Old 03-24-2016, 10:06 AM   #15
2015 Interstate Ext. Coach
Lake Mary , Florida
Lol protagonist ))
I've never tried that power booster bank. But I'm not sure what you are talking about... If you mean not starting but just activating accessories, yes the battery circle needs at list a little power.
Once my Mercedes G-wagen was staying in the garage for a long time with activated TeleAid, and its battery completely died. When I incerted the key to ignition, I was NOT able to turn the key even in the first position, also I was NOT able to remove the key from ignition. Once I connected the jump cables from other car battery, a small amount of power applied to the system circle, and I turned the key to position one and everything was activated in the car, so the key chip needs just a little power to be activated.
Mr. B is offline   Reply With Quote
Old 03-24-2016, 01:22 PM   #16
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
A point that a lot fail to realize is that the jumper car or portable battery pack doesn't actually start the dead car, it merely recharges the battery in the dead car allowing it to start the vehicle. That's why you don't need jumper cables that resemble welding cables because they aren't passing the several hundred amps required to start a car. Plus most jumper cables' clamps don't make adequate contact to pass the current anyway.
Old 03-24-2016, 04:41 PM   #17
Lake Mary , Florida
Marc, it seems that the Power Box is not charging battery but gives an immediate high-amperage boost to turn the starter.
Old 03-24-2016, 06:13 PM   #18
Houston , Texas
I have the Lightning Pak and it has saved me twice jump starting a 3.5 litre V-6 from a dead and compromised battery. My version targets Power Sports but impressively turned the car engine long enough and fast enough to get it running.
Further details
Jump Start Pack must be disconnected from vehicle within 30 seconds of starting the vehicle or damage may occur. 12 Volt, 6500 mA-h lithium battery.
200 amp (400 peak amp) jump starting ability, enough power to start most any powersport vehicle numerous times. Weighs 8 oz., ultra compact size - 5 1/2" L x 3" W x 1/2" T.
High powered LED flashlight with attention getting SOS emergency flash mode.
5v USB port, includes micro USB, iPhone 4 and iPhone 5 charging adapters.
Includes 110 volt charger, 12 volt car charger and storage pouch.
Mcrider is offline   Reply With Quote
Old 03-24-2016, 07:28 PM   #19
73shark's Avatar
The cables in the picture look pretty small to carry several hundred amps.
Good way to check is to disconnect your + cable on the battery, hook up the Power Box and see if you can start the vehicle.
Old 03-24-2016, 07:58 PM   #20
Lake Mary , Florida
Look what is stated on my unit:
Old 03-24-2016, 08:02 PM   #21
Lake Mary , Florida
It is designed to start the engine by cranking a starter
400 AMP pick power is good enough to our diesel.
Old 03-24-2016, 08:08 PM   #22
Lake Mary , Florida
For my opinion it is a very convenient item, and a good peice in mind that you have your power with you.
Old 03-25-2016, 03:47 PM   #23
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
If it's of any help, Mr Bean, I received an email from Parts.com and out of curiosity looked at all the components that make up the hood:
https://www.parts.com/index.cfm?fuse...iagram=5911155
And if you break the Air Vent trying to remove it, it's only $18 to replace it.
Old 03-25-2016, 05:08 PM   #24
Lake Mary , Florida
Thanks youkaydude!
But I'm not a bean ))))))
The HOOD panel removal cwf Stoves, Ovens & Microwaves 0 03-07-2016 11:18 PM
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 12:49 PM
Range Hood and Cabinet Removal TPdrums General Appliance Topics 10 02-25-2010 06:35 AM
Exterior Hood Vent hmsteader Stoves, Ovens & Microwaves 1 10-27-2004 10:47 AM
Range Hood Vent Cover Chuck Roof Vents, Skylights & Fans 0 08-06-2003 06:31 AM
