5
Alex AVI's Avatar
INTERBLOG - I heard about it, but did not read the reports until your posted link. I did not realize it was that bad. They did not post any temps on that report though?
About airports & flying in Las Vegas summers - they routinely stops flights taking off from McCarran when it gets too hot. Something to do with planes not getting the lift needed at certain high temps? I am not an aviation engineer, so no clue here. Sure you & LB_3 are very familiar with this phenomena.
Old 07-08-2018, 10:00 PM   #6
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
Temperature has a big effect on aircraft takeoff performance, as does altitude. I had to wait once until very late evening to take off from Lowry AFB in Denver on a hot summer day. There was just not enough runway at that heat and altitude.
John W. Irwin
WBCCI #9632
Old 07-08-2018, 11:03 PM   #7
2007 22' International CCD
It’s called Density Altitude. It is calculated based on air pressure and temperature. Particularly critical near full gross weight and high altitude and high temps. If the density altitude works out too high for the load and power, you are not gonna fly. That’s why high altitude airfields sometimes shut down in good weather. There is a lot more to flying safely than, “Kick the tires, light the fires.”
Have had some interesting marginal takeoffs from Lake Tahoe in light, but underpowered aircraft because the command pilot didn’t do the appropriate math carefully.
Rich, KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
2012 shortbed CrewMax 4x4 Toyota Tacoma TV with more antennae on it
Old 07-08-2018, 11:23 PM   #8
Alex AVI's Avatar
Originally Posted by rmkrum View Post
Have had some interesting marginal tkeoffs from Lake Tahoe in light, but underpowered aircraft because the command pilot didn’t do the appropriate math carefully.
RMKRUM - Ugh, that's just scary. Also underscores how extreme heat/cold could ground a sophisticated x-million dollar aircraft; so I would not be too far off in thinking similar things could happen to AI systems in these conditions. McCarran & Nellis AFB are at 2,100 ft asl. I am at 3,200 and I routinely go up Mt. Charleston at 8,500. Maybe they should not have sold me an AI for use in Las Vegas heat? I still think it is the reason why my Magnum had a meltdown
Old 07-09-2018, 04:39 AM   #9
Lily&Me's Avatar
Normal , Illinois
Ultimately, our Interstates are hot in the southern states because they are steel boxes baking under the hot sun.
I experienced 115 degrees picking up the new rig in Arizona last week, and have dealt with temps in the teens a half dozen times or so....neither extreme remotely pleasant, and I will continue to do my best to avoid these in the future.
Go north in the summer, and south in the winter...that’s what’s logical, and my plan.
Maggie
Old 07-09-2018, 11:22 AM   #10
Alex AVI's Avatar
Maggie
MAGGIE - you might be in a select group who have dealt with both hot/cold extremes in their AI. It has been 28 yrs since I experienced anything below 32 degrees. I plan to keep it that way. Your plan of going north in summer is excellent. Hoping to do so every chance we get coz as you say, it just ain't pleasant. Glad to read in other thread your A/C is fine. This extreme heat always makes me wonder at times if my A/C in the other cars are working at all
Old 07-09-2018, 12:41 PM   #11
Lily&Me's Avatar
Normal , Illinois
We were never intentionally in temps in the teens, but experienced them both in Louisiana and in south Texas...the latter also included an ice storm.
It happens...extreme temps in places that don’t usually have them.
But, speaking from those experiences, they should be avoided if at all possible.
Maggie
Old 07-09-2018, 01:18 PM   #12
I built a camping van into a 1970’s GMC van. The only heat it had was a 120 volt powered bathroom heater in one of the sidewalls. Camped out in 25 degree weather. The Ranger knocked on the door in the middle of the night to see if we were ok.
Rich, KE4GNK/AE
Old 07-09-2018, 03:24 PM   #13
Alex AVI's Avatar
RMKRUM - you did not say if you slept in the bathroom or not? That was thoughtful of ranger to check on you.
Old 07-09-2018, 03:48 PM   #14
Yeah, he was real concerned because it got colder than usual that night. Although we told him we had heat, he was a really nice guy, and I'm sure he was worried about the ONLY fools out there camping that night on our shakedown trip. I had so much insulation stuffed under the interior skins we were quite comfortable.
Only bathroom in that rig was a Sears porta-pottie.
It was a decent setup, with a compressor refrigerator, a three-burner stovetop, a nice kitchen sink, and a nice interior with big windows by the back sofa/bed. I built the whole interior using a set of templates I found in an RV supply catalog. Fancy seats and couch custom from Steelcase, nice carpet with padding on the floor that could be slept on in bad weather. 30 gallon propane tank and 20 gallon fresh water tank. Evaporative cooler on the roof that worked great out in the desert as well. Made a fancy lined custom set of curtains for it all around with my 'manly sewing machine skills' as well.
Went a lot of neat places with it.
It traveled nice, but had no dash air, so we sold it when we moved to Alabama...
Rich, KE4GNK/AE
Coach that has been parked for a long time kb0zke Dollars & Cents 13 08-03-2015 07:17 AM
Does the hottest weather overwhelm LP gas refers' ability to keep food frozen? Aage Refrigerators 18 08-24-2012 09:52 PM
Perhaps the lamest question that has ever been asked... bycrom Hitches, Couplers & Balls 19 08-17-2012 06:19 PM
Recommended Maintenance for a New A/S that has been parked too long RDM16CCD Wheels, Hubs & Bearings 2 11-04-2008 01:05 AM
Airstreamer Matthew McConaughey named hottest bachelor. Sean Michael Airstream "In the News" 1 06-15-2007 08:43 PM
