Old 06-15-2014, 11:32 AM   #1
weirdstuff's Avatar
2018 23' International
San Diego , California
Hot Water Heater Light Won't Come On
We're plugged in, and we DO have hot water. But just noticed that the red "on" light on the water heater switch isn't lit. Should it be lit red?
weirdstuff is offline   Reply With Quote
Old 06-15-2014, 11:50 AM   #2
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
I think you'll find that it lights red when there is a problem with the gas ignition. Check your manual to be sure though.
Bikerbill is offline   Reply With Quote
Old 06-15-2014, 12:30 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It's not an "on" light; it's a "fault" light. And the light works whether you're on propane or electric or both if there's a fault somewhere in the system that causes the heater to shut down.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-15-2014, 12:38 PM   #4
weirdstuff's Avatar
Thanks. First I thought it was opposite. My dumb.
Old 06-15-2014, 03:01 PM   #5
David M's Avatar
2013 Interstate Coach
Orange County , California
Don't feel dumb. I thought it worked the same way you did at first
David
David M is offline   Reply With Quote
Old 06-15-2014, 04:12 PM   #6
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
I did the same thing then I sought it goes on when the water is hot still I discovered it stayed on and the water was not hot. They Thermo fuse was blown now everything works fine without a light on.
PSchw is offline   Reply With Quote
Hot water heater won't ignite jkinglet Sprinter and B-van Forum 16 06-18-2014 11:29 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
Hot water heater won't light. :( sinjin Water Heaters, Filters & Pumps 14 12-20-2008 10:25 AM
Hot Water tank won't light Larry Salsma Furnaces, Heaters, Fireplaces & Air Conditioning 0 10-16-2007 09:17 PM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
